Before trying any optimization, it’s important to understand the way the data is represented and accessed in memory. In this case, the compiler cannot issue SIMD instructions because the operations are done in triplets (x,y,z) and SIMD operations for 32-bit floating point values require 4 elements.
In order to improve the data layout and help the compiler, you need to go back and look at the object struct in more detail. The memory layout of object is the following:
Figure 1. struct object memory layout with vec3
As the vec3 types are triplets, their alignment is 3 x 4 bytes = 12 bytes. This makes usage of SIMD instructions difficult as they usually operate on data multiples of 16 bytes. Alignment to 16 bytes is also important. You can usually solve this by adding extra bytes in such structures as padding. This results in wasted bytes, but sometimes these can be used for extra information. Even if the extra bytes cannot be used, the performance benefit outweighs the loss in memory.
You may be wondering how padding should be added to the struct. You can convert the vec3 helper struct to a vec4 to include an extra ‘dimension’, such as t.
Make the following change to the code to add the padding:
// Helper struct of a 3D vector with x, y, z, coordinates
typedef struct vec4 {
float x, y, z, t;
} vec4_t;
You also need to change the object struct:
// The object struct
typedef struct object {
vec4_t position;
vec4_t velocity;
} object_t;
Also change the function init_objects() to initialize the new t member:
void init_objects(object_t *objects) {
// Give initial speeds and positions
for (size_t i=0; i < N; i++) {
objects[i].position.z = randf(20.0) - 10.0f;
objects[i].position.t = 0.0f;
objects[i].velocity.y = randf(2.0) - 1.0f;
objects[i].velocity.t = 1.0f;
Finally, update the simulate_objects() function:
void simulate_objects(object_t *objects, float duration, float step) {
while (current_time < duration) {
// Move the object in msec steps
objects[i].position.z += objects[i].velocity.z * step;
objects[i].position.t += objects[i].velocity.t * step;
current_time += step;
The memory layout now looks like this:
Figure 2. struct object memory layout with vec4
After making the changes, compile the code again:
gcc -O3 simulation1.c -o simulation1
Running the new program shows immediate improvement:
./simulation1
The new elapsed time is less than before:
elapsed time: 12.993359
Use objdump again to view the new assembly code for thesimulate_objects() function:
objdump -S simulation1 | less
The usage of SIMD instructions is obvious now. You can see that loading is done in quads ldp q0, q3, [x0], then fmla is used to do the step multiply-accumulate instruction and it stores the vector directly with str:
0000000000000b20 <simulate_objects>:
b20: 1e202018 fcmpe s0, #0.0
b24: 1e204004 fmov s4, s0
b28: 1e204025 fmov s5, s1
b2c: 4e040422 dup v2.4s, v1.s[0]
b30: 5400004c b.gt b38 <simulate_objects+0x18>
b34: d65f03c0 ret
b38: 91524c02 add x2, x0, #0x493, lsl #12
b3c: 91524c01 add x1, x0, #0x493, lsl #12
b40: 0f000401 movi v1.2s, #0x0
b44: 91002003 add x3, x0, #0x8
b48: 91376042 add x2, x2, #0xdd8
b4c: 91380021 add x1, x1, #0xe00
b50: aa0303e0 mov x0, x3
b54: d503201f nop
b58: ad400c00 ldp q0, q3, [x0]
b5c: 4e23cc40 fmla v0.4s, v2.4s, v3.4s
b60: 3c830400 str q0, [x0], #48
b64: eb00005f cmp x2, x0
b68: 54ffff81 b.ne b58 <simulate_objects+0x38> // b.any
b6c: 3cdd8020 ldur q0, [x1, #-40]
b70: 1e252821 fadd s1, s1, s5
b74: 3cde8023 ldur q3, [x1, #-24]
b78: 1e212090 fcmpe s4, s1
b7c: 4e23cc40 fmla v0.4s, v2.4s, v3.4s
b80: 3c9d8020 stur q0, [x1, #-40]
b84: 54fffe6c b.gt b50 <simulate_objects+0x30>
b88: d65f03c0 ret
Sometimes it’s easy to make data layout improvements. Continue to the next section for a more complex problem.
