Build a ROS 2 and Zenoh simulation environment on an Arm server
Start the ROS 2 development containers
Configure Zenoh for ROS 2
Observe Zenoh router discovery behavior
Start the robot simulation and Navigation2
Visualize and navigate the robot with RViz
Control the Neobotix ROX robot with ROS 2
Observe ROS 2 simulation resource usage on an Arm server
Enable Zenoh shared-memory transport
Understand the router experiment
The Zenoh router helps ROS 2 nodes discover each other. When nodes start, they connect to the router, exchange locator information, and establish direct peer-to-peer links.
You can examine this behavior by stopping the router after a talker and listener have connected. If their established communication continues, the router isn’t carrying the messages between these two processes.
Open three bash shells in the robot container to observe router discovery behavior. Source the environment in each shell:
source ~/workshop_env.bash
Start the router
In the first shell, start the Zenoh router:
just router
The output is similar to:
Started Zenoh router with id 84e303525488529a304c8990ad9bed73
The router ID can differ on your system.
Start the ROS 2 nodes
In the second shell, start the talker:
ros2 run demo_nodes_cpp talker
In the third shell, start the listener:
ros2 run demo_nodes_cpp listener
The listener should receive every message published by the talker. The output is similar to:
[INFO] [listener]: I heard: [Hello World: 9]
[INFO] [listener]: I heard: [Hello World: 10]
Stop the router and observe the result
Press Ctrl+C in the first shell to stop the router. Keep watching the talker and listener.
The message exchange should continue without interruption. The two nodes already established a direct peer-to-peer connection, so the router isn’t in this data path. This result demonstrates the router’s discovery role for this established local connection. However, it doesn’t imply that every Zenoh topology can operate without a router.
Nodes can also start before the router because each node periodically retries the router connection.
Restart the router in the first shell before continuing:
just router
You’ve observed that the router enables discovery while an established talker and listener continue to communicate directly after it stops.
Next, you’ll replace the demonstration nodes with the Neobotix ROX simulation and Navigation2.
