Overview
In this section, you provision a Google Axion C4A virtual machine on Google Cloud Platform (GCP) using the c4a-standard-32 machine type, which provides 16 vCPUs and 128 GB of memory. This VM size is required for building a Yocto-based image in the next steps.
Note
For general guidance on setting up a Google Cloud account and project, see the Learning Path Getting started with Google Cloud Platform .
Provision a Google Axion C4A VM in Google Cloud Console
To create a virtual machine using the C4A instance type:
  • Open the Google Cloud Console .
  • Go to Compute Engine > VM instances, and then select Create instance.
  • Under Machine configuration:
    • Specify an Instance name, Region, and Zone.
    • Set Series to C4A.
    • Select c4a-standard-32 as the machine type.
Image Alt Text:Google Cloud Console VM creation page with the C4A machine series selected and the c4a-standard-32 machine type highlightedCreating a Google Axion C4A virtual machine in the Google Cloud Console
  • Under OS and storage, select Change, and then choose an Arm64-based operating system image.
    • For this Learning Path, select Ubuntu 22.04 LTS.
    • Increase Size (GB) from 10 to 100 to allocate sufficient disk space.
    • Select Choose to apply the changes.
Image Alt Text:Selecting Ubuntu LTS 22.04 with 100GB disk space highlightedSelecting Ubuntu 22.04 LTS with 100GB disk space
  • Under Networking, enable Allow HTTP traffic and Allow HTTPS traffic to simplify access for later Kubernetes testing.
  • Select Create to launch the virtual machine.
Image Alt Text:Configuring the required networking settingsConfiguring the VM network
After the instance starts, click SSH next to the VM in the instance list to open a browser-based terminal session.
Image Alt Text:Google Cloud Console VM instances list with the SSH button highlighted for a running C4A instanceConnecting to a running C4A virtual machine using SSH
A new browser window opens with a terminal connected to your virtual machine.
Image Alt Text:Browser-based terminal window showing a command prompt on an Ubuntu Linux VM running on Google Axion C4ATerminal session connected to the virtual machine
Note
This is a rather expensive VM given its vCPU and memory usage. It is highly recommended to delete this VM once you have completed this learning path!
In this section, you:
  • Provisioned a Google Axion C4A VM on Google Cloud Platform
  • Configured the VM for Arm64-based Yocto image builds
Next, you’ll use this VM to build a Yocto image for your target hardware. Continue to the Yocto installation section to complete your edge deployment workflow.
