Understand SmolVLA
SmolVLA is a compact vision-language-action model. It combines camera images, a task instruction, and the robot state to generate a sequence of robot actions.
Image Alt Text:SmolVLA combines camera images, a task instruction, and robot state in a vision-language model that conditions an action expert to generate an action sequence.SmolVLA architecture
Image source: SmolVLA paper .
Export SmolVLA to ONNX
The checkpoint includes the SmolVLA policy and the LeRobot processors used before and after inference. The exporter writes the policy to an ONNX graph, and the processors remain outside it.
Run the exporter:
python scripts/export_onnx.py \
  --checkpoint work/artifacts/smolvla_libero \
  --output work/onnx/fp32/model.onnx \
  --reference-dir work/onnx/fp32/reference
Note
The export might take several minutes while it loads the checkpoint, traces the model graph, and validates the output with ONNX Runtime.
The exporter creates a fixed-shape model and a deterministic reference batch. The batch includes an explicit flow-matching noise tensor, so the PyTorch and ONNX Runtime paths receive the same inputs.
The expected output ends with:
        PASS: ONNX Runtime matches PyTorch within atol=0.001 and rtol=0.001
The FP32 graph contains the exported policy computation. Large weights can be stored in external data files beside model.onnx, so keep the complete work/onnx/fp32 directory together.
Review the model interface
The graph accepts six preprocessed inputs:
InputTypeShapeDescription
camera1float32[1, 3, 512, 512]Primary RGB image scaled to [0, 1]
camera2float32[1, 3, 512, 512]Wrist RGB image scaled to [0, 1]
lang_tokensint64[1, 48]Tokenized task instruction
lang_attention_maskint64[1, 48]Valid language-token mask
statefloat32[1, 8]Normalized robot state
noisefloat32[1, 50, 32]Flow-matching noise
The model returns an action chunk with shape [1, 50, 7]: 50 steps with seven control values each.
The ONNX boundary deliberately starts after preprocessing and ends before postprocessing:
observation -> LeRobot preprocessor -> ONNX model -> LeRobot postprocessor -> robot action
Use the processors from the same checkpoint. They preserve the tokenization, normalization, and action conversion expected by the policy.
Inspect the validation report
View the report written by the exporter:
python -m json.tool work/onnx/fp32/validation.json
Confirm that the report lists CPUExecutionProvider, reports an output shape of [1, 50, 7], and passes validation.
You’ve exported SmolVLA to FP32 ONNX and validated its action output with ONNX Runtime on an Arm CPU.
Next, you’ll quantize the eligible linear weights to packed INT4 and run the resulting model through the same interface.
