Before you begin
Run every command on your Arm-based Linux machine. Ensure that you’re using Ubuntu 22.04 or later on an aarch64 host, such as a Raspberry Pi 5 or an Arm-based cloud instance.
Confirm the architecture:
uname -m
The expected output is:
aarch64
By the end of setup, you’ll have the following:
- A ROS 2 Humble container publishing a demo topic
- A Python virtual environment with the Device Connect packages
- The
ros2-device-connectadapter cloned and ready to run
Install Docker
The adapter talks to ROS 2 through Docker, so you need Docker Engine. To install Docker Engine, follow the
Docker Engine install guide
, including the step that adds your user to the docker group. The adapter runs docker exec as your user, so Docker needs to work without sudo.
Verify that Docker is installed and that you can connect to the Docker daemon without sudo:
docker version
The command should display version information for both the Docker client and server.
Start a ROS 2 container
You don’t need to install ROS 2 on the host. The official ros:humble image is multi-architecture, so Docker pulls the arm64 variant automatically. If you prefer a native install, see the
ROS 2 install guide
Start a long-running container named ros2_test:
docker run -d --name ros2_test ros:humble tail -f /dev/null
The tail -f /dev/null command keeps the container alive so that you can run ROS 2 commands inside it with docker exec. Start a demo publisher that sends a std_msgs/msg/String message on the /chatter topic once per second:
docker exec -d ros2_test bash -lc 'source /opt/ros/humble/setup.bash && ros2 topic pub -r 1 /chatter std_msgs/msg/String "{data: hello}"'
Check that the topic is being published:
docker exec ros2_test bash -lc 'source /opt/ros/humble/setup.bash && ros2 node list && ros2 topic list'
The output lists the ROS 2 topics:
/chatter
/parameter_events
/rosout
The node list is empty because ros2 topic pub runs as a hidden node. The container now stands in for a real robot’s ROS 2 stack.
Create the workspace
The adapter’s launch scripts expect a single project directory that holds the adapter repository and a Python virtual environment named .venv. Create the directory and clone both the adapter and the Device Connect source:
mkdir -p ~/device_connect
cd ~/device_connect
git clone --branch ros2_dc_lp https://github.com/odincodeshen/ros2-device-connect.git
git clone https://github.com/arm/device-connect.git
The adapter is cloned at the ros2_dc_lp tag, which is the version that the Learning Path was tested with.
Install uv and the Device Connect packages
Install uv to create the Python environment:
curl -LsSf https://astral.sh/uv/install.sh | sh
export PATH="$HOME/.local/bin:$PATH"
uv --version
Create a Python virtual environment in the project directory, and install the Device Connect edge SDK and agent tools from the cloned source:
The Device Connect packages require Python 3.11 or later and are tested on Python 3.11, 3.12, and 3.13. Python 3.12 is used in the commands as an example, but you can pass any supported version to --python. If the version isn’t installed on your machine, uv downloads it for you.
The host Python environment is separate from the Python version inside the ROS 2 container. Your choice here doesn’t need to match your ROS 2 distribution.
cd ~/device_connect
uv venv --python 3.12 .venv
VIRTUAL_ENV=.venv uv pip install \
-e device-connect/packages/device-connect-edge \
-e device-connect/packages/device-connect-agent-tools
The device-connect-edge package is the device runtime that the adapter runs on. The device-connect-agent-tools package is the client that you’ll use to discover the adapter and call its RPCs.
Verify that both packages import:
.venv/bin/python -c "import device_connect_edge, device_connect_agent_tools; print('Device Connect OK')"
Device Connect OK
Your workspace now looks like this:
~/device_connect/
├── .venv/ # Python environment with Device Connect
├── device-connect/ # Device Connect SDK source
└── ros2-device-connect/ # ROS 2 adapter
You’ve installed Docker and started a ROS 2 Humble container publishing on /chatter. You’ve also created a Python environment with the Device Connect packages next to the ros2-device-connect adapter.
Next, you’ll see how the adapter code works, start it in device-to-device mode, and query the ROS 2 container through Device Connect.
