To get started, clone the SIMD Loops project and change to the project directory:
git clone https://gitlab.arm.com/architecture/simd-loops simd-loops.git
cd simd-loops.git
Confirm that you are using an Arm machine:
uname -m
Expected output on Linux:
aarch64
Expected output on macOS:
arm64
In the SIMD Loops project, the source code for the loops is organized under the loops directory. The complete list of loops is documented in the loops.inc file, which includes a brief description and the purpose of each loop. Every loop is associated with a uniquely named source file following the pattern loop_<NNN>.c, where <NNN> represents the loop number.
A subset of the loops.inc file is below:
LOOP(001, "FP32 inner product", "Use of fp32 MLA instruction", STREAMING_COMPATIBLE)
LOOP(002, "UINT32 inner product", "Use of u32 MLA instruction", STREAMING_COMPATIBLE)
LOOP(003, "FP64 inner product", "Use of fp64 MLA instruction", STREAMING_COMPATIBLE)
LOOP(004, "UINT64 inner product", "Use of u64 MLA instruction", STREAMING_COMPATIBLE)
LOOP(005, "strlen short strings", "Use of FF and NF loads instructions")
LOOP(006, "strlen long strings", "Use of FF and NF loads instructions")
LOOP(008, "Precise fp64 add reduction", "Use of FADDA instructions")
LOOP(009, "Pointer chasing", "Use of CTERM and BRK instructions")
LOOP(010, "Conditional reduction (fp)", "Use of CLAST (SIMD&FP scalar) instructions", STREAMING_COMPATIBLE)
A loop is structured as follows:
// Includes and loop_<NNN>_data structure definition
#if defined(HAVE_NATIVE) || defined(HAVE_AUTOVEC)
// C reference or auto-vectorized version
void inner_loop_<NNN>(struct loop_<NNN>_data *data) { ... }
#if defined(HAVE_xxx_INTRINSICS)
// Intrinsics versions: xxx = SME, SVE, or SIMD (NEON)
#elif defined(<ASM_COND>)
// Hand-written inline assembly
// <ASM_COND> = __ARM_FEATURE_SME2p1, __ARM_FEATURE_SME2, __ARM_FEATURE_SVE2p1,
// __ARM_FEATURE_SVE2, __ARM_FEATURE_SVE, or __ARM_NEON
#else
#error "No implementations available for this target."
#endif
// Main of loop: buffer allocation, loop function call, result checking
Each loop is implemented in several SIMD extension variants. Conditional compilation selects one of the implementations for the inner_loop_<NNN> function.
The native C implementation is written first, and it can be generated either when building natively with -DHAVE_NATIVE or through compiler auto-vectorization with -DHAVE_AUTOVEC.
When SIMD ACLE is supported (SME, SVE, or Neon), the code is compiled using high-level intrinsics. If ACLE support is not available, the build process falls back to handwritten inline assembly targeting one of the available SIMD extensions, such as SME2.1, SME2, SVE2.1, SVE2, and others.
The overall code structure also includes setup and cleanup code in the main function, where memory buffers are allocated, the selected loop kernel is executed, and results are verified for correctness.
At compile time, you can select which loop optimization to compile, whether it is based on SME or SVE intrinsics, or one of the available inline assembly variants.
make
With no target specified, the list of targets is printed:
all fmt clean c-scalar scalar autovec-sve autovec-sve2 neon sve sve2 sme2 sme-ssve sve2p1 sme2p1 sve-intrinsics sme-intrinsics
Build all loops for all targets:
make all
Build all loops for a single target, such as Neon:
make neon
As a result of the build, two types of binaries are generated.
The first is a single executable named simd_loops, which includes all loop implementations.
Select a specific loop by passing parameters to the program. For example, to run loop 1 for 5 iterations using the Neon target:
build/neon/bin/simd_loops -k 1 -n 5
Example output:
Loop 001 - FP32 inner product
- Purpose: Use of fp32 MLA instruction
- Checksum correct.
The second type of binary is an individual loop.
To run loop 1 as a standalone binary:
build/neon/standalone/bin/loop_001.elf
Example output:
- Checksum correct.
