# Structure of arrays
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/)
- [What exactly is data layout?](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/data-layout-basics/)
- [Improve data alignment](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/data-layout-basics-2/)
- [Increase complexity](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/a-more-complex-problem/)
- [Write hand optimized SIMD code](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/a-more-complex-problem-manual-simd/)
- [Structure of arrays](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/a-more-complex-problem-revisited/)
- [Migrate to the Scalable Vector Extension (SVE)](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/a-more-complex-problem-revisited-sve/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/vectorization-friendly-data-layout/_next-steps/)
As you have learned, changing data layout can improve performance.
The challenge is knowing what to change and understanding why it would matter. Another version of the program is shown below. You can study this version to learn about data layout.
Use a text editor to copy the code below and save it as `simulation4.c`:
```c
#include <stdint.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <sys/time.h>
#include <unistd.h>
#include <arm_neon.h>
#define N           100000 // number of particles
#define SECONDS     100    // duration in seconds
#define STEPSPERSEC 1000   // steps per second or time resolution
// The object struct
typedef struct object {
  uint32_t id;
  float weight;
  void *model_data;
} object_t;
struct object_list {
  object_t o[N];
  float x[N];
  float y[N];
  float z[N];
  float vx[N];
  float vy[N];
  float vz[N];
// Helper function to return a random float number from 0.0f to a.
float randf(float a) {
  return ((float)rand() / (float)(RAND_MAX)) * a;
const float box_hi[4] = { 10.0f, 10.0f, 10.0f, 10.0f };
void init_objects(struct object_list *objects) {
  // Give initial speeds and positions
  for (size_t i = 0; i < N; i++) {
    objects->o[i].id = i;
    objects->o[i].weight = randf(2.0f);
    // initial positions in box [-10, 10], velocity in [-1, 1]
    objects->x[i] = randf(2.0f * box_hi[0]) - box_hi[0];
    objects->y[i] = randf(2.0f * box_hi[1]) - box_hi[1];
    objects->z[i] = randf(2.0f * box_hi[2]) - box_hi[2];
    objects->vx[i] = randf(2.0) - 1.0f;
    //printf("vx[%ld] = %f\n", i, objects->vx[i]);
    objects->vy[i] = randf(2.0) - 1.0f;
    objects->vz[i] = randf(2.0) - 1.0f;
void simulate_objects(struct object_list *objects, float duration, float step) {
  float current_time = 0.0f;
  //size_t iterations = 0;
  float32x4_t s = vdupq_n_f32(step);
  uint32x4_t one = vdupq_n_u32(1);
  // Collision counters are now per axis
  uint32x4_t ctr_x = vdupq_n_u32(0);
  uint32x4_t ctr_y = vdupq_n_u32(0);
  uint32x4_t ctr_z = vdupq_n_u32(0);
  float32x4_t box_hi_v = vld1q_f32(box_hi);
  float32x4_t box_lo_v = vnegq_f32(box_hi_v);
  while (current_time < duration) {
    // Move 4 objects in each iteration
    for (size_t i = 0; i < N; i += 4) {
      float32x4_t x_v, y_v, z_v, vx_v, vy_v, vz_v;
      // Load the x,y,z and vx, vy, vz coords for 4 objects
      x_v = vld1q_f32(&objects->x[i]);
      y_v = vld1q_f32(&objects->y[i]);
      z_v = vld1q_f32(&objects->z[i]);
      vx_v = vld1q_f32(&objects->vx[i]);
      vy_v = vld1q_f32(&objects->vy[i]);
      vz_v = vld1q_f32(&objects->vz[i]);
      // Move the 4 objects in each axis
      x_v = vmlaq_f32(x_v, vx_v, s);
      y_v = vmlaq_f32(y_v, vy_v, s);
      z_v = vmlaq_f32(z_v, vz_v, s);
      vst1q_f32(&objects->x[i], x_v);
      vst1q_f32(&objects->y[i], y_v);
      vst1q_f32(&objects->z[i], z_v);
      // Calculate the gt/lt masks for each axis
      uint32x4_t gt_mask_x = vcgtq_f32(x_v, box_hi_v);
      uint32x4_t lt_mask_x = vcltq_f32(x_v, box_lo_v);
      uint32x4_t gt_mask_y = vcgtq_f32(y_v, box_hi_v);
      uint32x4_t lt_mask_y = vcltq_f32(y_v, box_lo_v);
      uint32x4_t gt_mask_z = vcgtq_f32(z_v, box_hi_v);
      uint32x4_t lt_mask_z = vcltq_f32(z_v, box_lo_v);
      // Similarly, calculate the collision masks for each axis
      uint32x4_t col_mask_x = vorrq_u32(gt_mask_x, lt_mask_x);
      uint32x4_t col_mask_y = vorrq_u32(gt_mask_y, lt_mask_y);
      uint32x4_t col_mask_z = vorrq_u32(gt_mask_z, lt_mask_z);
      // Calculate the negative velocities for each axis for the 4 objects
      float32x4_t neg_vx_v = vnegq_f32(vx_v);
      float32x4_t neg_vy_v = vnegq_f32(vy_v);
      float32x4_t neg_vz_v = vnegq_f32(vz_v);
      // Select the proper values of vx, vy, vz based on the collision masks
      vx_v = vbslq_f32(col_mask_x, neg_vx_v, vx_v);
      vy_v = vbslq_f32(col_mask_y, neg_vy_v, vy_v);
      vz_v = vbslq_f32(col_mask_z, neg_vz_v, vz_v);
      vst1q_f32(&objects->vx[i], vx_v);
      vst1q_f32(&objects->vy[i], vy_v);
      vst1q_f32(&objects->vz[i], vz_v);
      // Increase the collision counters per axis
      ctr_x = vaddq_u32(ctr_x, vandq_u32(col_mask_x, one));
      ctr_y = vaddq_u32(ctr_y, vandq_u32(col_mask_y, one));
      ctr_z = vaddq_u32(ctr_z, vandq_u32(col_mask_z, one));
    current_time += step;
  // The counters we calculated are in 4 elements for each axis
  // we need to do a horizontal addition to get the final result
  uint32_t collisions[3];
  collisions[0] = vaddvq_u32(ctr_x);
  collisions[1] = vaddvq_u32(ctr_y);
  collisions[2] = vaddvq_u32(ctr_z);
  printf("Total border collisions: x: %d, y: %d, z: %d\n", collisions[0], collisions[1], collisions[2]);
int main() {
  struct object_list objects;
  init_objects(&objects);
  const float duration = SECONDS;
  const float step = 1.0f / STEPSPERSEC;
  struct timeval th_time_start, th_time_end;
  gettimeofday(&th_time_start, NULL);
  simulate_objects(&objects, duration, step);
  gettimeofday(&th_time_end, NULL);
  double elapsed;
  elapsed = (th_time_end.tv_sec - th_time_start.tv_sec); // sec
  elapsed += (th_time_end.tv_usec - th_time_start.tv_usec) / 1000000.0; // us to sec
  printf("elapsed time: %f\n", elapsed);
Compile and run the new program as before:
```bash
gcc -O3 -Wall simulation4.c -o simulation4
./simulation4
The output printed is:
__output__Total border collisions: x: 250123, y: 249711, z: 249844
__output__elapsed time: 16.655471
For comparison, `clang-15` produces this output:
__output__elapsed time: 13.530677
The first observation is that the number of collisions reported is the same (which is a good thing, performance optimization is useless if you get the wrong results)!
You also see a significant speed gain: the new version is up to 2.25x faster than the original version and about 1.43x faster (for GCC 12) as the previous version, even the hand-written version in the previous section.
Apart from small differences between the compilers, the important difference is due to the change in the data layout.
Review what has been changed.
First, you will notice that the coordinates `x`, `y`, `z` are not part of the original `object` structure anymore, similarly for the velocity values `vx`, `vy`, `vz`.
Instead, there is now an array of `N` elements for each of those variables.
This means that you can now process 4 consecutive `x` elements in each iteration, 4 `y` elements, 4 `z` elements. This results in processing 4 objects per iteration, thereby reducing the iterations to `N/4`.
There is no single `| x | y | z | (unused) |` vector that wastes 25% of storage per instruction.
This example demonstrates two paradigms used in data layout. The previous sections use Array of Structs (AoS). This sections switches to Struct of Arrays (SoA).
The second one is generally more performant in SIMD operations.
A few points to consider:
- There is no waste of storage compared to the previous implementations (only 3 of the 4 float elements were used for the 3D coordinates x, y, z)
- About 1/4 of the original `N` iterations are executed, which means 1/4 of the branches
- Many more calculations are done per iteration, which is good as it keeps the CPU pipeline full
Here are some rules for optimal performance with SIMD/vectorized code:
- Prefer fewer iterations with more calculations per iteration (keep the pipeline full with fewer branches)
- Data should be consecutive, prefer struct of arrays instead of arrays of structs
- Try to keep the data as packed as possible, no wasted elements in the vectors
So far you have been using Neon/ASIMD instructions, but newer Arm processors also offer the Scalable Vector Extension (SVE).
Proceed to the next section to find out how to use SVE and compare the performance with Neon.
