Why an Arm cloud instance?
ExecuTorch’s Arm backend build scripts are designed for native Arm compilation. The Vela compiler, which generates optimized command streams for Ethos-U NPUs, and the CMSIS-NN kernels all target Arm natively. Using an Arm-based EC2 instance avoids the complexity of cross-compilation from x86.
In this section, you launch a Graviton-based EC2 instance, install ExecuTorch, compile a MobileNetV2 model for the Ethos-U85, and build the ExecuTorch static libraries that your firmware links against.
Launch an EC2 instance
Create an AWS EC2 instance with the following configuration:
  • Instance type: c7g.4xlarge (Arm Graviton3, 16 vCPUs, 32 GB RAM)
  • OS: Ubuntu 22.04 LTS
  • Storage: 50 GB
The 16 cores speed up the ExecuTorch build significantly, and the 50 GB disk accommodates the repository, submodules, and build artifacts.
SSH to the EC2 instance.
Install system dependencies
Connect to your instance and install the required packages:
sudo apt update && sudo apt upgrade -y
sudo apt install -y \
  git \
  cmake \
  ninja-build \
  build-essential \
  python3.10 \
  python3.10-venv \
  python3-pip \
  unzip \
  wget \
  rsync
Reboot if the kernel was updated:
sudo reboot
After reconnecting, verify that Python 3.10 is available:
python3 --version
The output is similar to:
        Python 3.10.12
Set up the Python environment
Create an isolated Python environment and install PyTorch:
python3 -m venv ~/venv_executorch
source ~/venv_executorch/bin/activate
pip install --upgrade pip setuptools wheel ninja cmake
pip install pyyaml
pip install torch torchvision --index-url https://download.pytorch.org/whl/cpu
pip install pillow
This instance has no GPU, so the install uses CPU-only PyTorch. PyTorch is only needed for model export and ahead-of-time compilation. The actual inference runs on the microcontroller.
Verify the installation:
python - <<'PY'
import torch, torchvision
print(torch.__version__, torchvision.__version__)
PY
        2.10.0+cpu 0.25.0+cpu
Clone and install ExecuTorch
Clone the ExecuTorch repository and pin it to a known-working commit:
mkdir -p ~/alif
cd ~/alif
git clone https://github.com/pytorch/executorch.git
cd executorch
git checkout 40d94b6d62a195a2f46b2baa20383fa4af27f7d4
git submodule update --init --recursive
Note
The git checkout command pins ExecuTorch to a known-working commit. The Arm backend and Vela toolchain integration can change between commits, so pinning avoids unexpected breakage.
Install the ExecuTorch Python package:
python -m pip install -e . --no-build-isolation
Set up the Arm/Ethos-U toolchain
ExecuTorch includes a setup script that downloads the Arm GNU toolchain, CMSIS, and the Vela compiler:
./examples/arm/setup.sh --i-agree-to-the-contained-eula
The script fails at the tosa_serialization_lib build step due to a pybind11 version incompatibility. This is a known issue. When you see an error containing def_property family doesn't currently support keep_alive, fix the dependency and complete the setup manually.
First, install a compatible version of pybind11 and the required build tools:
pip install "pybind11<2.14" scikit-build-core setuptools_scm
Next, build and install the serialization library using those local packages:
CMAKE_POLICY_VERSION_MINIMUM=3.5 pip install --no-build-isolation \
  --no-dependencies \
  ~/alif/executorch/examples/arm/arm-scratch/tosa-tools/serialization
Then install the Ethos-U Vela compiler, which the setup script didn’t reach due to the earlier failure:
pip install --no-dependencies \
  -r ~/alif/executorch/backends/arm/requirements-arm-ethos-u.txt
Re-run the setup script to complete the remaining steps:
Source the environment paths that the setup script generated:
source examples/arm/arm-scratch/setup_path.sh
After the setup script, reinstall ExecuTorch and its dependencies:
pip install "torchao==0.15.0"
Compile MobileNetV2 for Ethos-U85
Run the ahead-of-time compiler:
mkdir -p ~/alif/models
python -m examples.arm.aot_arm_compiler \
  -m mv2 \
  -q \
  -d \
  -t ethos-u85-256 \
  -o ~/alif/models/mv2_ethosu85_256.pte
The flags are:
  • -m mv2: MobileNetV2 model
  • -q: quantize the model (int8)
  • -d: delegate computation to the NPU
  • -t ethos-u85-256: target the Ethos-U85 with 256 MAC configuration
  • -o: output path for the compiled .pte file
Verify the output:
ls -lh ~/alif/models/mv2_ethosu85_256.pte
The file should be approximately 3.7 MB. This .pte file contains the model graph, quantized weights, and the Vela-compiled command stream that the Ethos-U85 executes directly.
Build ExecuTorch static libraries
Your firmware needs to link against ExecuTorch’s runtime libraries. Build them for bare-metal Cortex-M:
cd ~/alif/executorch
rm -rf cmake-out
bash backends/arm/scripts/build_executorch.sh
This step takes several minutes. When complete, list the output libraries:
find arm_test/cmake-out -type f -name "*.a" | sort
The output lists approximately 13 libraries, including libexecutorch.a, libexecutorch_core.a, libexecutorch_delegate_ethos_u.a, libcortex_m_ops_lib.a, and libcmsis-nn.a.
Package headers and libraries
Bundle the headers and libraries for transfer to your development machine:
rm -rf ~/alif/et_bundle
mkdir -p ~/alif/et_bundle
cp -a arm_test/cmake-out/include ~/alif/et_bundle/
cp -a arm_test/cmake-out/lib     ~/alif/et_bundle/
tar -C ~/alif -czf ~/alif/et_bundle.tar.gz et_bundle
ls -lh ~/alif/et_bundle.tar.gz
Transfer artifacts to your development machine
Run these commands on your development machine, not on the EC2 instance. The paths below use ~/alif/ as the working directory; adjust these to match your own project location:
mkdir -p ~/alif/third_party/executorch/lib
scp alif:/home/ubuntu/alif/models/mv2_ethosu85_256.pte ~/alif/models/
scp alif:/home/ubuntu/alif/et_bundle.tar.gz ~/alif/models/
scp 'alif:/home/ubuntu/alif/executorch/arm_test/cmake-out/lib/*.a' \
  ~/alif/third_party/executorch/lib/
Verify the transfer:
ls ~/alif/third_party/executorch/lib/*.a | wc -l
The output shows the 3.7 MB model file and 13 library files.
Convert the model to a C header
The firmware embeds the model as a byte array in flash memory. Use xxd to generate a C header:
cd ~/alif/models
xxd -i mv2_ethosu85_256.pte > mv2_ethosu85_256_pte.h
Open mv2_ethosu85_256_pte.h and change the first line from:
unsigned char mv2_ethosu85_256_pte[] = {
to:
#include <stdint.h>
const uint8_t __attribute__((aligned(16))) mv2_ethosu85_256_pte[] = {
The aligned(16) attribute is required because the Ethos-U85 needs the Vela command stream data aligned to 16 bytes. Without it, the NPU driver will report an alignment error at runtime.
Extract the header bundle
On your development machine, extract the ExecuTorch headers into the VS Code template project:
cd ~/alif/alif_vscode-template
mkdir -p third_party/executorch
tar -C third_party/executorch -xzf ~/alif/models/et_bundle.tar.gz
Verify the headers are in place:
ls third_party/executorch/et_bundle/include/executorch/
You should see runtime/ and other directories.
You now have the compiled model, prebuilt libraries, and headers on your development machine, ready to integrate into the firmware project.
You’ve compiled the MobileNetV2 model for the Ethos-U85 NPU, built ExecuTorch static libraries for bare-metal Cortex-M55, and transferred the artifacts to your development machine.
Next, you’ll create the CMSIS firmware project and integrate the ExecuTorch libraries.
