Give feedback
AI-assisted
Close
Which core should I target when flashing and debugging the firmware?
Use the Cortex-M55 High-Performance (HP) core to orchestrate inference on the Ethos-U85. The steps assume this core for building, flashing, and running the application.
What artifacts should I expect after compiling on the Arm cloud instance?
You’ll have ExecuTorch static libraries and a compiled MobileNetV2 model targeted for the Ethos-U85. These outputs are linked into the mv2_runner firmware project.
After duplicating the Blinky example, which project files need to be updated?
Rename blinky.cproject.yml to mv2_runner.cproject.yml and replace internal references from blinky to mv2_runner. This establishes a new CMSIS project for the application.
Where do I place the provided `main.cpp` and how do I verify it works?
Place main.cpp in the mv2_runner project directory as instructed. When you flash and run the firmware, check the SEGGER RTT console for the printed classification result.
What memory changes are required for the model and runtime to fit?
Increase MRAM allocation for the embedded model (about 3.7 MB) and code (around 800 KB), and provision approximately 7.6 MB of SRAM for inference buffers. Update stack and heap sizes, and the linker script in the CMSIS project accordingly.
Return to Embedded and Microcontrollers
