Configure slot-based accounting with Intel x86 PMU counters
Intel uses a slot-based accounting model, where each CPU cycle provides multiple issue slots.
A slot is a hardware resource that represents one opportunity for a microoperation (μop) to issue for execution during a single clock cycle.
Each cycle, the core exposes a fixed number of these issue opportunities, and this is known as the machine width in Intel’s Top-Down Microarchitecture Analysis Methodology (TMAM). You may also see the methodology referred to as TMA.
The total number of available slots is defined as:
Total_SLOTS = machine_width × CPU_CLK_UNHALTED.THREAD
The machine width corresponds to the maximum number of μops that a core can issue to execution pipelines per cycle.
  • Intel cores such as Skylake and Cascade Lake are 4-wide.
  • Newer server and client cores such as Sapphire Rapids, Emerald Rapids, Granite Rapids, and Meteor Lake P-cores are 6-wide.
  • Future generations may widen further, but the slot-based framework remains the same.
Tools such as perf topdown automatically apply the correct machine width for the detected CPU.
Intel’s methodology uses a multi-level hierarchy that typically extends to three or four levels of detail. Each level provides progressively finer analysis, allowing you to drill down from high-level categories to specific hardware events.
Level 1: Identify top-level performance categories
At Level 1, all pipeline slots are attributed to one of four categories, giving a high-level view of how the CPU’s issue capacity is being used:
  • Retiring = UOPS_RETIRED.RETIRE_SLOTS / SLOTS
  • Frontend Bound = IDQ_UOPS_NOT_DELIVERED.CORE / SLOTS
  • Bad Speculation = derived from speculative flush behavior (branch mispredictions and machine clears) or computed residually
  • Backend Bound = 1 − (Retiring + Frontend Bound + Bad Speculation)
Most workflows compute Backend Bound as the residual after Retiring, Frontend Bound, and Bad Speculation are accounted for.
Level 2: Analyze broader bottleneck causes
Once the dominant Level 1 category is identified, Level 2 separates each category into groups:
CategoryLevel 2 Sub-CategoriesPurpose
Frontend BoundFrontend Latency vs Frontend BandwidthDistinguish instruction-fetch delays from decode or μop cache throughput limits.
Backend BoundMemory Bound vs Core BoundSeparate stalls caused by memory hierarchy latency/bandwidth from those caused by execution-unit contention or scheduler pressure.
Bad SpeculationBranch Mispredict vs Machine ClearsIdentify speculation waste due to control-flow mispredictions or pipeline clears.
RetiringBase vs Microcode SequencerShow the proportion of useful work from regular instructions versus microcoded sequences.
Level 3: Target specific microarchitecture bottlenecks
Level 3 provides fine-grained attribution that pinpoints precise hardware limitations.
Examples include:
  • Memory Bound covers L1 Bound, L2 Bound, L3 Bound, DRAM Bound, Store Bound
  • Core Bound covers execution-port pressure, divider utilization, scheduler or ROB occupancy
  • Frontend latency covers instruction-cache misses, ITLB walks, branch-prediction misses
  • Frontend bandwidth covers decode throughput or μop cache saturation
At this level, you can determine whether workloads are limited by memory latency, cache hierarchy bandwidth, or execution-resource utilization.
Level 4: Access specific PMU counter events
Level 4 exposes the Performance Monitoring Unit (PMU) events that implement the hierarchy.
Here you analyze raw event counts to understand detailed pipeline behavior.
Event names and availability vary by microarchitecture, but you can verify them with perf list.
Event NamePurpose
UOPS_RETIRED.RETIRE_SLOTSCounts retired μops
UOPS_ISSUED.ANYCounts all issued μops (used in speculation analysis)
IDQ_UOPS_NOT_DELIVERED.CORECounts μops not delivered from frontend
CPU_CLK_UNHALTED.THREADCore clock cycles (baseline for normalization)
BR_MISP_RETIRED.ALL_BRANCHESBranch mispredictions
MACHINE_CLEARS.COUNTPipeline clears due to faults or ordering
CYCLE_ACTIVITY.STALLS_TOTALTotal stall cycles
CYCLE_ACTIVITY.STALLS_MEM_ANYStalls from memory hierarchy misses
CYCLE_ACTIVITY.STALLS_L1D_MISSStalls due to L1 data-cache misses
CYCLE_ACTIVITY.STALLS_L2_MISSStalls waiting on L2 cache misses
CYCLE_ACTIVITY.STALLS_L3_MISSStalls waiting on last-level cache misses
MEM_LOAD_RETIRED.L1_HIT / L2_HIT / L3_HITTrack where loads are satisfied in the cache hierarchy
MEM_LOAD_RETIRED.L3_MISSLoads missing the LLC and going to memory
MEM_LOAD_RETIRED.DRAM_HITLoads serviced by DRAM
OFFCORE_RESPONSE.*Detailed classification of off-core responses (L3 vs DRAM, local vs remote socket)
Some events (for example, CYCLE_ACTIVITY.* and MEM_LOAD_RETIRED.*) vary across microarchitectures so you should confirm them on your CPU.
Practical guidance
Here are some practical steps to keep in mind:
  • Normalize all metrics to total slots: machine_width × CPU_CLK_UNHALTED.THREAD.
  • Start at Level 1 to identify the dominant bottleneck.
  • Drill down progressively through Levels 2 and 3 to isolate the root cause.
  • Use raw events (Level 4) for detailed validation or hardware-tuning analysis.
  • Check event availability before configuring counters on different CPU generations.
Intel’s Top-Down methodology provides a structured, slot-based framework for understanding pipeline efficiency. Each slot represents a potential μop issue opportunity.
By attributing every slot to one of the four categories you can measure how effectively a core executes useful work versus wasting cycles on stalls or speculation.
