Run parallel vision inference on an Alif Ensemble E8 with Zephyr
Understand the dual-NPU architecture
Prepare the board and workspace
Build the dual-NPU application
Package and flash the application
Validate live parallel inference
Define the build inputs
The sample application includes compiled PTE models for Ethos-U55 and Ethos-U85. It also includes a startup image that verifies both inference pipelines before the application starts the live camera.
Start by defining build inputs.
From the west workspace root, activate the Python environment and define the sample paths:
cd $HOME/alif-dual-npu
source .venv/bin/activate
APP=$PWD/sdk-alif/samples/modules/executorch/dual_npu_vision
OD=$PWD/sdk-alif/samples/modules/tflite-micro/alif_object_detection
MODULES=$(west list -f '{abspath}' | grep -v '/modules/lib/executorch$' | paste -sd';' -)
MODULES="$MODULES;$PWD/modules/lib/executorch;$PWD/modules/ethos-u-core-driver-src"
The overlay order is important. The final isp_route.overlay file disables the CPI memory endpoint and routes camera frames exclusively through the image signal processor (ISP).
If the ISP reports that it has no empty video buffer, confirm that isp_route.overlay is the final device-tree overlay in the build command. The application circulates five buffers and must return each processed buffer to the ISP queue. Don’t remove the ISP configuration fragments from vision.conf.
Build the firmware
Run the complete build command:
west build \
-b alif_e8_dk/ae822fa0e5597xx0/rtss_hp \
-d build-dual-npu-vision \
"$APP" --pristine -- \
-DZEPHYR_MODULES="$MODULES" \
-DPYTHON_EXECUTABLE="$PWD/.venv-executorch/bin/python" \
-DPython3_EXECUTABLE="$PWD/.venv-executorch/bin/python" \
-DCMSIS_NN_LOCAL_PATH="$PWD/modules/cmsis-nn-src" \
-DDTC_OVERLAY_FILE="$APP/boards/dual_npu_e8.overlay;$OD/boards/alif_e8_dk_ae822fa0e5597xx0_rtss_hp.overlay;$OD/serial_camera.overlay;$OD/serial_camera_mt9m114.overlay;$OD/serial_camera_isp.overlay;$OD/serial_camera_mt9m114_isp.overlay;$APP/isp_route.overlay" \
-DOVERLAY_CONFIG="$APP/vision.conf"
A successful build ends with messages showing that Zephyr linked the ELF file and generated the binary.
Confirm that the three expected outputs exist:
ls -lh build-dual-npu-vision/zephyr/zephyr.bin \
build-dual-npu-vision/zephyr/zephyr.elf \
build-dual-npu-vision/model_assets.bin
The files have the following roles:
| File | Purpose |
zephyr.bin | Cortex-M55 Zephyr application |
zephyr.elf | Symbols and debug information |
model_assets.bin | U85 PTE, U55 PTE, startup image, and ImageNet labels |
You can use the checked-in PTE files to build and flash the application without installing TensorFlow, TOSA Tools, or Vela. CMake packages those files directly into model_assets.bin.
If model preparation reports an allocation failure, the PTE files don’t match the memory-pool sizes in the checked-out sample. Confirm that the workspace is at the validated SDK revision and run a pristine build.
If you regenerated the PTE files, use the supplied scripts, model inputs, and ensemble_vela.ini file.
(Optional) Regenerate the PTE models
Skip this section unless you want to reproduce or modify the model artifacts. Use a Linux development host for the optional model-generation flow.
The pinned Vela 5.0.0 and TOSA Tools 2026.2.1 packages declare different FlatBuffers versions. Install the validated combination with the supplied helper. It keeps Vela’s FlatBuffers 24.3.25 and installs TOSA Tools without resolving its conflicting FlatBuffers dependency:
"$APP/tools/install_model_export_deps.sh"
Create a directory for the source weights:
mkdir -p model-weights
Download the trained SSD-Slim int8 model and the official torchvision MobileNetV2 checkpoint . The SSD URL is pinned to the commit that added the model:
curl -L \
https://raw.githubusercontent.com/emza-vs/ModelZoo/59fcdb2aab865a8a8d93a9d419b3c5490a5508e4/Models/Object_detection/SSD/ssd_slim_120x160x1_v1_int8.tflite \
-o model-weights/ssd_slim_120x160x1_v1_int8.tflite
curl -L \
https://download.pytorch.org/models/mobilenet_v2-7ebf99e0.pth \
-o model-weights/mobilenet_v2-7ebf99e0.pth
Verify both downloads before using them:
echo "64fcc31aa517798d0e798551418c85bc0a5ed03a75c45c4e47fc7ee41e5ea51f model-weights/ssd_slim_120x160x1_v1_int8.tflite" | shasum -a 256 -c -
echo "7ebf99e03e254b273379b23edca7ec0da9f48273b23a332b93c1c99d49e86e8f model-weights/mobilenet_v2-7ebf99e0.pth" | shasum -a 256 -c -
The SSD source repository doesn’t publish a PyTorch checkpoint. Use the sample’s importer to convert the trained, quantized constants into the common PyTorch checkpoint:
.venv-executorch/bin/python \
"$APP/tools/import_ssd_slim_tflite.py" \
--source model-weights/ssd_slim_120x160x1_v1_int8.tflite \
--output model-weights/ssd_slim_common.pth
Generate both PTE files with the Alif Vela configuration included in the SDK:
"$APP/tools/generate_pte_models.sh" \
"$PWD/sdk-alif/samples/modules/executorch/ensemble_vela.ini" \
"$PWD/model-weights/ssd_slim_common.pth" \
"$PWD/model-weights/mobilenet_v2-7ebf99e0.pth"
The script emits comparable_ssd_slim_u55.pte and mobilenet_v2_imagenet_u85.pte in the sample’s models directory. The export uses PT2E quantization, deterministic representative inputs, the ExecuTorch Ethos-U partitioner, and Vela. Both programs expose int8 tensors and require complete delegation, with no Cortex-M fallback operators. The SSD checkpoint is produced by the supplied offline weight-import tool. Both deployed files are native ExecuTorch PTE programs.
You’ve built the dual-NPU application and optionally regenerated the PTE models.
Next, you’ll package and flash the application.
