Overview: loop 202 matrix multiplication example
To illustrate the structure and design principles of SIMD Loops, consider loop 202 as an example.
Use a text editor to open loops/loop_202.c.
The function inner_loop_202() is defined around lines 60–70 in loops/loop_202.c and calls the matmul_fp32 routine defined in loops/matmul_fp32.c
Open loops/matmul_fp32.c in your editor.
This loop implements single-precision floating-point matrix multiplication of the form:
C[M × N] = A[M × K] × B[K × N]
You can view matrix multiplication in two equivalent ways:
  • As the dot product between each row of A and each column of B
  • As the sum of outer products between the columns of A and the rows of B
Data structure definition
The loop begins by defining a data structure that captures the matrix dimensions (M, K, N) along with input and output buffers:
struct loop_202_data {
  uint64_t m;
  uint64_t n;
  uint64_t k;
  float *restrict a;
  float *restrict b;
  float *restrict c;
For this loop:
  • Matrix a is stored in column-major order
  • Matrix b is stored in row-major order
  • The memory regions referenced by a, b, and c do not alias, as indicated by the restrict keyword
This layout helps optimize memory access patterns across the targeted SIMD architectures.
Loop attributes by architecture
Loop attributes are specified per target architecture:
  • SME targetsinner_loop_202 is invoked with the __arm_streaming attribute and uses a shared ZA register context (__arm_inout("za")). These attributes are wrapped in the LOOP_ATTR macro
  • SVE or Neon targets — no additional attributes are required
This design enables portability across SIMD extensions.
Function implementation in loops/matmul_fp32.c
loops/matmul_fp32.c provides several optimizations of matrix multiplication, including ACLE intrinsics and hand-optimized assembly.
Scalar code
A scalar C implementation appears around lines 40–52. It follows the dot-product formulation and serves as both a functional reference and an auto-vectorization baseline:
   for (uint64_t x = 0; x < m; x++) {
     for (uint64_t y = 0; y < n; y++) {
       c[x * n + y] = 0.0f;
   // Loops ordered for contiguous memory access in inner loop
   for (uint64_t z = 0; z < k; z++)
         c[x * n + y] += a[z * m + x] * b[z * n + y];
SVE-optimized code
The SVE version uses indexed floating-point multiply–accumulate (fmla) to optimize the matrix multiplication operation. The outer product is decomposed into indexed multiply steps, and results accumulate directly in Z registers.
In the intrinsics version (lines 167–210), the innermost loop is structured as follows:
  for (m_idx = 0; m_idx < m; m_idx += 8) {
    for (n_idx = 0; n_idx < n; n_idx += svcntw() * 2) {
      ZERO_PAIR(0);
      ZERO_PAIR(1);
      ZERO_PAIR(2);
      ZERO_PAIR(3);
      ZERO_PAIR(4);
      ZERO_PAIR(5);
      ZERO_PAIR(6);
      ZERO_PAIR(7);
      ptr_a = &a[m_idx];
      ptr_b = &b[n_idx];
      while (ptr_a < cnd_k) {
        lda_0 = LOADA_PAIR(0);
        lda_1 = LOADA_PAIR(1);
        ldb_0 = LOADB_PAIR(0);
        ldb_1 = LOADB_PAIR(1);
        MLA_GROUP(0);
        MLA_GROUP(1);
        MLA_GROUP(2);
        MLA_GROUP(3);
        MLA_GROUP(4);
        MLA_GROUP(5);
        MLA_GROUP(6);
        MLA_GROUP(7);
        ptr_a += m * 2;
        ptr_b += n * 2;
      ptr_c = &c[n_idx];
      STORE_PAIR(0);
      STORE_PAIR(1);
      STORE_PAIR(2);
      STORE_PAIR(3);
      STORE_PAIR(4);
      STORE_PAIR(5);
      STORE_PAIR(6);
      STORE_PAIR(7);
    c += n * 8;
At the beginning of the loop, the accumulators (Z registers) are zeroed using svdup (or dup in assembly), encapsulated in the ZERO_PAIR macro.
Within each iteration over the K dimension:
  • 128 bits (four consecutive floating-point values) are loaded from A using replicate loads svld1rq (or ld1rqw), through LOADA_PAIR
  • Two vectors are loaded from B using SVE vector loads, using LOADB_PAIR
  • Indexed fmla operations compute element–vector products and accumulate into 16 Z register accumulators
  • Partial sums build up the output tile
After all K iterations, results in the Z registers are stored to C using the STORE_PAIR macro.
The equivalent SVE hand-optimized assembly appears around lines 478–598.
This loop shows how SVE registers and indexed fmla enable efficient decomposition of the outer-product formulation into parallel, vectorized accumulation.
For SVE/SVE2 semantics and optimization guidance, see the Scalable Vector Extensions resources .
SME2-optimized code
The SME2 implementation leverages the outer-product formulation of the matrix multiplication function, utilizing the fmopa SME instruction to perform the outer-product and accumulate partial results in ZA tiles.
A snippet of the loop is shown below:
#if defined(__ARM_FEATURE_SME2p1)
  svzero_za();
#endif
  for (m_idx = 0; m_idx < m; m_idx += svl_s * 2) {
    for (n_idx = 0; n_idx < n; n_idx += svl_s * 2) {
#if !defined(__ARM_FEATURE_SME2p1)
      svzero_za();
#endif
      ptr_a = &a[m_idx];
      ptr_b = &b[n_idx];
        vec_a0 = svld1_x2(c_all, &ptr_a[0]);
        vec_b0 = svld1_x2(c_all, &ptr_b[0]);
        vec_a1 = svld1_x2(c_all, &ptr_a[m]);
        vec_b1 = svld1_x2(c_all, &ptr_b[n]);
        MOPA_TILE(0, 0, 0, 0);
        MOPA_TILE(1, 0, 0, 1);
        MOPA_TILE(2, 0, 1, 0);
        MOPA_TILE(3, 0, 1, 1);
        MOPA_TILE(0, 1, 0, 0);
        MOPA_TILE(1, 1, 0, 1);
        MOPA_TILE(2, 1, 1, 0);
        MOPA_TILE(3, 1, 1, 1);
        ptr_a += m * 2;
        ptr_b += n * 2;
      ptr_c = &c[n_idx];
      for (l_idx = 0; l_idx < l_cnd; l_idx += 8) {
        vec_c0 = svreadz_hor_za8_u8_vg4(0, l_idx + 0);
        vec_c1 = svreadz_hor_za8_u8_vg4(0, l_idx + 4);
#else
        vec_c0 = svread_hor_za8_u8_vg4(0, l_idx + 0);
        vec_c1 = svread_hor_za8_u8_vg4(0, l_idx + 4);
#endif
        STORE_PAIR(0, 0, 1, 0);
        STORE_PAIR(1, 0, 1, n);
        STORE_PAIR(0, 2, 3, c_blk);
        STORE_PAIR(1, 2, 3, c_off);
        ptr_c += n * 2;
    c += c_blk * 2;
Within the SME2 intrinsics code (lines 91–106), the innermost loop iterates across the K dimension - columns of A and rows of B.
In each iteration:
  • Two consecutive vectors are loaded from A and two from B (vec_a*, vec_b*) using multi-vector load intrinsics
  • fmopa, wrapped by MOPA_TILE, computes the outer product
  • Partial results accumulate in four 32-bit ZA tiles
After all K iterations, results are written back in a store loop (lines 111–124).
During this phase, rows of ZA tiles are read into Z vectors using svread_hor_za8_u8_vg4 (or svreadz_hor_za8_u8_vg4 on SME2.1). Vectors are then stored to the output buffer using SME multi-vector st1w stores using STORE_PAIR.
The equivalent SME2 hand-optimized assembly appears around lines 229–340.
For instruction semantics and SME/SME2 optimization guidance, see the SME Programmer’s Guide .
Other optimizations
Beyond the SME2 and SVE implementations, this loop also includes additional optimized versions that leverage architecture-specific features:
  • Neon: the Neon version (lines 612–710) uses structure load/store combined with indexed fmla to vectorize the computation.
  • SVE2.1: the SVE2.1 version (lines 355–462) extends the base SVE approach using multi-vector loads and stores.
  • SME2.1: the SME2.1 version uses movaz/svreadz_hor_za8_u8_vg4 to reinitialize ZA tile accumulators while moving data out to registers.
