Give feedback
AI-assisted
Close
How do I start and verify the ROS 2 and Zenoh environment before measuring?
From the Arm server host, run docker compose up -d in ~/ros_zenoh, then use docker compose ps. Both services should report Up. Then, open the robot container desktop and confirm that the Zenoh router, simulation, and Navigation2 processes are running. Restart any process that stopped.
Where do I run the network emulation command?
Open a terminal in the robot container desktop and run source ~/workshop_env.bash, followed by just network_limit. Apply the tc/netem limits from within the container environment used for the experiments.
How do I know the emulated wireless limits are active?
just network_limit prints the applied parameters, including rate, latency variation, loss, and reordering. Look for output that states the simulation is applied with values such as a 25mbit rate and nonzero latency and loss.
Which ROS 2 topics should I target first when the link is constrained?
The /camera/image_raw and /camera/points streams dominate bandwidth, while /scan is small. Compress the streams when you need to preserve them. If you don’t need point-cloud data, use access control to block /camera/points. If you need complete point-cloud frames, use compression with the QoS block_first policy.
When should I use downsampling instead of compression?
Use downsampling when the compressed camera stream still exceeds the available link capacity. Set the forwarded image rate less than the sustained capacity of the link to trade frame rate for steadier delivery and lower jitter.
