Analyze Arm Ethos-U models with Arm ML Inference Advisor
Understand where MLIA fits in model preparation
Install MLIA and discover capabilities
Analyze LiteRT artifacts with MLIA and Vela
Analyze TOSA IR artifacts with MLIA and Vela
Analyze ExecuTorch artifacts with MLIA and Corstone
(Optional) Use the MLIA Python API
(Optional) Use the MLIA and Model Explorer VS Code extension
Run a compatibility check
Start by asking Arm ML Inference Advisor (MLIA) whether a LiteRT model can map to the selected target profile.
LiteRT is a compact model format and runtime stack for deploying machine learning models on mobile, embedded, and edge devices. In embedded ML workflows, a .tflite file is often the artifact handed to backend tools for target-specific compatibility checks, compilation, or runtime deployment.
The model artifacts repository includes floating-point and quantized MobileNetV2 LiteRT variants:
tflite/mv2_fp32.tflite
tflite/mv2_int8.tflite
From the ml-model-artifacts directory, run MLIA on the FP32 LiteRT artifact:
mlia check tflite/mv2_fp32.tflite \
--target-profile ethos-u85-256 \
--compatibility \
--backend vela \
--json
The --json option makes the output easier to inspect, compare, and automate.
You can also use the shorter -t and -b options instead of --target-profile and --backend. Note that --compatibility and vela are both defaults that can be omitted:
mlia check tflite/mv2_fp32.tflite -t ethos-u85-256 --json
The report should show the FP32 LiteRT model as incompatible for Ethos-U acceleration, with accelerator_operator_percentage set to 0. This is expected because Ethos-U acceleration requires supported quantized integer workloads. The failed checks explain that the input, output, and weight tensors are missing quantization parameters.
This doesn’t mean LiteRT is the problem. It means that this particular LiteRT artifact isn’t in the numeric form the selected Ethos-U target needs. Use a quantized model instead.
Run the same compatibility check on the quantized INT8 model:
mlia check tflite/mv2_int8.tflite \
--compatibility \
--backend vela \
--json
You’ll generate a lengthy report, saved in the mlia-output directory in the root of the mlia execution directory. The following is a small snippet of the report:
"target": {
"configuration": {
"target": "ethos-u85",
"mac": 256
"model": {
"name": "mv2_int8.tflite",
"format": "tflite"
"backends": [
"id": "vela",
"name": "Vela Compiler",
"version": "5.0.0"
"results": [
"kind": "compatibility",
"status": "ok",
"metrics": [
"name": "accelerator_operator_percentage",
"value": 100.0
The following table describes the fields in the generated report, and what they mean:
| Field | What it tells you |
schema_version, run_id, timestamp | Which output schema was used, and how you can identify this specific run later. |
tool | The MLIA version that generated the report. |
target | The selected target profile and its configuration, such as Ethos-U85 with 256 MACs. |
model | The artifact name, format, and hash. |
context | The CLI command that produced the report. |
backends | The backend MLIA used, including the Vela version and compiler configuration. |
results | The answer MLIA produced for the requested check. |
checks | The individual operator support checks. |
entities | The operators MLIA analyzed, including placement and operator type. |
For the INT8 LiteRT file, the important result is that the status is ok and accelerator_operator_percentage is 100.0. That means Vela found the operators in this quantized MobileNetV2 LiteRT artifact compatible with the selected ethos-u85-256 target profile. MLIA therefore expects the operator work to map to the NPU path for this compatibility check.
The result doesn’t prove runtime latency or application accuracy. It tells you that the model is a good candidate for the next step: performance estimation and deeper deployment testing.
Read operator placement
The summary result tells you that the model is compatible overall. To see how MLIA reached that result, look at the entities list. Each operator entity describes one analyzed operator and includes a placement field:
"scope": "operator",
"name": "...",
"placement": "npu",
"attributes": {
"op_type": "Conv2D"
Names and attributes vary by input format and MLIA version. The important part is the placement. The placement tells you where MLIA and the backend analysis expect the operator to land for this target profile.
If a future model has unsupported operators, this is where you start narrowing down the problem. Find the operator whose placement or check status differs from the expected NPU path. Then, inspect that part of the model graph or change the model before deployment.
Run a performance check
Next, ask MLIA for a target-aware performance estimate using the INT8 LiteRT model:
--performance \
--backend vela \
--json
Because this run uses Vela, the performance report uses the same top-level structure as the compatibility report. The results object now contains estimated performance metrics, operator-level breakdowns, and advice:
"results": [
"kind": "performance",
"status": "ok",
"warnings": [
"The performance figures above refer to NPU only"
"metrics": [
"name": "npu_cycles",
"value": 3623146
"name": "total_cycles",
"value": 5006357
"name": "inference_time",
"unit": "ms",
"value": 5.006357
"name": "inferences_per_second",
"unit": "inferences/s",
"value": 199.74604288108097
"name": "target_utilization",
"unit": "%",
"value": 72.3709076280417
"advice": [
"category": "performance",
"severity": "warning",
"message": "The following layers make up the majority of operator cycles..."
"message": "Among the layers with the highest impact, 5 layers have been identified with low MAC utilization..."
"message": "Among the layers with the highest impact, 5 layers have been identified as possibly memory bound..."
warnings | Important scope limits for the result, such as the estimate referring to NPU work only. |
metrics | Summary estimates for cycles, inference time, throughput, utilization, model size, and memory use. |
breakdowns | Per-operator metrics, including operator cycles, memory access cycles, multiply-accumulates (MAC) count, and MAC utilization. |
advice | MLIA’s interpretation of the metrics, including which layers dominate cycles or might be inefficient. |
availability and reason | Why a metric isn’t available from the selected backend, if MLIA can’t report it. |
For this INT8 LiteRT file, the Vela-backed estimate reports the following:
- About
5.01Mtotal cycles - About
5.01 msinference time for batch size 1 - About
199.7inferences per second - About
72.4%target utilization - About
3.62MNPU cycles, plus SRAM and DRAM access cycles
Treat these as target-aware estimates for the NPU portion of the model rather than final runtime measurements from hardware.
In this report, MLIA advises on where to investigate to improve target performance. The advice identifies the ten layers that make up most operator cycles. It flags five high-impact layers with low MAC utilization, and five high-impact layers as possibly memory-bound.
Low MAC utilization can be expected for layers with small channel counts, small spatial dimensions, or heavy memory movement. These are the layers to consider adjusting.
You’ve used MLIA to check compatibility and estimate performance with LiteRT and Vela. You’ve also learned how to read target and backend metadata, metrics, operator placement, and advice.
Next, you’ll inspect the Tensor Operator Set Architecture (TOSA) intermediate representation (IR) using MLIA.
