Analyze Intel x86 and Arm Neoverse top-down performance methodologies
Understand Intel x86 multilevel hierarchical top-down analysis
Understand Arm Neoverse top-down analysis
Evaluate cross-platform PMU counter differences
Measure cross-platform performance with topdown-tool and Perf PMU counters
After understanding the Intel x86 multi-level top-down hierarchy, you can look at how Arm Neoverse approaches the same challenge with a two-stage model designed for clarity and cross-architecture consistency.
Arm’s methodology follows the same four top-level categories: Retiring, Bad Speculation, Frontend Bound, and Backend Bound, but uses Arm-specific Performance Monitoring Unit (PMU) events and formulas.
Neoverse V2 is used below; the details will be different for other Neoverse processors.
Neoverse V2 uses an 8-slot rename unit to measure pipeline bandwidth.
Each cycle provides up to eight micro-operation (μop) slots for issue and execution.
This forms the foundation of the Neoverse V2 slot-based top-down accounting.
Total_SLOTS = CPU_CYCLES × 8
Just like Intel’s issue-slot model, Arm attributes every slot to one of the same four categories.
This allows percentage-based comparisons of pipeline efficiency across different cores, regardless of frontend or backend width.
Stage 1 corresponds to Level 1 in Intel’s TMAM and determines where the processor spends its available slots.
All formulas below are defined in the Arm Neoverse V2 Telemetry Specification.
| Metric | Formula | Description |
| Backend Bound | 100 × (STALL_SLOT_BACKEND / (CPU_CYCLES × 8) − (BR_MIS_PRED × 3 / CPU_CYCLES)) | Percentage of total slots stalled by backend resource constraints |
| Frontend Bound | 100 × (STALL_SLOT_FRONTEND / (CPU_CYCLES × 8) − (BR_MIS_PRED / CPU_CYCLES)) | Slots lost because the frontend cannot supply μops (fetch, decode, or branch delays) |
| Bad Speculation | 100 × ((1 − OP_RETIRED / OP_SPEC) × (1 − STALL_SLOT / (CPU_CYCLES × 8)) + (BR_MIS_PRED × 4 / CPU_CYCLES)) | Slots used by operations that never retire due to mispredictions or pipeline flushes |
| Retiring | 100 × (OP_RETIRED / OP_SPEC × (1 − STALL_SLOT / (CPU_CYCLES × 8))) | Slots that retire valid μops (useful work) |
Each metric is expressed as a percentage of total slots.
All four categories sum to 100%, providing a complete top-level pipeline utilization view.
Stage 2 expands on Stage 1 hotspots by examining detailed resource groups rather than a strict hierarchy.
The Neoverse V2 Telemetry Specification organizes metrics into effectiveness groups that can be analyzed independently:
| Metric Group | Example Metrics | Purpose |
| Cycle Accounting | frontend_stalled_cycles, backend_stalled_cycles | Percentage of cycles stalled in frontend vs. backend |
| Branch Effectiveness | branch_misprediction_ratio, branch_mpki | Branch prediction accuracy and misprediction rate |
| ITLB/DTLB Effectiveness | itlb_walk_ratio, dtlb_mpki | TLB efficiency and translation latency impact |
| Cache Effectiveness | l1i_cache_mpki, l1d_cache_miss_ratio, l2_cache_mpki, ll_cache_read_hit_ratio | Cache performance across all hierarchy levels |
| Operation Mix | integer_dp_percentage, load_percentage, simd_percentage, store_percentage, sve_all_percentage | Workload instruction composition and vector utilization |
| MPKI / Miss Ratio | Derived from cache and TLB refill events | Normalized misses per kilo instructions for cross-core comparisons |
Unlike Intel’s drill-down approach, Arm’s groups can be explored in any order to focus on the dominant subsystem.
Neoverse V2 implements the Arm PMUv3.5 architecture and exposes about 155 events.
The following subset is essential for top-down and resource-effectiveness analysis:
| Event Name | Purpose / Usage |
CPU_CYCLES | Core clock cycles – used as baseline for normalization |
OP_SPEC | Speculatively executed μops – denominator for slot accounting |
OP_RETIRED | Retired μops – measures useful work |
INST_RETIRED | Retired instructions – used for IPC and MPKI metrics |
INST_SPEC | Speculative instructions – required for Operation Mix |
STALL_SLOT | All stalled slots (frontend + backend) |
STALL_SLOT_FRONTEND | Stalled slots caused by frontend fetch/decode limitations |
STALL_SLOT_BACKEND | Stalled slots caused by backend resource constraints |
BR_MIS_PRED | Speculatively executed mispredicted branches (used in top-down formulas) |
BR_MIS_PRED_RETIRED | Mispredicted branches retired – used in Branch Effectiveness |
BR_RETIRED | Total branches retired – misprediction ratio denominator |
L1I_CACHE_REFILL | Instruction cache refills – frontend latency indicator |
ITLB_WALK | Instruction TLB walks – frontend translation stall indicator |
L1D_CACHE_REFILL | Data cache refills – backend memory latency indicator |
L2D_CACHE_REFILL | L2 cache refills – backend stall from L2 misses |
LL_CACHE_MISS_RD | Last-level cache read misses – backend stalls from SLC or memory accesses |
DTLB_WALK | Data TLB walks – backend stall due to address translation |
MEM_ACCESS | All memory accesses – baseline for cache/TLB ratios |
MPKI (Misses Per Kilo Instructions) is a normalized metric that measures cache or TLB misses per 1,000 retired instructions.
The formula is: MPKI = (Miss_Events / INST_RETIRED) × 1000
For example:
(L1D_CACHE_REFILL / INST_RETIRED) × 1000(DTLB_WALK / INST_RETIRED) × 1000MPKI provides several advantages:
Here are some practical steps to keep in mind:
Arm Neoverse V2 employs a concise, two-stage top-down methodology built around an 8-slot rename unit.
Stage 1 classifies total slots into Retiring, Bad Speculation, Frontend Bound, and Backend Bound.
Stage 2 uses effectiveness groups to investigate specific subsystems such as branch prediction, cache, and memory.
This model mirrors Intel’s top-down philosophy so you can compare the top-level categories.
