During the porting process, you can see that certain instructions translate seamlessly. However, there are cases where direct equivalents for some intrinsics might not be readily available across architectures.
For example, the
_mm_madd_epi16
intrinsic from SSE2, which performs multiplication of 16-bit signed integer elements in a vector and then does a pairwise addition of adjacent elements increasing the element width, does not have a direct counterpart in Neon. However, it can be emulated using another intrinsic. Similarly its 256 and 512-bit counterparts,
_mm256_madd_epi16
and
_mm512_madd_epi16
, can be emulated by a sequence of instructions, but here you will see the 128-bit variant.
You might already know the equivalent operations for this particular intrinsic, but let’s assume that you don’t. In this particular use case, reading _mm_madd_epi16 on SIMD.info might indicate that a key characteristic of the instruction involved is the widening of the result elements, from 16-bit to 32-bit signed integers. Unfortunately, this is not the case. This particular instruction does not increase the size of the element holding the result values. You will see how this affects the result in the example.
Consider the following code for SSE2. Create a new file on your x86_64 Linux machine named _mm_madd_epi16_test.c, and populate with the contents as shown below:
#include <stdint.h>
#include <immintrin.h>
#include <stdio.h>
void print_s16x8(char *label, __m128i v) {
int16_t out[8];
_mm_storeu_si128((__m128i*)out, v);
printf("%-*s: ", 30, label);
for (size_t i=0; i < 8; i++) printf("%4x ", (uint16_t)out[i]);
printf("\n");
int main() {
__m128i a = _mm_set_epi16(10, 30, 50, 70, 90, 110, 130, 150);
__m128i b = _mm_set_epi16(20, 40, 60, 80, 100, 120, 140, 160);
// 130 * 140 = 18200, 150 * 160 = 24000
// adding them as 32-bit signed integers -> 42000
// adding them as 16-bit signed integers -> -23336 (overflow!)
__m128i res = _mm_madd_epi16(a, b);
print_s16x8("a", a);
print_s16x8("b", b);
print_s16x8("_mm_madd_epi16(a, b)", res);
return 0;
Compile the code as follows on the x86_64 system. No extra flags are required as SSE2 is assumed by default on all 64-bit x86 systems:
gcc -O3 _mm_madd_epi16_test.c -o _mm_madd_epi16_test
Now run the program:
./_mm_madd_epi16_test
The output should look like:
a : 96 82 6e 5a 46 32 1e a
b : a0 8c 78 64 50 3c 28 14
_mm_madd_epi16(a, b) : a4d8 0 56b8 0 2198 0 578 0
You will note that the result of the first element is a negative number, even though you added 2 positive results (130*140 and 150*160). This is because the result of the addition has to occupy a 16-bit signed integer element, and when the first is larger we have the effect of a negative overflow. The result is the same in binary arithmetic, but when interpreted into a signed integer, it turns the number into a negative.
The rest of the values are as expected. Notice how each pair has a zero element next to it. The results are correct, but they are not in the correct order. In this example, you used vmovl to zero-extend values, which achieves the correct order with zero elements in place. While both vmovl and zip can be used for this purpose, vmovl was chosen in this implementation. For more details, see the Arm Software Optimization Guides, such as the
Neoverse V2 guide
Now switch to your Linux Arm machine and create a file called _mm_madd_epi16_neon.c, populating it with the contents below:
#include <arm_neon.h>
#include <stdint.h>
#include <stdio.h>
void print_s16x8(char *label, int16x8_t v) {
int16_t out[8];
vst1q_s16(out, v);
for (size_t i = 0; i < 8; i++) printf("%4x ", (uint16_t)out[i]);
printf("\n");
int16_t a_array[8] = {150, 130, 110, 90, 70, 50, 30, 10};
int16_t b_array[8] = {160, 140, 120, 100, 80, 60, 40, 20};
int main() {
int16x8_t a = vld1q_s16(a_array);
int16x8_t b = vld1q_s16(b_array);
int16x8_t zero = vdupq_n_s16(0);
int16x8_t res = vmulq_s16(a, b);
print_s16x8("vmulq_s16(a, b)", res);
res = vpaddq_s16(res, zero);
print_s16x8("vpaddq_s16(a, b)", res);
// vmovl_s16 would sign-extend; we just want to zero-extend
// so we need to cast to uint16, vmovl_u16 and then cast back to int16
uint16x4_t res_u16 = vget_low_u16(vreinterpretq_u16_s16(res));
res = vreinterpretq_s16_u32(vmovl_u16(res_u16));
print_s16x8("final", res);
return 0;
Compile the code on your Arm Linux machine:
gcc -O3 _mm_madd_epi16_neon.c -o _mm_madd_epi16_neon
./_mm_madd_epi16_neon.c
vmulq_s16(a, b) : 5dc0 4718 3390 2328 15e0 bb8 4b0 c8
vpaddq_s16(a, b) : a4d8 56b8 2198 578 0 0 0 0
final : a4d8 0 56b8 0 2198 0 578 0
As you can see, the results of both executions on different architectures match. You used SIMD.info to help with the translation of complex intrinsics between different SIMD architectures.
