Give feedback
AI-assisted
Close
How do I know the FVP ASR application ran correctly before moving to the E8 board?
Check that the FVP console identifies the audio sample and prints a Decoded output: line with recognized text. You can then move on to the E8 build.
Which application do I build for the E8 and which core does it target?
Select the Alif MLEK alif_asr application with -DUSE_CASE_BUILD=alif_asr, then build the mlek_alif_asr target. You deploy it to the E8’s high-performance Cortex-M55 subsystem.
Which build option selects the Ethos-U85 NPU for the E8 firmware?
Set -DETHOS_U_NPU_ID=U85 when you configure the E8 firmware. You can check for nonzero NPU ACTIVE and NPU TOTAL counters in the UART log after inference.
What should I set up on the E8 before opening the serial console, and what settings do I use?
Keep the PRG USB cable connected and set SW4 to UART4. Open the board’s serial port at 115200 baud, eight data bits, no parity, and one stop bit. If the port was already open when you changed SW4, close and reopen it.
How do I know the E8 is ready to capture speech, and how do I record a phrase?
Press RESET (SW1) and wait for Model initialisation complete in the UART log and Conformer ASR (ExecuTorch) on the display. Hold down the joystick center while you speak, then release it. Check the display for a transcription and the console for a Decoded output: line.
Return to Embedded and Microcontrollers
