Build llama-bench and download a model
If you already have llama-bench built in $HOME/llama.cpp, skip the build commands. Otherwise, install the build tools and build only the llama-bench target with one compile job:
sudo apt update
sudo apt install -y git cmake build-essential
cd $HOME
git clone https://github.com/ggml-org/llama.cpp
cd llama.cpp
cmake -B build -DCMAKE_BUILD_TYPE=Release
cmake --build build --target llama-bench -j 1
This keeps memory use low on a 2 GB board.
Your token rates and energy results might differ from the example outputs because llama.cpp changes frequently.
Download the Qwen2.5 0.5B Instruct model in the Q4_0 format:
mkdir -p $HOME/models
cd $HOME/models
wget https://huggingface.co/Qwen/Qwen2.5-0.5B-Instruct-GGUF/resolve/9217f5db79a29953eb74d5343926648285ec7e67/qwen2.5-0.5b-instruct-q4_0.gguf
The size of the file is about 429 MB.
Measure only the token-generation phase
A llama-bench process first loads the model, then runs a warmup. Only then does the process run the timed repetitions. Loading reads the whole file from storage and draws a different amount of power than token generation. If you average power over the whole process, the result mixes the two and depends on how long loading took.
To exclude loading, the energy_per_token.py script runs llama-bench with --progress. With this option, llama-bench prints a line such as generation run 1/3 immediately before each timed repetition starts. The script records a timestamp for each line as it arrives. The length of each repetition comes from llama-bench, in the samples_ns field of its JSON output. Every repetition therefore has a known start and end time. The script averages only the power samples inside that window.
The script also records an idle window before llama-bench starts. It saves the output of vcgencmd get_throttled and the temperature before and after the run.
The script starts pmic_sampler.py from its own directory. Both files need to be in the same directory.
Change to the working directory that you created earlier:
cd $HOME/pi-energy
Use a text editor to save the following code as energy_per_token.py in $HOME/pi-energy:
#!/usr/bin/env python3
"""Measure joules per generated token for llama.cpp on a Raspberry Pi 5.
1. Start pmic_sampler.py in the background.
2. Record an idle window with nothing else running.
3. Run llama-bench (generation only) with --progress and time stamp each
   "generation run" line, so every repetition has a known start time. Its
   length comes from llama-bench's own samples_ns.
4. Average the PMIC power inside each decode window only (model load and
   warmup are excluded) and convert to joules per token, with and without
   the idle power subtracted.
import argparse
import csv
import json
import os
import statistics
import subprocess
import sys
import time
HERE = os.path.dirname(os.path.abspath(__file__))
def vc(*args):
    return subprocess.run(["vcgencmd", *args], capture_output=True, text=True).stdout.strip()
def mean_power(rows, t0, t1, col):
    vals = [float(r[col]) for r in rows if t0 <= float(r["time_s"]) <= t1]
    return (statistics.fmean(vals) if vals else float("nan")), len(vals)
def main():
    ap = argparse.ArgumentParser(description=__doc__,
                                 formatter_class=argparse.RawDescriptionHelpFormatter)
    ap.add_argument("-m", "--model", required=True, help="GGUF model file")
    ap.add_argument("-t", "--threads", type=int, default=4)
    ap.add_argument("-n", "--n-gen", type=int, default=128, help="tokens per repetition")
    ap.add_argument("-r", "--reps", type=int, default=3, help="llama-bench repetitions")
    ap.add_argument("--idle", type=float, default=10.0, help="idle window in seconds")
    ap.add_argument("--rail", help="pass to the sampler to read one rail only")
    ap.add_argument("--llama-bench", default=os.path.expanduser("~/llama.cpp/build/bin/llama-bench"))
    ap.add_argument("--out", default="energy_run", help="output directory")
    args = ap.parse_args()
    os.makedirs(args.out, exist_ok=True)
    power_csv = os.path.join(args.out, "power.csv")
    before = {"throttled": vc("get_throttled"), "temp": vc("measure_temp"),
              "arm_clock_hz": vc("measure_clock", "arm")}
    cmd = [sys.executable, os.path.join(HERE, "pmic_sampler.py"), power_csv]
    if args.rail:
        cmd += ["--rail", args.rail]
    sampler = subprocess.Popen(cmd)
    time.sleep(1.0)                      # let the sampler write its header
    idle_start = time.time()
    time.sleep(args.idle)
    idle_end = time.time()
    bench = [args.llama_bench, "-m", args.model, "-p", "0", "-n", str(args.n_gen),
             "-r", str(args.reps), "-t", str(args.threads), "--progress", "-o", "json"]
    proc = subprocess.Popen(bench, stdout=subprocess.PIPE, stderr=subprocess.PIPE, text=True)
    starts = []
    with open(os.path.join(args.out, "llama-bench.stderr"), "w") as err:
        for line in proc.stderr:
            now = time.time()
            err.write("%.4f %s" % (now, line))
            if ": generation run " in line:
                starts.append(now)
    result = json.loads(proc.stdout.read())[0]
    proc.wait()
    time.sleep(0.5)
    sampler.terminate()
    sampler.wait()
    after = {"throttled": vc("get_throttled"), "temp": vc("measure_temp")}
    with open(power_csv) as f:
        rows = list(csv.DictReader(f))
    col = "total_W" if not args.rail else args.rail + "_W"
    idle_w, idle_n = mean_power(rows, idle_start, idle_end, col)
    reps = []
    for start, ns in zip(starts, result["samples_ns"]):
        dur = ns / 1e9
        load_w, n = mean_power(rows, start, start + dur, col)
        reps.append({"start": start, "seconds": dur, "samples": n,
                     "tokens_per_s": args.n_gen / dur, "power_W": load_w,
                     "J_per_token": load_w * dur / args.n_gen,
                     "net_J_per_token": (load_w - idle_w) * dur / args.n_gen})
    summary = {"model": os.path.basename(args.model), "threads": args.threads,
               "n_gen": args.n_gen, "rail": col, "idle_W": idle_w, "idle_samples": idle_n,
               "before": before, "after": after, "build_commit": result.get("build_commit"),
               "reps": reps}
    with open(os.path.join(args.out, "summary.json"), "w") as f:
        json.dump(summary, f, indent=1)
    print("idle %s: %.3f W (%d samples)" % (col, idle_w, idle_n))
    print("rep  tok/s   power_W  J/token  net_J/token  samples")
    for i, r in enumerate(reps, 1):
        print("%3d  %6.2f  %7.3f  %7.4f  %11.4f  %7d" % (
            i, r["tokens_per_s"], r["power_W"], r["J_per_token"], r["net_J_per_token"], r["samples"]))
    print("throttled before %s after %s; %s -> %s" % (
        before["throttled"], after["throttled"], before["temp"], after["temp"]))
    if after["throttled"] != "throttled=0x0" or before["throttled"] != "throttled=0x0":
        print("WARNING: the board reported throttling; do not trust this run", file=sys.stderr)
if __name__ == "__main__":
    main()
For each repetition, the script computes the following values:
  • power_W: the mean power of the rail sum inside the token-generation window.
  • J/token: power_W multiplied by the window length, divided by the number of tokens. This is the energy the measured rails used per token, including the power the board draws when idle.
  • net_J/token: the same calculation with the idle power subtracted first. This is the extra energy that token generation adds to an idle board.
The value that you need depends on the question that you want to answer. If the board is dedicated to the model and would otherwise be off, use J/token. If the board stays on anyway and you want the cost of the extra work, use net_J/token.
Run the measurement
Check that the board is idle and not throttling, then run four threads and 128 generated tokens per repetition:
cd $HOME/pi-energy
uptime
python3 energy_per_token.py -m $HOME/models/qwen2.5-0.5b-instruct-q4_0.gguf -t 4 --out run_t4
The output is similar to:
         05:56:03 up 28 days,  4:33,  2 users,  load average: 0.76, 1.64, 1.84
throttled=0x0
wrote 1085 samples to run_t4/power.csv
idle total_W: 1.720 W (420 samples)
  1   24.31    5.256   0.2162       0.1455      188
  2   24.32    5.340   0.2196       0.1489      191
  3   24.20    5.329   0.2202       0.1491      188
throttled before throttled=0x0 after throttled=0x0; temp=47.2'C -> temp=49.9'C
The samples column shows how many power samples fall inside each window. Aim for at least 50, because a short window gives a noisy mean. To lengthen the window, increase the number of tokens generated in each repetition with the -n option of energy_per_token.py. The default is 128, so -n 256 roughly doubles the window length and the number of samples.
The throttled values before and after the run have to both be throttled=0x0. If they aren’t, the clock was reduced during the run and the result isn’t valid.
The run directory contains power.csv with every sample. It also contains llama-bench.stderr with the timestamped progress lines, and summary.json with the per-repetition results. You can check every number later.
Check the window alignment
Print the power around the generation windows to confirm that each window starts where power rises. The following command prints the mean power for each second, starting at the idle window. It marks with G each second whose midpoint falls inside a generation window:
python3 - <<'PY'
import csv, json
s = json.load(open("run_t4/summary.json"))
rows = list(csv.DictReader(open("run_t4/power.csv")))
t0 = float(rows[0]["time_s"])
gen = [(r["start"], r["start"] + r["seconds"]) for r in s["reps"]]
for sec in range(int(float(rows[-1]["time_s"]) - t0)):
    w = [float(x["total_W"]) for x in rows if t0 + sec <= float(x["time_s"]) < t0 + sec + 1]
    mid = t0 + sec + 0.5
    tag = "G" if any(a <= mid <= b for a, b in gen) else ""
    print("%3d s %5.2f W %s" % (sec, sum(w) / len(w), tag))
PY
          0 s  1.75 W
  1 s  1.76 W
  2 s  1.77 W
  3 s  1.75 W
  4 s  1.75 W
  5 s  1.66 W
  6 s  1.60 W
  7 s  1.79 W
  8 s  1.67 W
  9 s  1.61 W
 10 s  1.92 W
 11 s  3.62 W
 12 s  5.27 W G
 13 s  5.33 W G
 14 s  5.12 W G
 15 s  5.22 W G
 16 s  5.36 W G
 17 s  5.36 W G
 18 s  5.28 W G
 19 s  5.36 W G
 20 s  5.33 W G
 21 s  5.36 W G
 22 s  5.36 W G
 23 s  5.29 W G
 24 s  5.36 W G
 25 s  5.34 W G
 26 s  5.31 W G
 27 s  3.91 W G
Seconds 0 to 9 are the idle window, at about 1.7 W. Power starts to rise at second 10, while llama-bench loads the model and runs its warmup. The first G second then follows. Within the generation windows, the rail sum stays between 5.1 W and 5.4 W. The last second is lower because it only partly overlaps the end of the run.
If the G marks start before the power rises, or long after it, the timestamps and the power samples aren’t aligned. The result in that case isn’t valid.
You’ve now measured joules per token for one setting.
Next, you’ll repeat the measurement across clock frequencies and thread counts to find the most efficient setting on your board.
