The default Alif VS Code template divides memory equally between the two Cortex-M55 cores and allocates modest stack/heap sizes suitable for simple examples like Blinky. A MobileNetV2 model with ExecuTorch needs significantly more:
You need to reconfigure the MRAM allocation, stack/heap sizes, and linker script to fit this workload.
Open device/ensemble/RTE/Device/AE822FA0E5597LS0_M55_HP/app_mem_regions.h.
Change the following values from their defaults:
| Define | Default value | New value | Purpose |
APP_MRAM_HE_BASE | 0x80000000 | 0x80580000 | Move HE core out of the way |
APP_MRAM_HE_SIZE | 0x00200000 | 0x00000000 | Give HE core zero MRAM |
APP_MRAM_HP_BASE | 0x80200000 | 0x80000000 | HP core starts at MRAM base |
APP_MRAM_HP_SIZE | 0x00200000 | 0x00580000 | HP core gets full 5.5 MB |
APP_HP_STACK_SIZE | 0x00002000 | 0x00004000 | 16 KB stack (doubled) |
APP_HP_HEAP_SIZE | 0x00004000 | 0x00010000 | 64 KB heap (quadrupled) |
The default template splits MRAM 2 MB / 2 MB between the two cores. Since you’re only using the HP core, you give it the entire 5.5 MB of available MRAM. The increased stack and heap accommodate ExecuTorch’s initialization code, which uses more stack depth and a few small dynamic allocations.
Open device/ensemble/RTE/Device/AE822FA0E5597LS0_M55_HP/linker_gnu_mram.ld.src.
Make the following three changes to this file.
The application code places the 4 MB planned memory pool in SRAM1. The C runtime startup code needs to zero-initialize this region. Find the .zero.table section:
#if __HAS_BULK_SRAM
LONG (ADDR(.bss.at_sram0))
LONG (SIZEOF(.bss.at_sram0)/4)
#endif
Add two lines for SRAM1 immediately after:
#if __HAS_BULK_SRAM
LONG (ADDR(.bss.at_sram1))
LONG (SIZEOF(.bss.at_sram1)/4)
#endif
The precompiled ExecuTorch libraries use position-independent code (PIC), which relies on a Global Offset Table (GOT). The GOT must be copied from flash to RAM at startup, otherwise the table contains zeros and every indirect function call (including C++ vtable lookups) crashes with a BusFault.
Find the .data.at_dtcm section:
.data.at_dtcm : ALIGN(8)
*(vtable)
*(.data)
*(.data*)
*arm_common_tables*(.data* .rodata*)
KEEP(*(.jcr*))
. = ALIGN(8);
Add the GOT entries after KEEP(*(.jcr*)):
*(vtable)
*(.data)
*(.data*)
KEEP(*(.jcr*))
/* GOT for PIC code in precompiled ExecuTorch libraries */
*(.got)
*(.got.plt)
. = ALIGN(8);
This issue can be difficult to diagnose. Without these two lines, the firmware boots and loads the model, but crashes with a BusFault when ExecuTorch calls a virtual function. The GOT stores addresses for indirect calls. If the startup code doesn’t copy it from flash to RAM, those lookups resolve to address zero and the CPU faults.
The application code uses __attribute__((section(".bss.at_sram0"))) to place memory pools in SRAM. The stock linker script only has specific named sections for LCD and camera buffers. You need wildcard patterns to catch the ExecuTorch pools.
Find the .bss.at_sram0 section:
.bss.at_sram0 (NOLOAD) : ALIGN(8)
*(.bss.lcd_crop_and_interpolate_buf)
*(.bss.lcd_frame_buf)
*(.bss.camera_frame_buf)
*(.bss.camera_frame_bayer_to_rgb_buf)
} > SRAM0
#endif
Replace it with expanded SRAM0 wildcards and a new SRAM1 section:
*(.bss.at_sram0)
*(.bss.at_sram0.*)
} > SRAM0
.bss.at_sram1 (NOLOAD) : ALIGN(8)
*(.bss.at_sram1)
*(.bss.at_sram1.*)
} > SRAM1
#endif
After these changes, the memory layout is:
| Region | Size | Usage |
| MRAM | 5.5 MB | Code + model (~4.5 MB used) |
| ITCM | 256 KB | Fast code (~89% used) |
| DTCM | 1 MB | Stack (16 KB) + heap (64 KB) + GOT + data |
| SRAM0 | 4 MB | Method pool (1.5 MB) + temp pool (1.5 MB) + float input buffer (~588 KB) |
| SRAM1 | 4 MB | Planned memory buffers |
The Security Toolkit needs a JSON configuration file that tells it where to load the binary in MRAM and which CPU should boot it.
Open (or create) .alif/M55_HP_cfg.json and set its contents to:
"DEVICE": {
"disabled" : false,
"binary": "app-device-config.json",
"version" : "0.5.00",
"signed": true
"USER_APP": {
"binary": "alif-img.bin",
"mramAddress": "0x80000000",
"version": "1.0.0",
"cpu_id": "M55_HP",
"flags": ["boot"],
"signed": false
The key fields are:
mramAddress: must match APP_MRAM_HP_BASE (0x80000000) from app_mem_regions.h.cpu_id: M55_HP tells the bootloader to start the High-Performance core.flags: ["boot"]: marks this application as the boot image.You can view the completed versions of these edited files in the workshop repository for reference.
The memory layout and flash configuration are complete. The next section covers preparing the test image.
You’ve reconfigured the memory regions to allocate the full 5.5 MB of MRAM to the HP core, modified the linker script to support GOT relocation and SRAM memory pools, and configured the Security Toolkit JSON file to boot the application from the correct MRAM address.
Next, you’ll prepare a test image for classification by converting it to the format the model expects.
