Check your environment
Use Ubuntu 24.04 LTS on an x86-64 machine with CPython 3.12. If you use a different Linux distribution, ensure that it supports glibc 2.39 or later and CPython 3.12.
On Ubuntu 24.04, install Git, Git Large File Storage (LFS), and the Python 3.12 development and virtual environment packages:
sudo apt update
sudo apt install -y git git-lfs python3.12-dev python3.12-venv libatomic1
The Corstone-320 simulator requires libatomic1, which provides the libatomic.so.1 shared library.
Check the architecture, glibc version, Python version, and Git LFS installation:
uname -m
ldd --version
python3.12 --version
git lfs version
Confirm that the architecture is x86_64, the glibc version is 2.39 or later, and Python is 3.12.x. For Visual Studio Code (VS Code) over SSH or in a development container, check these requirements where you plan to run the Arm ML Inference Advisor (MLIA) extension.
Create a Python environment
Create a virtual environment so that the MLIA packages don’t conflict with any existing ML framework environment:
python3.12 -m venv mlia_env
source mlia_env/bin/activate
python -m pip install --upgrade pip
Install MLIA
MLIA uses plugins. The example target in the Learning Path is Ethos-U, so install the Ethos-U plugin package:
python -m pip install mlia-ethos-u
The Ethos-U plugin package depends on a compatible MLIA core package. Installing the target plugin is the recommended starting point because it brings in the matching MLIA core dependency.
Confirm the CLI works
Display top-level help:
mlia --help
The output is similar to:
          check     Generate compatibility/performance advice for a model
  backend   Manage MLIA backends
  target    Manage MLIA targets
The mlia check command is the main command you’ll use to ask MLIA compatibility and performance questions about model artifacts.
Discover target profiles
MLIA target profiles describe the target configuration used for analysis. List the target profiles available in your environment:
mlia target list
For Ethos-U, typical bundled profiles include:
Target profileEthos-U NPUMultiply-accumulates per cycle
ethos-u55-128Ethos-U55128
ethos-u55-256Ethos-U55256
ethos-u65-256Ethos-U65256
ethos-u65-512Ethos-U65512
ethos-u85-128Ethos-U85128
ethos-u85-256Ethos-U85256
ethos-u85-512Ethos-U85512
ethos-u85-1024Ethos-U851024
ethos-u85-2048Ethos-U852048
ethos-u85-256 is the Ethos-U85 profile that’s used in the examples. If you want MLIA to evaluate the same model for a different Ethos-U configuration, use a different profile.
Discover backends
Backends perform the work behind an MLIA analysis flow. List available and installed backends:
mlia backend list
For this Ethos-U demonstration, expect Vela and Corstone backend options:
        Name          Installed  Installable
corstone-300  no         yes
corstone-310  no         yes
corstone-320  no         yes
vela          no         yes
Use Vela for LiteRT and Tensor Operator Set Architecture (TOSA) checks. Use Corstone for packaged ExecuTorch .pte checks.
When you later use mlia check, any missing backends required by your target will be installed.
Clone model artifacts
Clone prebuilt artifacts from the Arm ML model artifacts repository:
git lfs install
git clone --filter=blob:none --sparse https://github.com/arm-education/ml-model-artifacts.git
cd ml-model-artifacts
git sparse-checkout set pte tflite tosa
git lfs pull \
  --include="pte/toy_conditional_select_int8_ethos_u55_256.pte,pte/toy_conditional_select_int8_ethos_u85_256.pte,tflite/mv2_fp32.tflite,tflite/mv2_int8.tflite,tosa/mv2_fp32.tosa,tosa/mv2_int8.tosa" \
  --exclude=""
git lfs checkout
This downloads only the artifacts that are required for you to complete the Learning Path. It avoids larger unrelated files, such as transformer .pte, .etdp, and .etrecord artifacts.
Confirm that the artifacts are real model files rather than Git LFS pointer files:
wc -c tflite/mv2_int8.tflite
The output is a size of several megabytes, similar to:
        3942808 tflite/mv2_int8.tflite
If the file is about 100 to 200 bytes, it’s still a Git LFS pointer file. Run the git lfs pull command again from the ml-model-artifacts directory, then rerun the size check.
The model artifacts are provided for learning and analysis exercises. Use the artifacts to explore MLIA workflows, model formats, and target-aware advice rather than accuracy reference models.
The repository contains model artifacts such as:
        ml-model-artifacts/
├── pte/
│   ├── toy_conditional_select_int8_ethos_u55_256.pte
│   └── toy_conditional_select_int8_ethos_u85_256.pte
├── tflite/
│   ├── mv2_fp32.tflite
│   └── mv2_int8.tflite
└── tosa/
    ├── mv2_fp32.tosa
    └── mv2_int8.tosa
You’ve installed MLIA, along with the Ethos-U plugin. You’ve also discovered available target profiles and backends from the CLI, and cloned model artifacts for analysis.
Next, you’ll run your first MLIA compatibility and performance checks.
