Clean previous build artifacts
If you’ve built other projects (like Blinky), delete the cached build files. CMSIS Toolbox caches aggressively and won’t pick up YAML configuration changes unless you clean first:
cd ~/alif/alif_vscode-template
rm -rf tmp/ out/
You can also clean from VS Code: press F1 and select CMSIS: Clean all out and tmp directories.
Build the project
Option 1: Build from VS Code
  • Select the CMSIS icon in the left sidebar.
  • Select the gear icon and set Active Target to E8-HP and Active Project to mv2_runner.
  • Select the Build (hammer) icon.
Option 2: Build from the command line
If you prefer to build from the terminal, set the required environment variables first. The exact paths depend on where the Arm Tools Environment Manager installed the tools:
export PATH="~/.vcpkg/artifacts/2139c4c6/tools.open.cmsis.pack.cmsis.toolbox/2.12.0/bin:~/.vcpkg/artifacts/2139c4c6/compilers.arm.arm.none.eabi.gcc/13.3.1/bin:~/.vcpkg/artifacts/2139c4c6/tools.kitware.cmake/3.31.5/bin:~/.vcpkg/artifacts/2139c4c6/tools.ninja.build.ninja/1.13.2:$PATH"
export CMSIS_COMPILER_ROOT="~/.vcpkg/artifacts/2139c4c6/tools.open.cmsis.pack.cmsis.toolbox/2.12.0/etc"
export GCC_TOOLCHAIN_13_3_1="~/.vcpkg/artifacts/2139c4c6/compilers.arm.arm.none.eabi.gcc/13.3.1/bin"
cbuild alif.csolution.yml --context mv2_runner.debug+E8-HP
Note
The GCC_TOOLCHAIN_13_3_1 variable must include the /bin suffix. Without it, the build system can’t find the compiler executables.
Check the output binary size:
ls -lh out/mv2_runner/E8-HP/debug/mv2_runner.bin
The binary should be approximately 4 MB.
Flash to the board
In VS Code, press F1, select Tasks: Run Task, then select Program with Security Toolkit (select COM port). Choose the DevKit’s port when prompted.
The flashing process takes about 30 seconds. The Security Toolkit reads the M55_HP_cfg.json configuration and writes the binary to the correct MRAM address.
View output with SEGGER RTT Viewer
  • Open SEGGER J-Link RTT Viewer on your development machine.
  • Set Connection to USB.
  • Filter by manufacturer: AlifSemiconductor.
  • For Device, start typing AE822F and select AE822FA0E5597LS0_M55_HP (Core: Cortex-M55).
  • Select OK to connect.
The expected output is:
        mv2_runner booted
Ethos-U85 NPU initialized (polling mode)
Model bytes: 3835552
Image bytes: 150528
ExecuTorch runtime initialized
Program loaded successfully
Method 'forward': 1 inputs, 1 outputs, 1 planned buffers
  Planned buffer[0]: 752640 bytes
Loading method 'forward'...
[I] data:0x800432b0
Method loaded, 1 inputs, 1 outputs
Converted input to float32
Input tensor set (1x3x224x224 float32)
Running inference...
[sem_take #1] count=1
[sem_take #2] count=0
Inference complete!
Output tensor: 1000 elements
Top-1 class: 283
Detected: cat! (ImageNet class 283)
If you see Detected: cat! with a class in the 280-285 range, the inference ran successfully on the Ethos-U85 NPU.
Understanding the output
Each line tells you something about what’s happening:
  • “Ethos-U85 NPU initialized (polling mode)”: The NPU driver connected to the correct peripheral (NPU_HG). “Polling mode” means NPU completion is detected by polling the status register rather than using an interrupt.
  • “Model bytes: 3835552”: The embedded .pte model is 3.7 MB.
  • “Method ‘forward’: 1 inputs, 1 outputs, 1 planned buffers”: The model has a single input tensor and single output tensor. ExecuTorch pre-plans one intermediate buffer.
  • “sem_take #1 count=1” and “sem_take #2 count=0”: The NPU semaphore was signaled. Two semaphore takes means the NPU processed the entire model as a single command stream.
  • “Top-1 class: 283”: ImageNet class 283 is “Persian cat”. The 1000-element output vector was scanned for the highest score.
Troubleshooting
If you don’t see the expected output, check these common issues:
  • RTT Viewer shows nothing: The code starts running as soon as it’s flashed. If you connect RTT Viewer too late, you might miss the output. Press the board’s reset button after connecting RTT Viewer.
  • “ethosu_init failed”: The NPU base address is wrong. Verify the code uses NPU_HG_BASE (0x49042000), not NPU_HP_BASE.
  • BusFault at a low address: The GOT sections are missing from the linker script. Verify that *(.got) and *(.got.plt) are in the .data.at_dtcm section.
  • “Missing operator: cortex_m::quantize_per_tensor.out”: libcortex_m_ops_lib isn’t in the --whole-archive block. Check mv2_runner.cproject.yml.
  • “Memory allocation failed: 1505280B requested”: The temp allocator pool is too small. The Ethos-U85 scratch buffer needs approximately 1.44 MB. Verify TEMP_ALLOC_POOL_SIZE is at least 1536 * 1024.
  • MRAM overflow linker error: Verify APP_MRAM_HP_SIZE is set to 0x00580000 in app_mem_regions.h.
  • “Vela bin ptr not aligned to 16 bytes”: The model array in the header needs __attribute__((aligned(16))).
This completes the setup and deployment of MobileNetV2 image classification on the Ethos-U85 NPU using ExecuTorch. The model went from PyTorch, through the Vela compiler, into a .pte flatbuffer embedded in firmware, and produced a correct classification result on real hardware.
What you’ve learned
You’ve successfully deployed a complete machine learning inference pipeline on the Alif Ensemble E8 DevKit. You compiled a MobileNetV2 model for the Ethos-U85 NPU, configured the firmware memory layout, integrated ExecuTorch libraries, and verified that the model correctly classifies ImageNet categories using real-time inference on the Arm Cortex-M55 microcontroller.
