# WindowsPerf Record using SPE
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/windowsperf_sampling_cpython_spe/)
- [Overview of Arm Statistical Profiling Extension](https://learn.arm.com/learning-paths/cross-platform/windowsperf_sampling_cpython_spe/overview/)
- [Setup](https://learn.arm.com/learning-paths/cross-platform/windowsperf_sampling_cpython_spe/windowsperf_sampling_cpython_spe/)
- [WindowsPerf Sample using SPE](https://learn.arm.com/learning-paths/cross-platform/windowsperf_sampling_cpython_spe/windowsperf_sampling_cpython_spe_example_1/)
- [WindowsPerf Record using SPE](https://learn.arm.com/learning-paths/cross-platform/windowsperf_sampling_cpython_spe/windowsperf_sampling_cpython_spe_example_2/)
- [Summary](https://learn.arm.com/learning-paths/cross-platform/windowsperf_sampling_cpython_spe/summary/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/windowsperf_sampling_cpython_spe/_next-steps/)
## Record CPython using SPE
You can use the `record` command to spawn the Python process and pin it to the core specified by the `-c` option.
A double-dash (`--`) syntax in shell commands signifies the end of command options and beginning of positional arguments.
This means that it separates the `wperf` CLI options from the arguments passed to the profiled program called `python_d.exe`.
Run the `record` command with SPE to collect load events from SPE:
```bash
wperf record -e arm_spe_0/ld=1/ -c 1 --timeout 5 -- cpython\PCbuild\arm64\python_d.exe -c 10**10**100
You can use the same `--annotate` and `--disassemble` command line arguments with the SPE extension.
The WindowsPerf `record` command is versatile, allowing you to start and stop the sampling process easily. It also simplifies the command-line syntax, making it user-friendly and efficient.
The example above can be replaced by these two commands:
```bash
start /affinity 2 cpython\PCbuild\arm64\python_d.exe -c 10**10**100
wperf sample -e arm_spe_0/ld=1/ --pe_file cpython\PCbuild\arm64\python_d.exe --image_name python_d.exe -c 1
