Build scalable communication systems with Eclipse Zenoh
Get started with Zenoh on Raspberry Pi and Arm Linux
Containerize and deploy Zenoh across multiple Raspberry Pi devices
Run a simple Zenoh pub/sub example
Run a Zenoh storage and query example
Run a Zenoh queryable node for on-demand edge computation
Run a Zenoh queryable with parameterized Rust computation
After building Zenoh and its core examples, the next step is to deploy them across multiple Arm-based devices.
If you’ve already installed Zenoh on an Arm Cortex-A or Neoverse platform as shown in the previous section, you can copy the compiled binaries from ~/zenoh/target/release/ to each of your Raspberry Pi devices.
To simplify and scale deployment across multiple devices, this section shows how to containerize Zenoh with Docker for streamlined distribution and consistent multi-node testing. This containerized approach enables repeatable rollouts and makes it easier to test distributed communication across Raspberry Pi, Arm cloud instances (like AWS Graviton), and Arm Virtual Hardware.
In this session, you’ll use Raspberry Pi boards to simulate a scalable distributed environment. The same workflow applies to any Arm Linux system, including cloud instances and virtual hardware. This setup allows you to simulate real-world, cross-node communication scenarios, making it ideal for evaluating Zenoh’s performance in robotics and industrial IoT applications. This setup simulates real-world, cross-node communication scenarios, making it ideal for robotics and industrial IoT applications that require fast, decentralized messaging using pub/sub, storage, and query models.
To simplify this process and ensure consistency, you can use Docker to containerize your Zenoh and ROS 2 environment. This lets you quickly replicate the same runtime on any device without needing to rebuild from source.
This enables scalable, multi-node testing in realistic distributed environments.
First, install Docker on each Raspberry Pi device:
curl -fsSL get.docker.com -o get-docker.sh && sh get-docker.sh
sudo usermod -aG docker $USER ; newgrp docker
To ensure compatibility with ROS-related tools, create a Dockerfile based on ros:galactic , and use the official Rust installation method to build Zenoh, as shown below.
This Dockerfile uses a multi-stage build process based on the ros:galactic environment. In the first stage, it installs Rust and compiles the Zenoh binaries directly from source. In the second stage, it installs essential ROS 2 demo tools and copies the Zenoh executables into the final runtime image.
# Stage 1: Build Zenoh using ROS base with Rust toolchain
FROM ros:galactic AS builder
RUN apt-get update && apt-get install -y \
curl \
git \
build-essential \
pkg-config \
clang \
libssl-dev \
cmake
RUN curl -sSf https://sh.rustup.rs -o rustup-init.sh && \
chmod +x rustup-init.sh && \
./rustup-init.sh -y --no-modify-path && \
rm rustup-init.sh
ENV PATH="/root/.cargo/bin:${PATH}"
WORKDIR /root
RUN git clone https://github.com/eclipse-zenoh/zenoh.git
WORKDIR /root/zenoh
RUN cargo build --release --all-targets -j $(nproc)
# Stage 2: Runtime with ROS + Zenoh binary only
FROM ros:galactic AS runtime
ros-galactic-demo-nodes-cpp \
ros-galactic-rmw-cyclonedds-cpp \
ros-galactic-turtlesim
COPY --from=builder /root/zenoh/target/release /root/zenoh/target/release
ENV RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
WORKDIR /root/zenoh/target/release
CMD ["/bin/bash"]
From the directory containing the above Dockerfile, run the following command to generate the docker image:
docker build -t zenoh-node .
After this has been done, the created ROS 2 Docker image can be seen by the following command.
docker images | grep zenoh-node
REPOSITORY TAG IMAGE ID CREATED SIZE
zenoh-node latest 2300ea78d043 30 minutes ago 3.73GB
Alternatively, if you’d like to skip the build process, a pre-built Docker image is available on Docker Hub. You can pull it directly using:
docker pull odinlmshen/zenoh-node
Once built, you can reuse this Docker image across multiple Arm-based nodes, including Raspberry Pi, AWS Graviton, and Arm Virtual Hardware.
There are two options to transfer the Docker image to your second device. Choose one of the following methods.
docker save zenoh-node > zenoh-node.tar
scp zenoh-node.tar pi@<target_ip>:/home/pi/
On the target device:
docker load < zenoh-node.tar
You can also push the image to Docker Hub or GitHub Container Registry and pull it on the second device.
Once the image is successfully loaded on the second device, you can run the container to start the Zenoh environment.
docker run -it --network=host zenoh-node
The Zenoh example binaries are now available within this container, allowing you to test pub/sub and query flows across devices.
With Zenoh running inside containers across devices, you’re now ready to explore real-time communication using prebuilt examples.
The following examples are written in Rust and precompiled in your container image. They’re fully interoperable and can be used to demonstrate Zenoh’s key capabilities across devices. The Rust binaries are available in the $ZENOH_LOC/target/release/examples/ directory. If you haven’t set ZENOH_LOC, they can be found under ~/zenoh/target/release/examples/.
The following sections illustrate the procedures to run the Zenoh examples so as to demonstrate the primary capabilities of Zenoh:
With your Zenoh examples running across containers, you’re now ready to build and benchmark real-time communication flows across nodes, which is ideal for simulating robotic fleets or industrial systems.
