Build scalable communication systems with Eclipse Zenoh
Get started with Zenoh on Raspberry Pi and Arm Linux
Containerize and deploy Zenoh across multiple Raspberry Pi devices
Run a simple Zenoh pub/sub example
Run a Zenoh storage and query example
Run a Zenoh queryable node for on-demand edge computation
Run a Zenoh queryable with parameterized Rust computation
This example demonstrates how to use Zenoh’s real-time publish/subscribe model to exchange messages between two Raspberry Pi devices over a local network.
Pub/sub is a core Zenoh communication pattern where data producers (publishers) send values to a key, and data consumers (subscribers) receive updates for matching key expressions. In this case, the subscriber listens for all messages published under the key expression demo/example/**, which matches any topic that begins with demo/example/. This enables flexible topic filtering and lightweight data dissemination across distributed systems.
Run the subscriber example on one of the Raspberry Pi systems:
cd ~/zenoh/target/release/examples
./z_sub
Then, log in to the other Raspberry Pi and run the publisher:
./z_pub
You can run both z_sub and z_pub on the same device for testing, but running them on separate Raspberry Pis demonstrates Zenoh’s distributed discovery and cross-node communication.
The results are shown below:
Simple Pub/Sub
The left-side window shows the z_sub program. It receives values with the key demo/example/zenoh-rs-pub continuously published by z_pub running in the right-side window.
This example confirms that Zenoh’s zero-configuration peer discovery and real-time pub/sub communication are working correctly across physical nodes.
