Create the sampler
To compute energy, you need power samples with a timestamp on each one. When you have timestamped samples, you can select only the samples that fall inside a measurement window.
The following sample polling script reads the power management integrated circuit (PMIC) at regular intervals. It records each reading with a timestamp.
Create a working directory:
mkdir -p $HOME/pi-energy
cd $HOME/pi-energy
Use a text editor to save the following code as pmic_sampler.py in the working directory:
#!/usr/bin/env python3
"""Log Raspberry Pi 5 PMIC rail power to a CSV file until stopped.
Every sample runs `vcgencmd pmic_read_adc`, pairs each rail's current (_A)
with its voltage (_V), and writes one CSV row: time, total watts, then watts
per rail. With --rail NAME only that rail is read (two short reads per
sample), which is several times faster.
import argparse
import re
import signal
import subprocess
import sys
import time
LINE = re.compile(r"^\s*(\S+)_([AV]) (?:current|volt)\(\d+\)=([-0-9.]+)[AV]\s*$")
def read_adc(channel=None):
    cmd = ["vcgencmd", "pmic_read_adc"]
    if channel:
        cmd.append(channel)
    out = subprocess.run(cmd, capture_output=True, text=True, check=True).stdout
    amps, volts = {}, {}
    for line in out.splitlines():
        m = LINE.match(line)
        if m:
            name, kind, value = m.group(1), m.group(2), float(m.group(3))
            (amps if kind == "A" else volts)[name] = value
    return amps, volts
def rail_power(rail=None):
    if rail:
        amps, _ = read_adc(rail + "_A")
        _, volts = read_adc(rail + "_V")
    else:
        amps, volts = read_adc()
    return {n: amps[n] * volts[n] for n in sorted(amps) if n in volts}
def main():
    ap = argparse.ArgumentParser(description=__doc__)
    ap.add_argument("csv", help="output CSV file")
    ap.add_argument("--rail", help="read only this rail, for example VDD_CORE")
    ap.add_argument("--duration", type=float, default=0,
                    help="stop after this many seconds (default: run until stopped)")
    args = ap.parse_args()
    stop = []
    signal.signal(signal.SIGTERM, lambda *_: stop.append(1))
    signal.signal(signal.SIGINT, lambda *_: stop.append(1))
    rails = sorted(rail_power(args.rail))
    if not rails:
        sys.exit("no rail has both a current and a voltage reading")
    t_end = time.time() + args.duration if args.duration else None
    n = 0
    with open(args.csv, "w", buffering=1) as f:
        f.write("time_s,total_W," + ",".join(r + "_W" for r in rails) + "\n")
        while not stop and (t_end is None or time.time() < t_end):
            t0 = time.time()
            p = rail_power(args.rail)
            t1 = time.time()
            # time stamp the middle of the read
            f.write("%.4f,%.4f,%s\n" % ((t0 + t1) / 2, sum(p.values()),
                                        ",".join("%.4f" % p.get(r, 0.0) for r in rails)))
            n += 1
    print("wrote %d samples to %s" % (n, args.csv), file=sys.stderr)
if __name__ == "__main__":
    main()
The script calls vcgencmd pmic_read_adc and matches the current line of each rail (power supply output) with its voltage line. It then writes one row per sample:
  • time_s is the wall-clock time, in seconds, at the middle of the read.
  • total_W is the sum of the power of all rails that report both a current and a voltage.
  • One column per rail follows, in watts.
The script stops cleanly when it receives Ctrl+C, a SIGINT or SIGTERM signal, or after --duration seconds.
Log an idle board
Make sure nothing else is running, then log ten seconds of idle power:
python3 pmic_sampler.py idle.csv --duration 10
head -3 idle.csv | cut -c1-120
The output is similar to:
        wrote 404 samples to idle.csv
time_s,total_W,0V8_AON_W,0V8_SW_W,1V1_SYS_W,1V8_SYS_W,3V3_ADC_W,3V3_DAC_W,3V3_SYS_W,3V7_WL_SW_W,DDR_VDD2_W,DDR_VDDQ_W,HD
1791953741.3029,1.8872,0.0024,0.2130,0.1940,0.2904,0.0012,0.0000,0.3165,0.3327,0.0000,0.0000,0.1275,0.4094
1791953741.3292,1.7417,0.0023,0.2150,0.1941,0.2891,0.0024,0.0000,0.1841,0.3256,0.0000,0.0000,0.1287,0.4003
Count the samples and compute the mean power with a one-line Python command:
python3 -c "import csv,statistics as s; r=list(csv.DictReader(open('idle.csv'))); print(len(r), 'samples', round(s.fmean(float(x['total_W']) for x in r), 3), 'W')"
        404 samples 1.752 W
Sample one rail faster
If you need only one rail, pass --rail. The sampler then reads the current and voltage channels of only that rail:
python3 pmic_sampler.py core.csv --rail VDD_CORE --duration 10
python3 -c "import csv; r=list(csv.DictReader(open('core.csv'))); print(len(r), 'samples')"
        wrote 1386 samples to core.csv
1386 samples
Note
The sampler runs on the same four Cortex-A76 cores as the workload that you measure. Each sample starts a vcgencmd process. Logging at a higher rate costs more CPU time. You’ll measure how much this slows down llama.cpp, so that you can decide whether the overhead matters for your measurement.
You can now log power with timestamps.
Next, you’ll line these samples up with llama.cpp token generation and compute joules per token.
