Understand wireless traffic constraints
A robot can work correctly in a controlled test environment and still fail when you move its ROS 2 traffic over to Wi-Fi. This is sometimes described as a robot that works on the bench.
The simulation from Build a ROS 2 and Zenoh simulation environment on an Arm server and Distribute a ROS 2 robotic system across Arm devices with Zenoh published three sensor streams:
TopicWhat it containsApproximate source traffic
/scanA two-dimensional laser scan0.4 Mbps
/camera/image_rawCamera images85 Mbps
/camera/pointsA three-dimensional point cloud 700 Mbps
These three streams together need about 800 Mbps, whereas a typical 2.4 GHz Wi-Fi connection might deliver only 50–100 Mbps of usable throughput. The sender can therefore produce between 8 and 16 times more data than the link can carry.
You’ll test four ways to control this traffic: compression, access control, downsampling, and quality of service (QoS) with congestion control. Most policies are applied at the Zenoh router. Compression must be enabled at both ends of the connection.
The work is done in two series:
  • In the first experiment, you’ll use tc/netem to emulate a degraded wireless link between two containers on the same server, which isolates each mechanism under repeatable conditions.
  • In the second experiment, you’ll repeat the measurements with a Raspberry Pi over real Wi-Fi, confirming the conclusions outside the emulator.
You’ve learned that the combined sensor traffic exceeds the capacity of the wireless link.
Next, you’ll set up the environment and record an unconstrained baseline.
