Select a configuration for your deployment
The experiments show that the right configuration depends on which sensor data the remote application needs. The available bandwidth didn’t need to change. Zenoh changed which messages used it and whether those messages arrived in a form the ROS 2 receiver could use.
Compression and access control
Use compression and access control when the remote station needs camera images and laser scans, but not the point cloud.
Enable transport/unicast/compression at both ends of the link. On the router in the robot desktop, deny */camera/points/** and its */camera/points/**/@adv/** variant.
The camera runs at its full source rate, /scan remains available, and the point cloud consumes no link bandwidth. For a remote station that only needs to monitor the robot, these two settings are sufficient.
Compression and quality of service
Use compression and quality of service (QoS) when complete point-cloud frames must reach the remote device.
Keep compression enabled and add the QoS qos/network block. Give important topics higher priority, and set congestion_control: "block_first" for payloads larger than 4096 bytes.
All three sensor streams can then share the link. The point cloud arrives at the rate the network supports. Each delivered frame is complete rather than a collection of unusable fragments.
Downsampling
Use downsampling when the compressed camera stream still exceeds the available capacity.
Set the forwarded image rate less than the sustained capacity of the link. This trades frame rate for steadier delivery and lower jitter.
What you’ve accomplished
You’ve used Zenoh deployment policies to control traffic and learned what policy you should select depending on your application requirements.
Apply the policy that matches your deployment, then use this measurement workflow to validate its results.
