Build scalable communication systems with Eclipse Zenoh
Get started with Zenoh on Raspberry Pi and Arm Linux
Containerize and deploy Zenoh across multiple Raspberry Pi devices
Run a simple Zenoh pub/sub example
Run a Zenoh storage and query example
Run a Zenoh queryable node for on-demand edge computation
Run a Zenoh queryable with parameterized Rust computation
Modern robotics and industrial IoT systems are evolving rapidly, from indoor collaborative arms on assembly lines to fleets of outdoor autonomous delivery robots. These applications must operate in real-time, often across multiple compute nodes, over networks that may span factory LANs, 5G cellular links, or even cloud data centers.
Such systems require fast, reliable, and scalable data communication between nodes. This includes not just broadcasting sensor updates or actuator commands (pub/sub), but also performing state queries, storing values for later use, and even distributed computation across nodes.
A modern protocol must be:
Traditional communication stacks such as Data Distribution Service (DDS) serve as the backbone for middleware like ROS 2. However, DDS struggles in multi-network or wireless environments where multicast is unavailable, or NAT traversal is needed. Zenoh was developed to address these challenges with a unified approach to data movement, storage, and interaction across heterogeneous, distributed systems.
Eclipse Zenoh is a modern, open-source, data-centric communication protocol that goes beyond traditional pub/sub. Designed specifically for edge computing, industrial IoT, robotics, and autonomous systems, Zenoh unifies:
Unlike most traditional stacks, Zenoh is fully decentralized and designed to operate across cloud-to-edge-to-thing topologies, making it ideal for industrial robotics, autonomous systems, and smart environments.
It supports heterogeneous platforms, is implemented in Rust for performance and safety, and also offers bindings for Python, enabling rapid prototyping.
Zenoh excels in wireless, 5G, and cross-network deployments, which are environments where multicast is unavailable and DDS often struggles. Its routing engine avoids excessive discovery traffic, conserves bandwidth, and supports seamless bridging between legacy ROS 2/DDS apps and modern, optimized Zenoh networks using Zenoh-Bridge-DDS, a bridge between DDS systems and Zenoh networks.
In this Learning Path, you’ll use Zenoh to build and validate a multi-node distributed communication system across multiple Arm-based platforms, gaining hands-on experience with data exchange and coordination between edge devices.
You can substitute Raspberry Pi with any Linux-based Arm device that supports networking, such as a Cortex-A or Neoverse board.
By the end of this Learning Path, you’ll be able to:
