Apply network constraints
After measuring a baseline, emulate a wireless link and tune Zenoh. Start by applying network constraints.
Linux traffic control (tc) decides how packets leave a network interface. Its network emulator (netem) can add delay, loss, duplication, corruption, and reordering. You can use tc and netem together to reproduce a difficult network without moving the containers to Wi-Fi.
In a terminal within the robot container desktop, run:
source ~/workshop_env.bash
just network_limit
The output is similar to:
        WiFi medium connection simulation applied to 172.1.0.3:
 - Rate: 25mbit
 - Latency: 20ms ± 10ms
 - Packet loss: 0.5%
 - Reordering: 1% 25%
 - Duplicates: 0.1%
 - Corruptions: 0.01%
The 25 Mbps rate is a maximum. It’s not a guaranteed result. TCP can send less than the limit when it reacts to loss and reordering.
Restart the measurements and record:
Scenario/scan/camera/image_raw/camera/pointsLink traffic
Constrained7.94 Hz — unaffected0.88 Hz (std 0.577 s, max gap 6.3 s)Nothing received~23.5 Mbps (at the cap)
The scan is untouched: it’s small, and it has a connection of its own. /camera/image_raw slows down, becomes irregular, or receives no complete frames during the window. The point cloud disappears.
Stop all four measurement commands with Ctrl+C.
Apply compression
Zenoh uses LZ4 compression to reduce the bytes sent over a unicast connection. LZ4 was chosen for speed rather than ratio to avoid compression becoming a latency source. Compression is negotiated when a client connects, so the router and the client must both enable it.
In a terminal on the robot container desktop, open the router configuration:
nano ~/container_data/ROUTER_CONFIG.json5
Find the existing transport/unicast/compression section and set enabled to true:
compression: {
  enabled: true,
Don’t add a second transport block. Ignore the commented example and edit only the active value.
In a terminal on the control container desktop, open the client configuration:
nano ~/container_data/SESSION_CONFIG.json5
Find the same compression setting and set it to true.
Save each file with Ctrl+O and Enter, then exit Nano with Ctrl+X.
The router reads its configuration only at startup.
In the robot container desktop, find the terminal running the router. Press Ctrl+C, then restart it:
just router
Restart the four measurements and record:
Compression7.95 Hz (link traffic ~380 Kbps → ~200 Kbps)0.5–2.8 Hz, driftingNothing received~23.5 Mbps, still at the cap
The scan’s rate is unchanged but its bytes on the link roughly halve, with LZ4 achieving about 1.8× on this data. The image improves, but the reading drifts between measurements, while incomplete point-cloud fragments still compete for the link. An unstable reading is expected.
The total TX rate (Link traffic) can remain close to the constrained link’s capacity. Compression reduces individual messages, but publishers continue supplying more data than the link can carry.
Stop all four measurement commands with Ctrl+C. Keep compression enabled and keep the network limit active for the next scenario.
Add an access-control rule
A monitoring station doesn’t always need the point cloud. Zenoh access control can stop that topic at the router while local robot nodes continue to use it.
Open the router configuration in the robot container desktop:
Add the following access_control block at the top level of the file:
access_control: {
  enabled: true,
  default_permission: "allow",
  rules: [
      permission: "deny",
      messages: [
        "put", "delete", "declare_subscriber",
        "query", "reply", "declare_queryable",
        "liveliness_token", "liveliness_query", "declare_liveliness_subscriber",
      flows: ["egress", "ingress"],
      key_exprs: [
        "*/camera/points/**",
        "*/camera/points/**/@adv/**",
  subjects: [
    { id: "ALL" },
  policies: [
      rules: ["deny_points_cloud"],
      subjects: ["ALL"],
Don’t place the block inside transport.
The first key expression matches the point-cloud data. The @adv form matches the additional keys used to advertise topics with transient-local durability.
Save the file, stop the router with Ctrl+C, and restart it on the robot container desktop:
just router
Restart the three measurements in control and just iftop_router in robot, and wait 60–90 seconds:
Compression and access control7.97 Hz0.84 Hz (still bursty, max gap 11.4 s)Blocked, and the connection drops to zero~9.4 Mbps (The link is no longer saturated)
Verify the asymmetry from both sides:
# control container: nothing arrives
ros2 topic bw /camera/points
# robot container: unchanged
ros2 topic hz /camera/points
The control container receives nothing while the robot’s own nodes still exchange the point cloud at about 12 Hz. The rule governs what crosses the router rather than what happens inside the robot.
Note that /camera/points still appears in the remote ros2 topic list even though no data arrives. The block stops the data.
Stop all measurement commands with Ctrl+C. Keep compression, access control, and the network limit active.
Downsample the image
Downsampling drops publications on the egress path to a target frequency.
Keep the access-control block active. Open the router configuration in robot container desktop:
Add the following block at the top level:
downsampling: [
    messages: ["put", "reply"],
    flows: ["egress"],
    rules: [
      { key_expr: "*/camera/image_raw/**", freq: 3.0 },
      { key_expr: "*/camera/image_raw/**/@adv/**", freq: 3.0 },
The rule sets a maximum egress rate of 3 Hz for the image and its transient-local advertisement keys.
Save the file, stop the router, and restart it on the robot container desktop:
just router
Compression, access control, and downsampling8.0 Hz2.6 Hz, std dev 0.06 s — steadyBlocked~6.8 Mbps
The remote camera rate should settle near, but not necessarily exactly at, 3 Hz. Compare its standard deviation with access control. A lower standard deviation means the frames arrive more regularly instead of in bursts.
A steady rate less than the connection’s usable capacity gives the transmit queue time to drain between frames. A stable 2.6 Hz stream can be more useful to an operator than a lower average made from short bursts and long pauses.
Apply priority and congestion control
The remaining problem is the point cloud, which has only been blocked and never delivered. Restore the point-cloud traffic. Then, change the congestion policy.
Open ~/container_data/ROUTER_CONFIG.json5 in the robot container desktop. Comment out the access_control and downsampling blocks.
Add the following block for quality of service (QoS) at the top level:
qos: {
  network: [
      interfaces: ["eth0"],
      key_exprs: ["**/map/**", "**/scan/**"],
      messages: ["put", "query"],
      overwrite: { priority: "interactive_high" }
      key_exprs: ["**/robot_description/**"],
      overwrite: { priority: "interactive_low" }
      key_exprs: ["**/camera/image_raw/**"],
      messages: ["put"],
      overwrite: { priority: "data_low" }
      key_exprs: ["**/camera/points/**"],
      messages: ["put"],
      overwrite: { priority: "background" }
      payload_size: "4096..",
      messages: ["put"],
      overwrite: { congestion_control: "block_first" }
Verify the state of all three blocks before restarting:
grep -n "access_control\|downsampling\|qos\|block_first" ~/container_data/ROUTER_CONFIG.json5
Restart the router on the robot container desktop and the measurements.
Compression and QoS7.9 Hz4.4 Hz, std dev 0.08 sDelivered: 2.0–3.0 MB/s, a complete 7.37 MB frame every ~3 s~17.2 Mbps, all of it usable
For the first time under the constrained link, ros2 topic bw /camera/points should report complete 7.37 MB messages. The average bandwidth will be much lower than the baseline because a complete frame can take several seconds to arrive.
When the queue is full, block_first waits for the first matching message to progress and can drop later matching messages. This favors complete point-cloud frames over fragments from several competing frames. Fewer frames arrive, but the received frames are usable.
Stop the measurements with Ctrl+C. Restore the normal Docker network in the robot container desktop:
just network_normal
Compare the results of the experiment
The complete comparison shows how each policy changes the traffic delivered over the same constrained link:
Baseline7.97 Hz11.85 Hz~88 MB/s~810 Mbps
Constrained7.94 Hz0.88 HzNothing received~23.5 Mbps
Compression7.95 Hz0.5–2.8 Hz, driftingNothing received~23.5 Mbps
Compression and access control7.97 Hz0.84 Hz, burstyBlocked~9.4 Mbps
Compression, access control, and downsampling8.0 Hz2.6 Hz, steadyBlocked~6.8 Mbps
Compression and QoS7.9 Hz4.4 Hz, steady2.0–3.0 MB/s~17.2 Mbps
You’ve reproduced a constrained wireless link and measured how each Zenoh policy changes the result. Compression reduced the bytes sent but couldn’t deliver the point cloud by itself. Access control removed unwanted traffic, downsampling made the camera stream steadier, and block_first allowed complete point-cloud frames to arrive.
Next, you’ll repeat the comparison with a Raspberry Pi over real Wi-Fi.
