To test the profiling capabilities, you can stress CPython by using the CPython binary that you built from source in debug mode to compute a large integer number called a Googolplex .
To do this, follow these steps:
python_d.exe interactive console to an arbitrary CPU core, and calculate 10^10^100.Start by using the Windows start command to execute and pin python_d.exe process to CPU core 1.
Run the command below at a Windows Command Prompt to execute the computation intensive calculation:
start /affinity 2 cpython\PCbuild\arm64\python_d.exe -c 10**10**100
The
start
command line /affinity <hexaffinity> applies the specified processor affinity mask (expressed as a hexadecimal number). In this example, decimal 2 is 0x02 or 0b0010. This value denotes core number 1 as 1 is a second bit in the mask, where the mask is indexed from 0.
You can use the Windows Task Manager to confirm that python_d.exe is running on CPU core 1.
You can specify SPE filters using the -e command line option with arm_spe_0//.
The arm_spe_0/*/ notation is available for the sample and record commands, where * represents a comma-separated list of supported filters.
Currently, filters such as store_filter=, load_filter=, and branch_filter=, or their short equivalents like st=, ld=, and b=, use 0 or 1 to disable or enable a given filter.
Here are some filter examples:
arm_spe_0/branch_filter=1/
arm_spe_0/load_filter=1,branch_filter=0/
arm_spe_0/ld=1,branch_filter=0/
arm_spe_0/st=0,ld=0,b=1/
The SPE register, PMSFCR_EL1.FT, enables filtering by operation type.
When enabled, PMSFCR_EL1.{ST, LD, B} defines the collected types:
ST enables collection of store-sampled operations, including all atomic operations.LD enables collection of load-sampled operations, including atomic operations that return a value to a register.B enables collection of branch-sampled operations, including direct and indirect branches and exception returns.The command below samples the running python_d.exe process.
The SPE filter ld=1 enables collection of load sampled operations, including atomic operations that return a value to a register.
wperf sample -e arm_spe_0/ld=1/ --pe_file cpython\PCbuild\arm64\python_d.exe --image_name python_d.exe -c 1
You can use the same sampling --annotate and --disassemble command line interface of WindowsPerf with the SPE extension. This is shown in the example output below.
It takes a few seconds for the samples to arrive from the Kernel driver. You can press Ctrl+C to stop sampling.
You will see an output similar to:
base address of 'python_d.exe': 0x7ff765fe1288, runtime delta: 0x7ff625fe0000
sampling ....eee....eCtrl-C received, quit counting... done!
Performance counter stats for core 1, no multiplexing, kernel mode excluded, on Arm Limited core implementation:
note: 'e' - normal event, 'gN' - grouped event with group number N, metric name will be appended if 'e' or 'g' comes from it
counter value event name event idx event note
29,337,387,738 cycle fixed e
76,433,491,476 sample_pop 0x4000 e
18 sample_feed 0x4001 e
7 sample_filtrate 0x4002 e
0 sample_collision 0x4003 e
======================== sample source: LOAD_STORE_ATOMIC-LOAD-GP/retired+level1-data-cache-access+tlb_access, top 50 hot functions ========================
overhead count symbol
85.71 6 x_mul:python312_d.dll
14.29 1 unknown
100.00% 7 top 2 in total
9.853 seconds time elapsed
You can close the command-line window running python_d.exe when you have finished sampling.
Sampling also automatically ends when the sampled process exits.
In the output above, you see that the majority of overhead generated by python_d.exe resides in the python312_d.dll DLL, in the x_mul symbol.
SPE sampling output also contains PMU events for the SPE-registered events.
Here are some helpful definitions:
sample_pop - Counts statistical profiling sample population, which is the count of all operations that can be sampled but might or might not be chosen for sampling.sample_feed - Counts statistical profiling samples taken.sample_filtrate - Counts statistical profiling samples taken which are not removed by filtering.sample_collision - Counts statistical profiling samples that have collided with a previous sample and therefore not taken.During sampling the ....eee....e output is a progressing printout where:
. character represents an SPE sample payload received from the WindowsPerf Kernel driver.e character represents an unsuccessful attempt - an empty SPE fill buffer - to fetch the whole sample payload.You can also generate wperf sample output in JSON format. Use the --json command-line option to enable the JSON output.
Use the -v command-line option verbose to add more information about sampling.
The --annotate command-line option enables translating addresses taken from samples in sample/record mode into source code line numbers.
For example:
wperf sample -e arm_spe_0/ld=1/ --annotate --pe_file cpython\PCbuild\arm64\python_d.exe --image_name python_d.exe -c 1
The output is similar to:
sampling ....ee.Ctrl-C received, quit counting...e done!
15,579,045,952 cycle fixed e
40,554,143,220 sample_pop 0x4000 e
10 sample_feed 0x4001 e
2 sample_filtrate 0x4002 e
line_number hits filename
3,590 2 C:\path\to\cpython\Objects\longobject.c
100.00 2 x_mul:python312_d.dll
100.00% 2 top 1 in total
5.199 seconds time elapsed
The above SPE sampling pass records that the function x_mul:python312_d.dll
in source file C:\path\to\cpython\Objects\longobject.c, line 3590 is a hot spot for the load_filter.
The --disassemble command-line option enables disassembly output, and also implies --annotate.
For example:
wperf sample -e arm_spe_0/ld=1/ --disassemble --pe_file cpython\PCbuild\arm64\python_d.exe --image_name python_d.exe -c 1
sampling ......eCtrl-C received, quit counting... done!
13,193,499,134 cycle fixed e
34,357,259,935 sample_pop 0x4000 e
4 sample_filtrate 0x4002 e
line_number hits filename instruction_address disassembled_line
3,591 2 C:\path\to\cpython\Objects\longobject.c 4043b4 address instruction
4043a8 ldr x8, [sp, #0x10]
4043ac and x8, x8, #0x3fffffff
4043b0 mov w8, w8
4043b4 ldr x9, [sp, #0x20]
4043b8 str w8, [x9]
4043bc ldr x8, [sp, #0x20]
4043c0 add x8, x8, #0x4
4043c4 str x8, [sp, #0x20]
3,589 1 C:\path\to\cpython\Objects\longobject.c 404360 address instruction
40435c ldr x9, [sp, #0x108]
404360 ldr x8, [sp, #0x58]
404364 cmp x8, x9
404368 b.hs 0x18040440c <_PyCrossInterpreterData_UnregisterClass+0x3fc680>
v_isub:python312_d.dll
1,603 1 C:\path\to\cpython\Objects\longobject.c 402a60 address instruction
402a60 ldr w8, [sp, #0x10]
402a64 and w8, w8, #0x1
402a68 str w8, [sp, #0x10]
75.00 3 x_mul:python312_d.dll
25.00 1 v_isub:python312_d.dll
100.00% 4 top 2 in total
4.422 seconds time elapsed
The output above shows that the function x_mul:python312_d.dll is a hot spot which comes from the following source code lines:
C:\path\to\cpython\Objects\longobject.c, line 3591, instruction ldr x9, [sp, #0x20] at address 0x4043b4 as potential hot-spot.C:\path\to\cpython\Objects\longobject.c, line 3589, instruction ldr x8, [sp, #0x58] at address 0x404360 as potential hot-spot.Another potential hot spot is in the function v_isub:python312_d.dll in the source file C:\path\to\cpython\Objects\longobject.c, line 1603, instruction ldr w8, [sp, #0x10] at address 0x402a60.
