## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/)
- [Introduction to Rust](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/intro-to-rust/)
- [Arm SIMD on Rust](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/simd-on-rust-part1/)
- [Inlining Intrinsics](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/simd-on-rust-part2/)
- [Matrix transpose](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/simd-on-rust-part3/)
- [A more complicated example](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/simd-on-rust-part4/)
- [Conclusion](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/conclusion/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/_next-steps/)
## [Inlining Intrinsics](https://learn.arm.com/learning-paths/cross-platform/simd-on-rust/simd-on-rust-part2/)
## An example with dot product instructions
You can now continue with an example around `dotprod` intrinsics. Shown below is a program that calculates the sum of absolute differences (SAD) of a 32x32 array of 8-bit unsigned integers (`uint8_t`) using the `vdotq_u32` intrinsic. Save the contents in a file named `dotprod1.c`:
```c
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <arm_neon.h>
#define N 32
void init_vec(uint8_t *A, uint8_t *B, int w, int h) {
  for (int i = 0; i < h; i++) {
    printf("A[%d] = [ ", i);
    for (int j = 0; j < w; j++) {
      A[i*w + j] = i + j;
      printf("%02x ", A[i*w + j]);
    printf("]\n");
    printf("B[%d] = [ ", i);
      B[i*w + j] = (i + j) & 4;
      printf("%02x ", B[i*w + j]);
    printf("]\n");
uint32_t sad_neon(const uint8_t *a, const uint8_t *b, int w, int h) {
  uint32x4_t sum = vdupq_n_u32(0);
    for (int j = 0; j < w; j += 16) {
      uint8x16_t va = vld1q_u8(&a[i*w + j]);
      uint8x16_t vb = vld1q_u8(&b[i*w + j]);
      uint8x16_t diff = vabdq_u8(va, vb);
      sum = vdotq_u32(sum, diff, vdupq_n_u8(1));
  return vaddvq_u32(sum);
int main() {
    uint8_t A[N*N], B[N*N];
    init_vec(A, B, N, N);
    uint32_t sad = sad_neon(A, B, N, N);
    printf("sad = %x\n", sad);
Compile the program as follows:
gcc -O3 -march=armv8.2-a+dotprod dotprod1.c -o dotprod1
Run the program:
./dotprod1
The output should look similar to:
__output__ A[0] = [ 00 01 02 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f ]
__output__ B[0] = [ 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 ]
__output__ A[1] = [ 01 02 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f 20 ]
__output__ B[1] = [ 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 ]
__output__ A[30] = [ 1e 1f 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d ]
__output__ B[30] = [ 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 ]
__output__ A[31] = [ 1f 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e ]
__output__ B[31] = [ 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 ]
__output__ sad = 7400
Note the extra compiler flag `-march=armv8.2-a+dotprod` as this flag is used to enable the code generation for `dotprod` instructions.
Generate the disassembly output as per below:
objdump -S dotprod1
Shown below is the disassembly output for the `sad_neon` function:
0000000000000a10 <sad_neon>:
 a10:   7100007f        cmp     w3, #0x0
 a14:   5400030d        b.le    a74 <sad_neon+0x64>
 a18:   4f000402        movi    v2.4s, #0x0
 a1c:   93407c46        sxtw    x6, w2
 a20:   4f00e423        movi    v3.16b, #0x1
 a24:   52800005        mov     w5, #0x0                        // #0
 a28:   d2800004        mov     x4, #0x0                        // #0
 a2c:   7100005f        cmp     w2, #0x0
 a30:   5400012d        b.le    a54 <sad_neon+0x44>
 a34:   d503201f        nop
 a38:   3ce46800        ldr     q0, [x0, x4]
 a3c:   3ce46821        ldr     q1, [x1, x4]
 a40:   91004084        add     x4, x4, #0x10
 a44:   6e217400        uabd    v0.16b, v0.16b, v1.16b
 a48:   6e839402        udot    v2.4s, v0.16b, v3.16b
 a4c:   6b04005f        cmp     w2, w4
 a50:   54ffff4c        b.gt    a38 <sad_neon+0x28>
 a54:   110004a5        add     w5, w5, #0x1
 a58:   8b060000        add     x0, x0, x6
 a5c:   8b060021        add     x1, x1, x6
 a60:   6b05007f        cmp     w3, w5
 a64:   54fffe21        b.ne    a28 <sad_neon+0x18>  // b.any
 a68:   4eb1b840        addv    s0, v2.4s
 a6c:   1e260000        fmov    w0, s0
 a70:   d65f03c0        ret
 a74:   4f000402        movi    v2.4s, #0x0
 a78:   4eb1b840        addv    s0, v2.4s
 a7c:   1e260000        fmov    w0, s0
 a80:   d65f03c0        ret
You will notice the use of `uabd` and `udot` assembly instructions that correspond to the `vabdq_u8`/`vdotq_u32` intrinsics.
Now create an equivalent Rust program using `std::arch` `neon` intrinsics. Save the contents shown below in a file named `dotprod2.rs`:
```rust
#![feature(stdarch_neon_dotprod)]
const N: usize = 32;
fn main() {
    let mut a: [u8; N*N] = [0; N*N];
    let mut b: [u8; N*N] = [0; N*N];
    init_vec(&mut a, &mut b, N, N);
    let sad: u32 = sad_vec(&a, &b, N, N);
    println!("sad = {:x}", sad);
fn init_vec(a: &mut [u8], b: &mut [u8], w: usize, h: usize) {
    for i in 0..h {
        print!("A[{}] = [ ", i);
        for j in 0..w {
            a[i*w + j] = (i + j) as u8;
            print!("{:02x} ", a[i*w + j]);
        println!("]");
        print!("B[{}] = [ ", i);
        for j in 0..w {
            b[i*w + j] = ((i + j) & 4) as u8;
            print!("{:02x} ", b[i*w + j]);
        println!("]");
#[inline(never)]
fn sad_vec(a: &[u8], b: &[u8], w: usize, h: usize) -> u32 {
    #[cfg(target_arch = "aarch64")]
        use std::arch::is_aarch64_feature_detected;
        if is_aarch64_feature_detected!("neon") {
            return unsafe { sad_vec_asimd(a, b, w, h) };
    // Scalar implementation should be included here as fallback
    return 0;
#[target_feature(enable = "neon")]
unsafe fn sad_vec_asimd(a: &[u8], b: &[u8], w: usize, h: usize) -> u32 {
    use std::arch::aarch64::*;
    let mut sum: uint32x4_t = vdupq_n_u32(0);
    for i in 0..h {
        for j in (0..w).step_by(16) {
            let va: uint8x16_t = vld1q_u8(&a[i*w + j]);
            let vb: uint8x16_t = vld1q_u8(&b[i*w + j]);
            let diff: uint8x16_t = vabdq_u8(va, vb);
rustc -O dotprod2.rs
Run the program:
./dotprod2
__output__ B[31] = [ 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 04 04 00 00 00 00 04 04 ]
As you can see both executables produce the same output.
Generate the disassembly output:
objdump -S dotprod2
0000000000006394 <_ZN4core9core_arch10arm_shared4neon9generated9vdotq_u3217h5c7bc8d63e4a993fE>:
    6394:       3dc00000        ldr     q0, [x0]
    6398:       3dc00021        ldr     q1, [x1]
    639c:       3dc00042        ldr     q2, [x2]
    63a0:       6e829420        udot    v0.4s, v1.16b, v2.16b
    63a4:       3d800100        str     q0, [x8]
    63a8:       d65f03c0        ret
0000000000006690 <_ZN8dotprod27sad_vec17h827a107d303290b5E>:
    6690:       d101c3ff        sub     sp, sp, #0x70
    6694:       f90023fe        str     x30, [sp, #64]
    6698:       a90557f6        stp     x22, x21, [sp, #80]
    669c:       a9064ff4        stp     x20, x19, [sp, #96]
    66a0:       aa0103f3        mov     x19, x1
    66a4:       aa0003f4        mov     x20, x0
    66a8:       6f00e400        movi    v0.2d, #0x0
    66ac:       4f00e423        movi    v3.16b, #0x1
    66b0:       aa1f03f5        mov     x21, xzr
    66b4:       aa1f03e8        mov     x8, xzr
    66b8:       3ce86a81        ldr     q1, [x20, x8]
    66bc:       3ce86a62        ldr     q2, [x19, x8]
    66c0:       91004116        add     x22, x8, #0x10
    66c4:       910003e8        mov     x8, sp
    66c8:       910043e0        add     x0, sp, #0x10
    66cc:       910083e1        add     x1, sp, #0x20
    66d0:       6e227421        uabd    v1.16b, v1.16b, v2.16b
    66d4:       9100c3e2        add     x2, sp, #0x30
    66d8:       3d800fe3        str     q3, [sp, #48]
    66dc:       ad0087e0        stp     q0, q1, [sp, #16]
    66e0:       97ffff2d        bl      6394 <_ZN4core9core_arch10arm_shared4neon9generated9vdotq_u3217h5c7bc8d63e4a993fE>
    66e4:       4f00e423        movi    v3.16b, #0x1
    66e8:       3dc003e0        ldr     q0, [sp]
    66ec:       f10082df        cmp     x22, #0x20
    66f0:       aa1603e8        mov     x8, x22
    66f4:       54fffe21        b.ne    66b8 <_ZN8dotprod27sad_vec17h827a107d303290b5E+0x28>  // b.any
    66f8:       910006b5        add     x21, x21, #0x1
    66fc:       91008273        add     x19, x19, #0x20
    6700:       91008294        add     x20, x20, #0x20
    6704:       f10082bf        cmp     x21, #0x20
    6708:       54fffd61        b.ne    66b4 <_ZN8dotprod27sad_vec17h827a107d303290b5E+0x24>  // b.any
    670c:       4eb1b800        addv    s0, v0.4s
    6710:       a9464ff4        ldp     x20, x19, [sp, #96]
    6714:       a94557f6        ldp     x22, x21, [sp, #80]
    6718:       f94023fe        ldr     x30, [sp, #64]
    671c:       1e260000        fmov    w0, s0
    6720:       9101c3ff        add     sp, sp, #0x70
    6724:       d65f03c0        ret
Note that where you might expect to see a `udot` instruction, there’s a `bl` instruction which indicates a branch. The `udot` instruction is instead called in another function, which carries out the loads again.
This seems counter-intuitive but the reason is that, unlike C, Rust treats the intrinsics like normal functions.
Like functions, inlining them isn’t always guaranteed. If it’s possible to inline the intrinsic, code generation and performance would be almost as that with C. If it’s not possible, you might find that the same code in Rust performs worse than in C.
Because of this, you have to look carefully at the disassembly generated from your SIMD Rust code. So, how can you fix this behavior and get the expected generated code?
As you have seen, Rust has a very particular way to enable target features. In this case, you have to remember to add that `dotprod` is the required target feature. Make this change in the function `sad_vec_asimd` as shown below:
```rust
#[target_feature(enable = "dotprod")]
Add support for both `neon` and `dotprod` target features as shown:
```rust
#[target_feature(enable = "neon", enable = "dotprod")]
Next, check that you have added the `#!feature` for the module’s code generation at the top of the file:
```rust
Save the file again and recompile as before:
Generate the disassembly output again:
objdump -S dotprod2
Now look at the changed disassembly output as follows:
000000000000667c <_ZN8dotprod213sad_vec_asimd17h2989b6ba09be74edE>:
    667c:       6f00e400        movi    v0.2d, #0x0
    6680:       4f00e421        movi    v1.16b, #0x1
    6684:       aa1f03e8        mov     x8, xzr
    6688:       8b080009        add     x9, x0, x8
    668c:       8b08002a        add     x10, x1, x8
    6690:       91008108        add     x8, x8, #0x20
    6694:       ad401542        ldp     q2, q5, [x10]
    6698:       f110011f        cmp     x8, #0x400
    669c:       ad401123        ldp     q3, q4, [x9]
    66a0:       6e227462        uabd    v2.16b, v3.16b, v2.16b
    66a4:       6e819440        udot    v0.4s, v2.16b, v1.16b
    66a8:       6e257482        uabd    v2.16b, v4.16b, v5.16b
    66ac:       6e819440        udot    v0.4s, v2.16b, v1.16b
    66b0:       54fffec1        b.ne    6688 <_ZN8dotprod213sad_vec_asimd17h2989b6ba09be74edE+0xc>  // b.any
    66b4:       4eb1b800        addv    s0, v0.4s
    66b8:       1e260000        fmov    w0, s0
    66bc:       d65f03c0        ret
This disassembly output is now as you would expect it to be as well as being better performant. You’ll see that the compiler automatically unrolled the loop twice because it was able to figure out that the number of iterations was small. Increasing the iterations will probably disable aggressive unrolling but it will at least inline the intrinsics properly.
