Build a ROS 2 and Zenoh simulation environment on an Arm server
Start the ROS 2 development containers
Configure Zenoh for ROS 2
Observe Zenoh router discovery behavior
Start the robot simulation and Navigation2
Visualize and navigate the robot with RViz
Control the Neobotix ROX robot with ROS 2
Observe ROS 2 simulation resource usage on an Arm server
Enable Zenoh shared-memory transport
Confirm the containers are running and that your Arm server allows access to the published web ports. Ensure network access to ports
6080 and 6081 is available from your client.Run
docker ps, copy the CONTAINER ID for ros_zenoh-robot-1, then run docker exec -it <container_id> /bin/bash in each shell. In every shell, run source ~/workshop_env.bash.You’ll see the talker and listener continue communicating without interruption. This shows that you established a direct peer-to-peer connection and that the router isn’t carrying their messages.
Yes. After the router experiment, stop the talker and listener but keep the router running before starting the simulation and Navigation2.
Expect to see the robot model, map, global and local costmaps, and sensor visualizations. Use Nav2 Goal to set a navigation target and watch the robot plan and move in RViz.
