Cap the CPU clock
The Linux cpufreq interface sets the highest frequency that the CPU governor can choose. On the Raspberry Pi 5, all four cores share one frequency policy, policy0. Check the governor, the available frequencies, and the current maximum frequency:
cat /sys/devices/system/cpu/cpufreq/policy0/scaling_governor
cat /sys/devices/system/cpu/cpufreq/policy0/scaling_available_frequencies
cat /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq
The output is similar to:
        ondemand
1500000 1600000 1700000 1800000 1900000 2000000 2100000 2200000 2300000 2400000
2400000
The values are in kHz. The ondemand governor is the Raspberry Pi OS default. With ondemand, the CPU runs at the lowest frequency when idle and moves to scaling_max_freq under load.
Writing a lower value to scaling_max_freq caps the clock:
echo 2000000 | sudo tee /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq
To confirm that the cap holds while llama.cpp generates tokens, read the current frequency during a run:
$HOME/llama.cpp/build/bin/llama-bench -m $HOME/models/qwen2.5-0.5b-instruct-q4_0.gguf -p 0 -n 256 -r 1 -t 1 > /dev/null 2>&1 &
sleep 5; cat /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq; wait
The expected output is:
        2000000
Note
If your governor isn’t ondemand, for example userspace or powersave, the CPU doesn’t move to scaling_max_freq under load. Set the governor with echo ondemand | sudo tee /sys/devices/system/cpu/cpufreq/policy0/scaling_governor before you run the sweep. Then, record the governor with your results.
Run the sweep
The following loop measures three clock caps and three thread counts. Each run takes about 30 seconds, so the loop takes about five minutes:
cd $HOME/pi-energy
MODEL=$HOME/models/qwen2.5-0.5b-instruct-q4_0.gguf
for cap in 1500000 2000000 2400000; do
  echo $cap | sudo tee /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq > /dev/null
  for t in 1 2 4; do
    python3 energy_per_token.py -m $MODEL -t $t --out sweep_${cap}_t$t > sweep_${cap}_t$t.txt
  done
done
echo 2400000 | sudo tee /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq > /dev/null
The last line restores the default maximum frequency of 2.4 GHz.
Summarize the runs in one table:
python3 - <<'PY'
import glob, json, statistics as st
print("cap_GHz threads tok/s  power_W idle_W J/token net_J/token")
for f in sorted(glob.glob("sweep_*_t*/summary.json")):
    s = json.load(open(f))
    cap = int(f.split("_")[1]) / 1e6
    m = lambda k: st.fmean(r[k] for r in s["reps"])
    print("%7.1f %7d %6.2f %7.3f %6.3f %7.4f %11.4f" % (cap, s["threads"],
          m("tokens_per_s"), m("power_W"), s["idle_W"], m("J_per_token"), m("net_J_per_token")))
PY
    1.5       1  21.68   2.937  1.755  0.1355      0.0545
    1.5       2  26.12   4.044  1.629  0.1548      0.0924
    1.5       4  22.36   4.038  1.523  0.1805      0.1125
    2.0       1  26.87   3.414  1.589  0.1271      0.0679
    2.0       2  28.47   4.068  1.445  0.1429      0.0921
    2.0       4  23.27   4.227  1.558  0.1816      0.1146
    2.4       1  31.96   4.170  1.497  0.1305      0.0836
    2.4       2  31.49   4.833  1.564  0.1535      0.1038
    2.4       4  23.96   5.177  1.595  0.2162      0.1496
Read the results
Your numbers will differ from these, but look for the following patterns:
  • How tokens per second changes with the thread count
  • Whether a lower clock reduces the total J per token or only the net J per token
Also compare the idle_W column across runs. On the example board, the idle power moved between about 1.45 W and 1.76 W from run to run. Almost all of this change was on the Wi-Fi rail 3V7_WL_SW. This is because the board was controlled over SSH through Wi-Fi. A change of this size can reorder settings that are close, so a single sweep isn’t enough to rank them.
Repeat the sweep before making a decision
The idle power and the temperature drift between runs. Repeat the sweep at least five times, alternating the order of the settings, before you trust a difference of a few percent. For the example board, five passes in alternating order gave the following means:
Clock capThreadsTokens per secondRail sum during generation (W)J per tokenNet J per token
1.5 GHz121.692.830.13050.0570
1.5 GHz226.094.110.15760.0945
1.5 GHz421.984.040.18390.1084
2.0 GHz126.933.460.12850.0684
2.0 GHz228.434.030.14180.0857
2.0 GHz423.384.290.18330.1148
2.4 GHz131.944.230.13230.0817
2.4 GHz231.514.820.15290.1020
2.4 GHz424.025.120.21310.1451
Across the five passes, the tokens per second of each setting varied by 1.2% or less (coefficient of variation). The J per token varied by 3.8% or less, and the net J per token varied by 6.7% or less. get_throttled returned throttled=0x0 before and after every run. The system-on-chip (SoC) temperature stayed between 45°C and 51°C.
Four threads is the worst setting at every clock cap. At 2.4 GHz, it costs 61% more energy per token than one thread while running 25% slower. This is despite four being the thread count that llama-bench uses by default on the board. Token generation for this model is limited by memory bandwidth. Extra threads therefore add power on VDD_CORE without adding tokens.
With one thread, the three clock caps are within 3% of each other in total J per token. That’s inside the run-to-run variation, so this data doesn’t rank them. A lower clock reduces the power, but each token takes longer. As a result, the board draws its idle power for longer too.
The net J per token depends on the clock. One thread at 1.5 GHz uses 30% less net energy per token than one thread at 2.4 GHz. However, it generates 32% fewer tokens per second.
Most of the extra power during generation is on VDD_CORE. With one thread at 2.4 GHz, VDD_CORE rises from 0.42 W at idle to 2.62 W. This is about 85% of the rise of the rail sum.
Which setting is best depends on what you pay for. If the board runs only this model, the total energy per token is the decider. One thread at any clock cap is close to the best. If the board stays on for other work, the net energy per token is the decider. A lower clock saves energy at the cost of speed.
Measure the cost of the sampler
The sampler competes with llama.cpp for the four cores. At 2.4 GHz, compare llama-bench alone with the same run under the full-rail sampler and the single-rail sampler:
cd $HOME/pi-energy
for t in 1 4; do
  $HOME/llama.cpp/build/bin/llama-bench -m $MODEL -p 0 -n 128 -r 3 -t $t -o csv 2>/dev/null | tail -1 | awk -F, -v t=$t '{gsub(/"/, ""); printf "threads %d none %.2f tok/s\n", t, $(NF-1)}'
  python3 energy_per_token.py -m $MODEL -t $t --out over_full_t$t | awk -v t=$t '/^ +[0-9]+ / {s+=$2; n++} END {printf "threads %d full %.2f tok/s\n", t, s/n}'
  python3 energy_per_token.py -m $MODEL -t $t --rail VDD_CORE --out over_core_t$t | awk -v t=$t '/^ +[0-9]+ / {s+=$2; n++} END {printf "threads %d core %.2f tok/s\n", t, s/n}'
done
In the output, none means no sampler and full means the full-rail sampler. core means the single-rail sampler reading VDD_CORE.
        threads 1 none 32.42 tok/s
wrote 1002 samples to over_full_t1/power.csv
threads 1 full 31.91 tok/s
wrote 3479 samples to over_core_t1/power.csv
threads 1 core 29.94 tok/s
threads 4 none 25.23 tok/s
wrote 1098 samples to over_full_t4/power.csv
threads 4 full 24.25 tok/s
wrote 3027 samples to over_core_t4/power.csv
threads 4 core 21.74 tok/s
The full-rail sampler reads about 40 samples per second. It slows token generation by about 2% with one thread and 4% with four threads. The single-rail sampler reads more often, about 100 to 140 samples per second. It costs more: about 8% with one thread and 14% with four threads.
Over five alternating passes on the example board, the full-rail sampler slowed generation by 1.8% with one thread. It slowed generation by 4.5% with four threads. The single-rail sampler slowed generation by 8.0% and 14.0%, respectively. Both samplers reported the same VDD_CORE power during generation, within 0.5%.
The full-rail sampler already gives more than 150 samples in each 128-token window. A faster sampler adds overhead without making the average more precise. Use the single-rail mode only when you need to see short changes in power. Report the slowdown with your results.
What you’ve accomplished
You’ve now compared joules per token across clock caps and thread counts.
You can extend the Learning Path for any workload that prints a marker when its measured phase starts. For other models, replace the GGUF file and repeat the sweep.
