# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/)
- [Setup a Workspace in Xilinx Vivado](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/setup/)
- [Create a custom AXI4 Peripheral](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/creating_peripheral/)
- [Connect AXI4 Peripheral to ZYNQ Processing System](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/connecting_peripheral/)
- [Generate the bitstream and write your application using Vitis IDE](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/generating_bitstream/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/_next-steps/)
## Design an AXI-Lite peripheral to control GPIOs
### [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/)
### [Setup a Workspace in Xilinx Vivado](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/setup/)
### [Create a custom AXI4 Peripheral](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/creating_peripheral/)
### [Connect AXI4 Peripheral to ZYNQ Processing System](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/connecting_peripheral/)
### [Generate the bitstream and write your application using Vitis IDE](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/generating_bitstream/)
### [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/_next-steps/)
## Share
Bring your insights to the conversation.
## Give Feedback
What is the primary reason for your feedback?
- Missing information
- Too complicated / unclear steps
- Code problems
- Out of date
- Easy to understand
- Solved my problem
- Excellent code snippets
Thank you! We're grateful for your feedback.
- Have more feedback? [Log an issue on GitHub.](https://github.com/ArmDeveloperEcosystem/arm-learning-paths/issues/new?title=Feedback%20-%20Design%20an%20AXI-Lite%20peripheral%20to%20control%20GPIOs)
- Want to collaborate? [Join our Discord server.](https://discord.com/invite/armsoftwaredev)
## Continue Learning
### Read related resources
- [Zybo Z7 10 Documentation](https://digilent.com/shop/zybo-z7-zynq-7000-arm-fpga-soc-development-board/)
### Join the Arm Developer Program
Connect, upskill, and build with the Arm Developer Community. Join today for hands-on technical resources and education materials, along with the support of Arm engineers and the broader ecosystem.
### Login to Arm Account
Login to your Arm Account to access personalized features.
