Follow this step-by-step process to porting:
_mm_set_ps is in reality a macro, in Neon you can do the same thing with curly braces {} initialization.vst1q_f32
for storing 128-bit floating-point vectors and
vst1q_u32
for storing 128-bit integer vectors.After identifying the Neon intrinsics that you require in the ported program, it’s now time to write the code.
This time on your Arm Linux machine, create a new file for the ported Neon code named calculation_neon.c, populating with the contents as shown below:
#include <arm_neon.h>
#include <stdio.h>
float32_t a_array[4] = {1.0f, 4.0f, 9.0f, 16.0f};
float32_t b_array[4] = {1.0f, 2.0f, 3.0f, 4.0f};
int main() {
float32x4_t a = vld1q_f32(a_array);
float32x4_t b = vld1q_f32(b_array);
uint32x4_t cmp_result = vcgtq_f32(a, b);
float a_arr[4], b_arr[4];
uint32_t cmp_res[4];
vst1q_f32(a_arr, a);
vst1q_f32(b_arr, b);
vst1q_u32(cmp_res, cmp_result);
for (int i = 0; i < 4; i++) {
if (cmp_res[i] != 0) {
printf("Element %d: %.2f is larger than %.2f\n", i, a_arr[i], b_arr[i]);
} else {
printf("Element %d: %.2f is not larger than %.2f\n", i, a_arr[i], b_arr[i]);
printf("\n");
float32x4_t add_result = vaddq_f32(a, b);
float32x4_t mul_result = vmulq_f32(add_result, b);
float32x4_t sqrt_result = vsqrtq_f32(mul_result);
float res[4];
vst1q_f32(res, add_result);
printf("Addition Result: %.2f %.2f %.2f %.2f\n", res[0], res[1], res[2], res[3]);
vst1q_f32(res, mul_result);
printf("Multiplication Result: %.2f %.2f %.2f %.2f\n", res[0], res[1], res[2], res[3]);
vst1q_f32(res, sqrt_result);
printf("Square Root Result: %.2f %.2f %.2f %.2f\n", res[0], res[1], res[2], res[3]);
return 0;
It’s time to verify that the functionality remains the same, which means that you achieve the same results and similar performance.
Compile the above code as follows on your Arm Linux machine:
gcc -O3 calculation_neon.c -o calculation_neon
Now run the program:
./calculation_neon
The output should look like the following:
Element 0: 1.00 is not larger than 1.00
Element 1: 4.00 is larger than 2.00
Element 2: 9.00 is larger than 3.00
Element 3: 16.00 is larger than 4.00
Addition Result: 2.00 6.00 12.00 20.00
Multiplication Result: 2.00 12.00 36.00 80.00
Square Root Result: 1.41 3.46 6.00 8.94
You can see that the results are the same as in the SSE4.2 example.
You initialized the vectors in reverse order compared to the SSE4.2 version because the array initialization and vld1q_f32 function load vectors from LSB to MSB, whereas _mm_set_ps loads elements MSB to LSB.
