Give feedback
AI-assisted
Close
How do I check whether the Raspberry Pi 5 exposes power data through hwmon?
You can list the sensors under /sys/class/hwmon/ and check for power or current files. On the Raspberry Pi 5, you use vcgencmd pmic_read_adc to read current and voltage from the onboard PMIC rails instead.
What does the PMIC sampling script write?
You choose the output CSV path when you run pmic_sampler.py, for example idle.csv in your working directory. In your CSV, each row contains time_s, total_W, and a watts column for each rail with both current and voltage readings.
How do I align power samples with token generation?
When you run energy_per_token.py, it starts the sampler before llama-bench. You can trace each generation window from the script timestamp for a --progress start marker, and the corresponding samples_ns duration. The script selects samples inside that window.
How do I calculate joules per token with and without idle power?
Multiply the mean power during a generation window by its duration, then divide by the generated token count for J/token. For net_J/token, subtract the measured idle baseline from the mean window power before multiplying and dividing.
How should I compare clock caps and thread counts?
Set scaling_max_freq and check scaling_cur_freq during token generation to confirm the cap. Then, repeat the sweep at least five times, alternating the setting order. Compare J/token and net_J/token separately, and avoid ranking settings whose differences fall within run-to-run variation.
