Connect the Raspberry Pi over Wi-Fi
In the first experiment, you used the Docker network and the robot and control containers to emulate a wireless link. You’ll now connect your Raspberry Pi to the same Wi-Fi network as the Arm server. You’ll use the real Wi-Fi connection to test the same policy changes as the first experiment.
Using a 2.4 GHz Wi-Fi connection makes the effects clearer. To connect your Raspberry Pi as a Zenoh client, follow the Raspberry Pi connection procedure in Distribute a ROS 2 robotic system across Arm devices with Zenoh .
Restore the router configuration
Before starting, return the router configuration to a clean state. Open ~/container_data/ROUTER_CONFIG.json5 in a terminal within the robot container desktop and ensure the following:
  • Set transport/unicast/compression/enabled to false
  • Keep access_control, downsampling, and qos commented out
Restart the router on the robot container desktop after saving the file. Confirm that the emulated link is no longer active:
just network_normal
Use the physical wireless link for this experiment. Don’t run just network_limit.
Record an untuned baseline
Open three SSH sessions to the Raspberry Pi. In each session, open a bash shell in the pi_edge container and source ROS 2:
docker exec -it pi_edge /bin/bash
source /opt/ros/jazzy/setup.bash
Run one receiver command in each bash shell that has been opened in the pi_edge container:
ros2 topic hz /scan
Measure the camera image rate in the second shell:
ros2 topic hz /camera/image_raw
Measure the point-cloud bandwidth in the third shell:
ros2 topic bw /camera/points
Run just iftop_router in a terminal within the robot container desktop. Wait 60–90 seconds:
Scenario/scan/camera/image_raw/camera/pointsLink traffic
Untuned7.90 Hz4.2 HzNothing (wasting ~28 Mbps)~62 Mbps, nearly half of it wasted
A common baseline pattern is an intact laser scan, a reduced or irregular camera rate, and no complete point-cloud frames. iftop can show substantial point-cloud traffic even while ros2 topic bw remains silent. Those bytes belong to incomplete frames.
Real Wi-Fi results vary with signal strength, distance, interference, access-point load, and other devices using the same channel. Record the values that you observe.
Stop the three measurements and iftop with Ctrl+C.
Enable compression
Keep the three bash shells in the pi_edge container on the Raspberry Pi open after stopping the baseline measurements. In the robot container desktop, enable compression in ~/container_data/ROUTER_CONFIG.json5. Keep access_control, downsampling, and qos commented out.
Enable compression in each Pi shell:
export ZENOH_CONFIG_OVERRIDE="${ZENOH_CONFIG_OVERRIDE};transport/unicast/compression/enabled=true"
Confirm that the override includes compression:
echo $ZENOH_CONFIG_OVERRIDE
Stop and restart the router on the robot container desktop so that it reads the new configuration. Restart the same three measurements in the Raspberry Pi pi_edge container used for the baseline. Run just iftop_router in the robot container desktop. Collect data for 60–90 seconds.
Record your measurements and compare them with the reference result:
Compression7.85 Hz11.87 Hz — source rateNothing received (~26 Mbps wasted)~55.7 Mbps
Compression allows the camera images to fit the real Wi-Fi link, restoring the source frame rate. The point cloud still fails because the default congestion policy discards fragments before a complete frame arrives.
Downsample the camera
Stop the compression measurements and iftop. In the router configuration, disable compression and enable only the downsampling block. Keep access_control and qos commented out.
Exit the current three pi_edge container shells. Open fresh pi_edge shells, then source ROS 2 in each one:
exit
Don’t enable compression in these new shells. Stop and restart the router on the robot container desktop. Restart the measurements in the three pi_edge shells. Run just iftop_router in the robot container desktop. Collect data for 60–90 seconds.
Downsampling7.94 Hz2.37 Hz — steadyNothing received despite using 58–61 Mbps~64 Mbps
The camera settles near the 3 Hz target with less jitter. The point-cloud connection uses the bandwidth released by the camera and still delivers no complete frames. More available bandwidth hasn’t solved the large-message problem.
Compress and block the point cloud
Stop the downsampling measurements and iftop. In the router configuration, disable downsampling, enable compression, and enable the access_control block. Keep qos commented out.
Compression and access control7.85 Hz11.89 HzBlocked~29 Mbps, all useful
The point cloud now consumes no link bandwidth, while the camera and scan remain available. This configuration suits remote monitoring when the operator doesn’t need three-dimensional data.
Compress and deliver complete large messages
Stop the compression and access control measurements and iftop. In the router configuration, comment out the access-control block, keep compression enabled, and enable the quality of service (QoS) block. Keep downsampling disabled.
The Pi shells already have compression enabled, so no client-side change is needed. Stop and restart the router on the robot container desktop. Restart the measurements in the three pi_edge shells. Run just iftop_router in the robot container desktop. Collect data for 60–90 seconds.
Compression and QoS7.89 Hz11.88 Hz, std dev 0.019 s~1 complete frame/s~63 Mbps, all useful
The point-cloud terminal now reports complete 7.37 MB frames at the rate supported by the Wi-Fi connection. The camera and scan continue alongside it.
Compare the experiment results
The complete comparison shows that similar link rates can carry very different amounts of useful ROS 2 data:
Untuned baseline7.90 Hz4.2 HzNothing received~62 Mbps, nearly half wasted
Compression7.85 Hz11.87 HzNothing received~55.7 Mbps
Downsampling7.94 Hz2.37 Hz, steadyNothing received~64 Mbps
Compression and QoS7.89 Hz11.88 Hz, steady~1 complete frame/s~63 Mbps, all useful
You’ve repeated the policy comparison over real Wi-Fi. Compression restored the camera rate and access control removed an unwanted flow. Downsampling produced a steady lower-rate stream, and block_first delivered complete point-cloud frames.
The comparison shows that tuning doesn’t need to increase the available bandwidth. It changes how the bandwidth is used and which complete messages reach the receiver.
Next, you’ll select a configuration for the needs of your deployment.
