Give feedback
AI-assisted
Close
How do I confirm that I’m running on the right architecture before starting?
Run uname -m on your Arm-based Linux host. You should see aarch64.
What should I see to confirm that the ROS 2 container is working?
After starting the demo publisher, run docker exec ros2_test bash -lc 'source /opt/ros/humble/setup.bash && ros2 node list && ros2 topic list'. You should see /chatter, /parameter_events, and /rosout. You can expect an empty node list because the publisher runs as a hidden node.
How do I know that the adapter is running in D2D mode correctly?
Look for D2D mode: skipping registry registration, using presence announcements in the adapter log. Then, run .venv/bin/python client.py with the client environment settings. You should discover rpi5-d2d, and get_ros_topics should return /chatter.
Which profile should I use if I’m testing without a robot attached?
Use rpi5 with ROS_CONTAINER=ros2_test and WORKSPACE_SETUP=/opt/ros/humble/setup.bash. You can validate the shared inspection RPCs without PuppyPi hardware. You can expect ros_ok: false in get_status because the robot packages are absent.
Which profile should I use for a Raspberry Pi 5 camera?
Use rpi_camera for the Raspberry Pi 5 camera example. Run ./ros2-device-connect/start_camera_ros2.sh to start the pi_ros container and /image_raw publisher, then run DEVICE_PROFILE=rpi_camera ./ros2-device-connect/start_d2d.sh. For other hardware, create or edit a profiles/<name>.env file to select the driver, container, and ROS 2 setup scripts.
