Learn SVE and SME programming with SIMD Loops
About Single Instruction, Multiple Data loops
Using SIMD Loops
Code example
Learning with SIMD Loops
Run
uname -m. Expect aarch64 on Linux or arm64 on macOS. If you see another value, switch to an Arm-based system before continuing.Browse the
loops directory and open loops.inc. It lists the kernels with brief descriptions and the identifiers used by the project.Open
loops/loop_202.c and locate inner_loop_202() around lines 60–70. Then open loops/matmul_fp32.c, which implements C[M × N] = A[M × K] × B[K × N].You can explore predication, vector-length-agnostic (VLA) programming, gather/scatter, streaming mode, and ZA tiles. Implementations use C and Arm C Language Extensions (ACLE) intrinsics.
Build and run the selected kernel with the project runner, then validate its results against the C reference implementation. Choose the build target for each variant to compare scalar, Neon, SVE and SVE2, and SME2 behavior.
