The programming pattern: four components around one ROS 2 command
The adapter doesn’t add a new way to talk to Robot Operating System 2 (ROS 2). It wraps the same ros2 command that you ran from your terminal during setup, one component at a time. Each component adds one thing to the component beneath it:
| Component | What it is | What it adds | Example |
| ROS 2 command | A ros2 CLI call run in the container from the host | The ROS 2 query itself | docker exec ros2_test ... ros2 topic list |
| Python wrapper | run_ros() | The same command, called from Python and returning structured output | run_ros("ros2 topic list") |
| Remote procedure calls (RPCs) | An @rpc method on Ros2InspectionMixin | A named function that peers and agents can discover and call over the network | get_ros_topics() |
| Device | A driver class run by DeviceRuntime | A device that bundles those RPCs and joins the network | PuppyPiRos2Driver |
The ROS 2 command component is all you need when you have a shell on the machine. The Python wrapper, RPCs, and device components let a caller without shell access run the same query safely and by name.
The following code excerpts are simplified to show the pattern. The full versions are in ros2_common.py and puppypi_device.py in the repository.
Run a ROS 2 command in the container
You’ve already used this component. From the host, docker exec runs a ros2 command inside the container after sourcing the ROS 2 environment:
docker exec ros2_test bash -lc 'source /opt/ros/humble/setup.bash && ros2 topic list'
The output is similar to:
/chatter
/parameter_events
/rosout
Every RPC in this Learning Path ends up running a command such as this one.
Wrap the command in Python
run_ros() in ros2_common.py builds that same docker exec command:
def run_ros(command: str, timeout: float = 10.0) -> dict[str, Any]:
script = f"source {ROS_SETUP} && source {WORKSPACE_SETUP} && {command}"
return run(["docker", "exec", "-u", EXEC_USER, CONTAINER, "bash", "-lc", script], timeout=timeout)
The container name, user, and setup scripts come from environment variables. The same function therefore works with any ROS 2 container. It returns a dictionary with ok, stdout, and stderr instead of printed text. A timeout stops a stalled ROS 2 command from hanging the adapter.
Expose the command as an RPC
Ros2InspectionMixin turns run_ros() calls into Device Connect RPCs. The @rpc() decorator is what makes a method discoverable and callable over the network:
class Ros2InspectionMixin:
@rpc()
async def get_ros_topics(self, limit: int = 200, contains: str = "") -> dict[str, Any]:
"""List active ROS2 topics."""
return lines(run_ros("ros2 topic list"), limit=limit, contains=contains)
@rpc()
async def get_topic_info(self, topic: str) -> dict[str, Any]:
"""Return read-only metadata for a specific ROS2 topic."""
if not TOPIC_NAME_RE.fullmatch(topic):
return {"ok": False, "error": "topic must match ^/[A-Za-z0-9_/]+$"}
return run_ros(f"ros2 topic info {topic}")
This is also where you apply safety rules, because it’s the boundary where remote input arrives. get_ros_topics caps and filters its output with the lines() helper. get_topic_info validates the topic name before it reaches a shell command.
The mixin provides six inspection RPCs in total for the following:
- Nodes
- Topics
- Services
- Packages
- Interfaces
- Topic information
The inspection RPCs all follow the same pattern.
The following table shows how the shared inspection and hardware-specific RPCs map to the ROS 2 operations that they run or wrap:
| Device Connect RPC | ROS 2 operation inside the container | Purpose |
get_ros_nodes() | ros2 node list | List active ROS 2 nodes |
get_ros_topics() | ros2 topic list | List active ROS 2 topics |
get_ros_services() | ros2 service list | List active ROS 2 services |
get_ros_packages() | ros2 pkg list | List installed ROS 2 packages |
get_ros_interfaces() | ros2 interface list | List available ROS 2 message and service interfaces |
get_topic_info(topic) | ros2 topic info <topic> | Inspect one topic after validating the topic name |
get_raw_image() | Subscribe to /image_raw, then JPEG or base64 encode one frame | Expose a camera stream as a callable perception RPC |
run_action(action) | Call /puppy_control/runActionGroup with an allowlisted action file | Run a pre-approved PuppyPi motion |
set_velocity(x, y, yaw_rate) | Publish once to /puppy_control/velocity | Send a bounded PuppyPi velocity command |
stop() | Publish a zero-velocity command | Stop PuppyPi motion |
Device Connect doesn’t replace ROS 2. It wraps selected ROS 2 operations as discoverable, typed, remotely callable capabilities.
Build the device
The final component is a driver class that inherits from both Ros2InspectionMixin and DeviceDriver. Ros2InspectionMixin supplies the shared ROS 2 RPCs. DeviceDriver makes the class a Device Connect device. You add any hardware-specific RPCs alongside the shared ones. The rpi5 profile runs the driver from puppypi_device.py:
class PuppyPiRos2Driver(Ros2InspectionMixin, DeviceDriver):
device_type = os.getenv("DEVICE_TYPE", "quadruped")
@rpc()
async def echo(self, text: str) -> dict[str, str]:
"""Echo text for connectivity testing."""
return {"echo": text}
# get_status(), run_action(), set_velocity(), stop() ...
async def main() -> None:
runtime = DeviceRuntime(driver=PuppyPiRos2Driver(), device_id=os.getenv("DEVICE_ID"))
await runtime.run()
DeviceRuntime connects the driver to the messaging network and announces every @rpc method, both inherited and its own, to peers. To support new hardware, write a new class. The other components stay the same.
Start the adapter
The start_d2d.sh launcher loads a profile and activates the .venv environment. The launcher sets device-to-device (D2D) defaults — the Zenoh backend, TCP port 7447, and a device ID of <profile>-d2d. It runs the driver script that the profile names.
Open a terminal on your Arm-based Linux machine and start the adapter with the rpi5 profile, pointing it at the ros2_test container:
cd ~/device_connect
DEVICE_PROFILE=rpi5 PROJECT_ROOT=$HOME/device_connect \
ROS_CONTAINER=ros2_test WORKSPACE_SETUP=/opt/ros/humble/setup.bash \
./ros2-device-connect/start_d2d.sh
The inline variables override the values in profiles/rpi5.env. You need the WORKSPACE_SETUP override because the rpi5 profile defaults to a robot workspace that doesn’t exist in a plain ros:humble container.
The adapter stays in the foreground. The adapter log shows that it has joined the Zenoh network in D2D mode as rpi5-d2d:
WARNING - Running in INSECURE mode (DEVICE_CONNECT_ALLOW_INSECURE=true). Do NOT use this in production!
INFO - Using ZENOH messaging backend
INFO - Driver connected: raspberry_pi
INFO - Subscribed to commands on device-connect.default.rpi5-d2d.cmd
INFO - D2D mode: skipping registry registration, using presence announcements
Call the RPCs from a client
Open a second terminal on the same machine. In ~/device_connect, create a file named client.py:
import json
from device_connect_agent_tools import connect, discover
from device_connect_agent_tools.tools import invoke
DEVICE = "rpi5-d2d"
CALLS = [
("echo", {"text": "hello from arm"}),
("get_status", {}),
("get_ros_topics", {}),
("get_ros_packages", {"contains": "std_msgs"}),
("get_topic_info", {"topic": "/chatter"}),
("get_topic_info", {"topic": "bad;rm"}),
connect()
found = discover("device(*)")
print("discovered:", [d["device_id"] for d in found["results"]])
for function, params in CALLS:
result = invoke(f"device({DEVICE}).function({function})", params=params)
print(f"--- {function}", json.dumps(result, indent=2))
The client uses two calls from the agent tools. discover("device(*)") lists every device on the network, and invoke() calls one function on a named device using a device(<id>).function(<name>) selector. The client doesn’t know about ROS 2 or Docker. It sees only the device and its RPCs.
Set the connection settings of the client and run it:
cd ~/device_connect
export MESSAGING_BACKEND=zenoh
export ZENOH_CONNECT=tcp/127.0.0.1:7447
export DEVICE_CONNECT_DISCOVERY_MODE=d2d
export DEVICE_CONNECT_ALLOW_INSECURE=true
export TENANT=default
.venv/bin/python client.py
ZENOH_CONNECT points the client at the Zenoh endpoint of the adapter. To reach the adapter from another machine on your LAN, replace 127.0.0.1 with the IP address of the adapter host.
The output is similar to the following, shortened for readability:
discovered: ['rpi5-d2d']
--- echo {
"success": true,
"device_id": "rpi5-d2d",
"function": "echo",
"result": {
"echo": "hello from arm"
--- get_status {
"result": {
"device": "puppypi",
"container": "ros2_test",
"container_status": "running",
"ros_ok": false,
"ros_output": [
"ROS_DISTRO=humble"
--- get_ros_topics {
"result": {
"ok": true,
"count": 3,
"items": [
"/chatter",
"/parameter_events",
"/rosout"
"truncated": false,
--- get_ros_packages {
"result": {
"ok": true,
"count": 1,
"items": [
"std_msgs"
--- get_topic_info {
"result": {
"ok": true,
"topic": "/chatter",
"stdout": "Type: std_msgs/msg/String\nPublisher count: 1\nSubscription count: 0\n",
"stderr": ""
"result": {
"ok": false,
Each result shows the following:
echoconfirms the full round trip from the client over Zenoh to the adapter.get_ros_topicsreturns the same three topics as theros2 topic listcommand, reached through all four components.get_topic_infoadds the message type of/chatter.get_ros_packagesshows thecontainsfilter reducing the package list tostd_msgs.- The second
get_topic_infocall is rejected atRos2InspectionMixin, so no command runs in the container. get_statusreports that the container is running ROS 2 Humble.ros_okisfalsebecause the health check for this driver looks for PuppyPi robot packages, which aren’t in a plainros:humblecontainer. This is expected.
Clean up
Stop the adapter with Ctrl+C in its terminal. If you started the adapter in the background, stop it with:
pkill -f puppypi_device.py
The ros2_test container keeps running. When you no longer need the container, remove it:
docker rm -f ros2_test
You’ve learned the four-component pattern of the adapter. You started the adapter in D2D mode and called its RPCs from a Python client that knows nothing about ROS 2.
Next, you’ll see how other profiles reuse layers with different device drivers for real hardware, such as a Raspberry Pi 5 with a camera.
