In this section, you will build and run C and Rust examples to perform a matrix transpose.
Shown below is a simple program in C that does a matrix transpose operation on a 4x4 matrix of uint16_t elements. Copy and save the contents in a file named transpose1.c:
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <arm_neon.h>
#define N 4
void init_vec(uint16_t *A) {
for (int i = 0; i < N; i++) {
for (int j = 0; j < N; j++) {
A[i*N + j] = 4*i + j + 1;
void print_vec(uint16_t *A) {
printf("A[] = \n");
printf("%02x ", A[i*N + j]);
printf("\n");
void transpose_s16_4x4(int16_t *a) {
int16x4_t va[N];
va[0] = vld1_s16(&a[0]);
va[1] = vld1_s16(&a[4]);
va[2] = vld1_s16(&a[8]);
va[3] = vld1_s16(&a[12]);
const int16x4x2_t b0 = vtrn_s16(va[0], va[1]);
const int16x4x2_t b1 = vtrn_s16(va[2], va[3]);
const int32x2x2_t c0 = vtrn_s32(vreinterpret_s32_s16(b0.val[0]),
vreinterpret_s32_s16(b1.val[0]));
const int32x2x2_t c1 = vtrn_s32(vreinterpret_s32_s16(b0.val[1]),
vreinterpret_s32_s16(b1.val[1]));
vst1_s16(&a[0], vreinterpret_s16_s32(c0.val[0]));
vst1_s16(&a[4], vreinterpret_s16_s32(c1.val[0]));
vst1_s16(&a[8], vreinterpret_s16_s32(c0.val[1]));
vst1_s16(&a[12], vreinterpret_s16_s32(c1.val[1]));
int main() {
int16_t A[N*N];
init_vec(A);
print_vec(A);
transpose_s16_4x4(A);
print_vec(A);
Compile the program as follows:
gcc -O3 transpose1.c -o transpose1
Run the program:
./transpose1
The output should look like the following:
A[] =
0001 0002 0003 0004
0005 0006 0007 0008
0009 000a 000b 000c
000d 000e 000f 0010
A[] =
0001 0005 0009 000d
0002 0006 000a 000e
0003 0007 000b 000f
0004 0008 000c 0010
Note the special data types int16x4x2_t and int32x2x2_t which are used by the transpose vtrn_s16 and vtrn_s32 respectively. The pairs denote that there are going to be two instructions executed with a specific outcome. The corresponding assembly instructions executed are trn1/trn2 for the first intrinsic and zip1/zip2 for the second intrinsic.
Generate the disassembly output as per below:
objdump -S transpose1
The disassembly output of the transpose_s16_4x4 function should look like the following:
00000000000008f0 <transpose_s16_4x4>:
8f0: 6d400c00 ldp d0, d3, [x0]
8f4: 6d411001 ldp d1, d4, [x0, #16]
8f8: 0e432802 trn1 v2.4h, v0.4h, v3.4h
8fc: 0e436800 trn2 v0.4h, v0.4h, v3.4h
900: 0e442823 trn1 v3.4h, v1.4h, v4.4h
904: 0e446821 trn2 v1.4h, v1.4h, v4.4h
908: 0e833844 zip1 v4.2s, v2.2s, v3.2s
90c: 0e837842 zip2 v2.2s, v2.2s, v3.2s
910: 0e813803 zip1 v3.2s, v0.2s, v1.2s
914: 0e817800 zip2 v0.2s, v0.2s, v1.2s
918: 6d000c04 stp d4, d3, [x0]
91c: 6d010002 stp d2, d0, [x0, #16]
920: d65f03c0 ret
This looks fairly straightforward with the expected sequence of instructions.
Now create an equivalent program implemented in Rust. Save the contents shown below in a file named transpose2.rs:
const N : usize = 4;
fn main() {
let mut a: [i16; N*N] = [0; N*N];
init_vec(&mut a);
print_vec(&a);
transpose_s16_4x4(&mut a);
print_vec(&a);
fn init_vec(a: &mut [i16; N*N]) -> () {
for i in 0..N {
for j in 0..N {
a[i*N + j] = (4*i + j + 1) as i16;
fn print_vec(a: &[i16; N*N]) -> () {
println!("A[] =");
for i in 0..N {
for j in 0..N {
print!("{:02x} ", a[i*N + j]);
println!();
#[inline(never)]
fn transpose_s16_4x4(a: &mut [i16]) -> () {
#[cfg(target_arch = "aarch64")]
use std::arch::is_aarch64_feature_detected;
if is_aarch64_feature_detected!("neon") {
return unsafe { transpose_s16_4x4_asimd(a) };
// Scalar implementation should be included here as fallback
#[target_feature(enable = "neon")]
unsafe fn transpose_s16_4x4_asimd(a: &mut [i16]) -> () {
use std::arch::aarch64::*;
let va: [int16x4_t; N] = [ vld1_s16(&a[0]), vld1_s16(&a[4]), vld1_s16(&a[8]), vld1_s16(&a[12]) ];
let b0 : int16x4x2_t = vtrn_s16(va[0], va[1]);
let b1 : int16x4x2_t = vtrn_s16(va[2], va[3]);
let c0 : int32x2x2_t = vtrn_s32(vreinterpret_s32_s16(b0.0),
vreinterpret_s32_s16(b1.0));
let c1 : int32x2x2_t = vtrn_s32(vreinterpret_s32_s16(b0.1),
vreinterpret_s32_s16(b1.1));
vst1_s16(&mut a[0], vreinterpret_s16_s32(c0.0));
vst1_s16(&mut a[4], vreinterpret_s16_s32(c1.0));
vst1_s16(&mut a[8], vreinterpret_s16_s32(c0.1));
vst1_s16(&mut a[12], vreinterpret_s16_s32(c1.1));
You will note two important differences here:
int16x4_t va array at the start of the transpose_s16_4x4_asimd function.va and the compiler will not complain. The compiler knows that the SIMD variable will be immediately initialized by the respective load instructions vld1q_s16.int16x4x2_t and int32x2x2_t are defined as structs in C with each element as the corresponding element of the nested array val[]. In Rust, however, they are defined as tuples, and each element is accessed directly as 0 or 1 in these cases, e.g., b0.0 and c1.1.Compile the program as follows:
rustc -O transpose2.rs
Run the program:
./transpose2
The output should look similar to the below:
A[] =
A[] =
0001 0002 0003 0004
0005 0006 0007 0008
0009 000a 000b 000c
000d 000e 000f 0010
A[] =
0001 0005 0009 000d
0002 0006 000a 000e
0003 0007 000b 000f
0004 0008 000c 0010
Generate the disassembly output:
objdump -S transpose2
The disassembly output of the Rust implementation of transpose_s16_4x4_asimd is shown below:
00000000000064b0 <_ZN10transpose217transpose_s16_4x417ha75632bf6146b962E>:
64b0: 6d400400 ldp d0, d1, [x0]
64b4: 6d410c02 ldp d2, d3, [x0, #16]
64b8: 0e412804 trn1 v4.4h, v0.4h, v1.4h
64bc: 0e416800 trn2 v0.4h, v0.4h, v1.4h
64c0: 0e432845 trn1 v5.4h, v2.4h, v3.4h
64c4: 0e436841 trn2 v1.4h, v2.4h, v3.4h
64c8: 0e853882 zip1 v2.2s, v4.2s, v5.2s
64cc: 0e813803 zip1 v3.2s, v0.2s, v1.2s
64d0: 0e857884 zip2 v4.2s, v4.2s, v5.2s
64d4: 0e817800 zip2 v0.2s, v0.2s, v1.2s
64d8: 6d000c02 stp d2, d3, [x0]
64dc: 6d010004 stp d4, d0, [x0, #16]
64e0: d65f03c0 ret
As you would expect this matches the C disassembly.
In the next section, you will look at a more complex example.
