Build scalable communication systems with Eclipse Zenoh
Get started with Zenoh on Raspberry Pi and Arm Linux
Containerize and deploy Zenoh across multiple Raspberry Pi devices
Run a simple Zenoh pub/sub example
Run a Zenoh storage and query example
Run a Zenoh queryable node for on-demand edge computation
Run a Zenoh queryable with parameterized Rust computation
This section shows you how to install and build the open-source Eclipse Zenoh protocol on Arm-based devices like Raspberry Pi.
The following instructions have been verified on Raspberry Pi 4 and 5, but you can use any Arm Linux device. These steps apply to Raspberry Pi and other Arm-based Linux platforms. Before building Zenoh, make sure your system has the necessary development tools and runtime libraries.
First, install the Rust environment. The core of Zenoh is developed in Rust for performance and safety.
sudo apt update
sudo apt install -y curl gcc
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh -s -- -y
Near the end of the installation, you should see the message:
Rust is installed now. Great!
Source your shell environment to activate Rust:
source "$HOME/.cargo/env"
For more information, see the Rust Install Guide for Arm Linux.
Robot Operating System is a set of software libraries and tools that help you build robot applications. ROS provides everything from drivers to state-of-the-art algorithms, as well as developer tools. It is completely open-source.
If you plan to use Zenoh alongside ROS 2, for example, to bridge DDS-based nodes, you should install ROS 2 before proceeding. See the ROS2 Installation Guide to install ROS 2 on your Arm platforms.
Clone the Zenoh repository:
cd $HOME
git clone https://github.com/eclipse-zenoh/zenoh.git
Build the source using Cargo:
cd zenoh
cargo build --release --all-targets -j $(nproc)
This process will take several minutes depending on your device. When complete, you should see output like:
Updating crates.io index
Downloaded humantime v2.2.0
Downloaded spin v0.10.0
Downloaded crossbeam-channel v0.5.14
Downloaded uhlc v0.8.1
Downloaded 4 crates (182.5 KB) in 2.19s
warning: output filename collision.
The lib target `zenoh_plugin_storage_manager` in package `zenoh-plugin-storage-manager v1.4.0 (/home/ubuntu/zenoh/plugins/zenoh-plugin-storage-manager)` has the same output filename as the lib target `zenoh_plugin_storage_manager` in package `zenoh-plugin-storage-manager v1.4.0 (/home/ubuntu/zenoh/plugins/zenoh-plugin-storage-manager)`.
Colliding filename is: /home/ubuntu/zenoh/target/release/deps/libzenoh_plugin_storage_manager.so
The targets should have unique names.
Consider changing their names to be unique or compiling them separately.
This may become a hard error in the future; see <https://github.com/rust-lang/cargo/issues/6313>.
Colliding filename is: /home/ubuntu/zenoh/target/release/deps/libzenoh_plugin_storage_manager.so.dwp
Colliding filename is: /home/ubuntu/zenoh/target/release/deps/libzenoh_plugin_storage_manager.rlib
Compiling proc-macro2 v1.0.86
Compiling unicode-ident v1.0.13
Compiling libc v0.2.158
Compiling version_check v0.9.5
Compiling autocfg v1.3.0
Compiling zenoh-link-quic v1.4.0 (/home/ubuntu/zenoh/io/zenoh-links/zenoh-link-quic)
Compiling zenoh_backend_traits v1.4.0 (/home/ubuntu/zenoh/plugins/zenoh-backend-traits)
Compiling zenoh-plugin-storage-manager v1.4.0 (/home/ubuntu/zenoh/plugins/zenoh-plugin-storage-manager)
Compiling zenoh-ext v1.4.0 (/home/ubuntu/zenoh/zenoh-ext)
Compiling zenoh-ext-examples v1.4.0 (/home/ubuntu/zenoh/zenoh-ext/examples)
Compiling zenoh-plugin-example v1.4.0 (/home/ubuntu/zenoh/plugins/zenoh-plugin-example)
Compiling zenoh-backend-example v1.4.0 (/home/ubuntu/zenoh/plugins/zenoh-backend-example)
Finished `release` profile [optimized] target(s) in 6m 28s
After the build process, the binary executables will be located at ~/zenoh/target/release/examples/.
Installation time can vary depending on your device’s performance.
If you get a build error like this:
error[E0599]: no function or associated item named `start` found for struct `StoragesPlugin` in the current scope
--> plugins/zenoh-plugin-storage-manager/tests/operations.rs:91:55
Edit the file ./plugins/zenoh-plugin-storage-manager/tests/operations.rs and comment the line shown below and add the second line to the file:
//use zenoh_plugin_trait::Plugin;
use crate::path::to::Plugin;
Then rebuild:
cargo clean && cargo build
With Zenoh successfully compiled, you’re ready to explore how nodes communicate using the Zenoh runtime.
