Prepare a PyTorch Development Environment
Create a PyTorch model for MNIST
About PyTorch Model Training
Perform Training and Save the Model
Deploy the Model for Inference
Learn about Inference on Android
Create an Android Application
Prepare the Test Data
Run the Application
Optimizing Neural Network Models in PyTorch
Create an optimized PyTorch model for MNIST
Run optimization
Update the Android application
In this section you will create an Android application to run digit classification.
The application randomly loads a selected image containing a handwritten digit and its true label.
The application runs an inference on the image and predicts the digit value.
Start by creating a project:
Open Android Studio and create a new project with an Empty Views Activity.
Configure as follows:
Devices with hardware accelerators can leverage NNAPI to offload ML tasks to specialized hardware, such as Neural Processing Units (NPUs), Digital Signal Processors (DSPs), or Graphics Processing Units (GPUs).
The user interface design contains different components:
ImageView and TextView sections to display the image and its true label.TextView controls to display the predicted label and the inference time.Use the editor in Android Studio to replace the contents of activity_main.xml, located in src/main/res/layout with the following code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout
xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="match_parent"
android:layout_height="match_parent"
android:orientation="vertical"
android:padding="16dp"
android:gravity="center">
<!-- Header -->
<TextView
android:id="@+id/header"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:text="Digit Recognition"
android:textSize="24sp"
android:textStyle="bold"
android:layout_marginBottom="16dp"/>
<!-- ImageView to display the image -->
<ImageView
android:id="@+id/imageView"
android:layout_width="200dp"
android:layout_height="200dp"
android:layout_gravity="center"
android:contentDescription="Image for inference"
<!-- Label showing the true label of the image -->
<TextView
android:id="@+id/trueLabel"
android:text="True Label: N/A"
android:textSize="18sp"
<!-- Button to select an input image -->
<Button
android:id="@+id/selectImageButton"
android:text="Load Image"
<!-- Button to run inference -->
<Button
android:id="@+id/runInferenceButton"
android:text="Run Inference"
<!-- TextView to display the predicted label and inference time -->
<TextView
android:id="@+id/predictedLabel"
android:text="Predicted Label: N/A"
android:layout_marginBottom="8dp"/>
<TextView
android:id="@+id/inferenceTime"
android:text="Inference Time: N/A ms"
android:textSize="18sp"/>
</LinearLayout>
The XML code above defines a user interface layout for an Android activity using a vertical LinearLayout. It includes several UI components arranged vertically with padding and centered alignment.
At the top, there is a TextView acting as a header, displaying the text Digit Recognition in bold and with a large font size.
Below the header, an ImageView displays an image, with a default source set to sample_image.
This is followed by another TextView that shows the true label of the displayed image, initially set to True Label: N/A.
The layout also contains two buttons: one labeled Load Image for selecting an input image, and another labeled Run Inference to execute the inference process on the selected image.
At the bottom, there are two TextView elements to display the predicted label and the inference time, both initially set to N/A. The layout uses margins and appropriate sizes for each element to ensure a clean and organized appearance.
Add PyTorch to the project by opening the build.gradle.kts file and adding the following two lines under dependencies:
implementation("org.pytorch:pytorch_android:1.10.0")
implementation("org.pytorch:pytorch_android_torchvision:1.10.0")
The dependencies section should look as follows:
dependencies {
implementation(libs.androidx.core.ktx)
implementation(libs.androidx.appcompat)
implementation(libs.material)
implementation(libs.androidx.activity)
implementation(libs.androidx.constraintlayout)
testImplementation(libs.junit)
androidTestImplementation(libs.androidx.junit)
androidTestImplementation(libs.androidx.espresso.core)
You will now implement the logic for the application.
This includes loading the pre-trained model, loading and displaying images, and running inference.
Open MainActivity.kt and modify it as follows:
package com.arm.armpytorchmnistinference
import android.graphics.Bitmap
import android.graphics.BitmapFactory
import android.os.Bundle
import android.widget.Button
import android.widget.ImageView
import android.widget.TextView
import androidx.activity.enableEdgeToEdge
import androidx.appcompat.app.AppCompatActivity
import org.pytorch.IValue
import org.pytorch.Module
import org.pytorch.Tensor
import java.io.File
import java.io.FileOutputStream
import java.io.IOException
import java.io.InputStream
import kotlin.random.Random
import kotlin.system.measureNanoTime
class MainActivity : AppCompatActivity() {
private lateinit var imageView: ImageView
private lateinit var trueLabel: TextView
private lateinit var selectImageButton: Button
private lateinit var runInferenceButton: Button
private lateinit var predictedLabel: TextView
private lateinit var inferenceTime: TextView
private lateinit var model: Module
private var currentBitmap: Bitmap? = null
private var currentTrueLabel: Int? = null
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
enableEdgeToEdge()
setContentView(R.layout.activity_main)
// Initialize UI elements
imageView = findViewById(R.id.imageView)
trueLabel = findViewById(R.id.trueLabel)
selectImageButton = findViewById(R.id.selectImageButton)
runInferenceButton = findViewById(R.id.runInferenceButton)
predictedLabel = findViewById(R.id.predictedLabel)
inferenceTime = findViewById(R.id.inferenceTime)
// Load model from assets
model = Module.load(assetFilePath("model.pth"))
// Set up button click listener for selecting random image
selectImageButton.setOnClickListener {
selectRandomImageFromAssets()
// Set up button click listener for running inference
runInferenceButton.setOnClickListener {
currentBitmap?.let { bitmap ->
runInference(bitmap)
private fun selectRandomImageFromAssets() {
try {
// Get list of files in the mnist_bitmaps folder
val assetManager = assets
val files = assetManager.list("mnist_bitmaps") ?: arrayOf()
if (files.isEmpty()) {
trueLabel.text = "No images found in assets/mnist_bitmaps"
return
// Select a random file from the list
val randomFile = files[Random.nextInt(files.size)]
val inputStream: InputStream = assetManager.open("mnist_bitmaps/$randomFile")
val bitmap = BitmapFactory.decodeStream(inputStream)
// Extract the true label from the filename (e.g., 07_00.png -> true label is 7)
currentTrueLabel = randomFile.split("_")[0].toInt()
// Display the image and its true label
imageView.setImageBitmap(bitmap)
trueLabel.text = "True Label: $currentTrueLabel"
// Set the current bitmap for inference
currentBitmap = bitmap
} catch (e: IOException) {
e.printStackTrace()
trueLabel.text = "Error loading image from assets"
// Method to convert a grayscale bitmap to a float array and create a tensor with shape [1, 1, 28, 28]
private fun createTensorFromBitmap(bitmap: Bitmap): Tensor {
// Ensure the bitmap is in the correct format (grayscale) and dimensions [28, 28]
if (bitmap.width != 28 || bitmap.height != 28) {
throw IllegalArgumentException("Expected bitmap of size [28, 28], but got [${bitmap.width}, ${bitmap.height}]")
// Convert the grayscale bitmap to a float array
val width = bitmap.width
val height = bitmap.height
val floatArray = FloatArray(width * height)
val pixels = IntArray(width * height)
bitmap.getPixels(pixels, 0, width, 0, 0, width, height)
for (i in pixels.indices) {
// Normalize pixel values to [0, 1] range, assuming the grayscale image stores values in the R channel
floatArray[i] = (pixels[i] and 0xFF) / 255.0f
// Create a tensor with shape [1, 1, 28, 28] (batch size, channels, height, width)
return Tensor.fromBlob(floatArray, longArrayOf(1, 1, height.toLong(), width.toLong()))
private fun runInference(bitmap: Bitmap) {
// Convert bitmap to a float array and create a tensor with shape [1, 1, 28, 28]
val inputTensor = createTensorFromBitmap(bitmap)
// Run inference and measure time
val inferenceTimeMicros = measureTimeMicros {
// Forward pass through the model
val outputTensor = model.forward(IValue.from(inputTensor)).toTensor()
val scores = outputTensor.dataAsFloatArray
// Get the index of the class with the highest score
val maxIndex = scores.indices.maxByOrNull { scores[it] } ?: -1
predictedLabel.text = "Predicted Label: $maxIndex"
// Update inference time TextView in microseconds
inferenceTime.text = "Inference Time: $inferenceTimeMicros µs"
// Method to measure execution time in microseconds
private inline fun measureTimeMicros(block: () -> Unit): Long {
val time = measureNanoTime(block)
return time / 1000 // Convert nanoseconds to microseconds
// Helper function to get the file path from assets
private fun assetFilePath(assetName: String): String {
val file = File(filesDir, assetName)
assets.open(assetName).use { inputStream ->
FileOutputStream(file).use { outputStream ->
val buffer = ByteArray(4 * 1024)
var read: Int
while (inputStream.read(buffer).also { read = it } != -1) {
outputStream.write(buffer, 0, read)
outputStream.flush()
return file.absolutePath
This Kotlin code defines an Android app activity called MainActivity that performs inference on the MNIST dataset using a pre-trained PyTorch model. The app allows the user to load a random MNIST image from the assets folder and run the model to classify the image.
The MainActivity class contains several methods:
The onCreate() method is called when the activity is first created. It sets up the user interface by inflating the layout defined in activity_main.xml and initializes several UI components, including an ImageView to display the image, TextView controls to show the true label and predicted label, and two buttons, selectImageButton and runInferenceButton, to select an image and run inference. This method then loads the PyTorch model from the assets folder using the assetFilePath() function, and sets up click listeners for the buttons. The selectImageButton is configured to select a random image from the mnist_bitmaps folder, while the runInferenceButton runs the inference on the selected image.
The selectRandomImageFromAssets() method is responsible for selecting a random image from the mnist_bitmaps folder in assets. It lists all the files in the folder, picks one at random, and loads it as a bitmap. This method then does the following:
ImageView.trueLabel TextView with the correct label.If there is an error loading the image or the folder is empty, an appropriate error message is displayed in the trueLabel TextView.
The createTensorFromBitmap() method converts a grayscale bitmap of size 28x28 (an image from the MNIST dataset) into a PyTorch Tensor, through the following steps:
The runInference() method accepts a bitmap as input and performs inference using the pre-trained PyTorch model, through the following steps:
createTensorFromBitmap() method.measureTimeMicros() method.predictedLabel TextView.inferenceTime TextView with the time taken for the inference in microseconds.The inline function measureTimeMicros() is a utility method that measures the execution time of the given code block in microseconds:
measureNanoTime() function to get the execution time in nanoseconds.runInference() method.The assetFilePath() method is a helper function that copies a file from the assets folder to the application’s internal storage and returns the absolute path of the copied file. This is necessary because PyTorch’s Module.load() method requires a file path, not an InputStream. The assetFilePath() method does the following:
This method is used in onCreate() to load the PyTorch model file, model.pth, from the assets folder.
MainActivity class initializes the UI components, loads a pre-trained PyTorch model, and allows the user to select random MNIST images and run inference on them.Each method is designed to handle a specific aspect of the functionality, such as loading images, converting them to tensors, running inference, and measuring execution time. The code is modular and organized, making it easy to understand and maintain.
To be able to successfully run the application, you need to add the model and prepare the bitmaps. Continue with this Learning Path to learn how to prepare the data.
