Prepare a PyTorch Development Environment
Create a PyTorch model for MNIST
About PyTorch Model Training
Perform Training and Save the Model
Deploy the Model for Inference
Learn about Inference on Android
Create an Android Application
Prepare the Test Data
Run the Application
Optimizing Neural Network Models in PyTorch
Create an optimized PyTorch model for MNIST
Run optimization
Update the Android application
You can create and train an optimized feedforward neural network to classify handwritten digits from the MNIST dataset. This time you will introduce several changes to enable model quantization and fusing.
Start by creating a new notebook named pytorch-digits-model-optimizations.ipynb.
Then define the model architecture using the code below.
You can also find the source code on GitHub .
import torch
from torch import nn
from torchsummary import summary
class_names = range(10)
class NeuralNetwork(nn.Module):
def __init__(self, use_dropout=True):
super(NeuralNetwork, self).__init__()
self.use_dropout = use_dropout
self.flatten = nn.Flatten()
self.linear1 = nn.Linear(28*28, 96)
self.relu1 = nn.ReLU()
self.dropout1 = nn.Dropout(0.2) if use_dropout else nn.Identity()
self.linear2 = nn.Linear(96, 256)
self.relu2 = nn.ReLU()
self.dropout2 = nn.Dropout(0.2) if use_dropout else nn.Identity()
self.linear3 = nn.Linear(256, len(class_names))
# Softmax is removed from the model
def forward(self, x):
x = self.flatten(x)
x = self.linear1(x)
x = self.relu1(x)
x = self.dropout1(x)
x = self.linear2(x)
x = self.relu2(x)
x = self.dropout2(x)
x = self.linear3(x)
return x # Outputs raw logits
This code defines a neural network in PyTorch for digit classification, consisting of three linear layers with ReLU activations and optional dropout layers for regularization. The network first flattens the input, that is a 28x28 image, and passes it through two linear layers, each followed by a ReLU activation and if enabled, a dropout layer. The final layer produces raw logits as the output. Notably, the softmax layer has been removed to enable quantization and layer fusion during model optimization, allowing better performance when deploying the model on mobile or edge devices.
The output is left as logits, and the softmax function can be applied during post-processing, particularly during inference.
This model includes dropout layers, which are used during training to randomly set a portion of the neurons to zero in order to prevent overfitting and improve generalization.
The use_dropout parameter allows you to enable or disable dropout, with the option to bypass dropout by replacing it with a nn.Identity layer when set to False, which is typically done during inference or quantization for more consistent behavior.
Add the following lines to display the model architecture:
model = NeuralNetwork()
summary(model, (1, 28, 28))
After running the code, you will see the following output:
Layer (type) Output Shape Param #
Flatten-1 [-1, 784] 0
Linear-2 [-1, 96] 75,360
ReLU-3 [-1, 96] 0
Dropout-4 [-1, 96] 0
Linear-5 [-1, 256] 24,832
ReLU-6 [-1, 256] 0
Dropout-7 [-1, 256] 0
Linear-8 [-1, 10] 2,570
Total params: 102,762
Trainable params: 102,762
Non-trainable params: 0
Input size (MB): 0.00
Forward/backward pass size (MB): 0.01
Params size (MB): 0.39
Estimated Total Size (MB): 0.41
The output shows the structure of the neural network, including the layers, their output shapes, and the number of parameters.
Now add the load-the-data, train, and test loops to train the model. This process is the same as with the original model:
from torchvision import transforms, datasets
from torch.utils.data import DataLoader
# Training data
training_data = datasets.MNIST(
root="data",
train=True,
download=True,
transform=transforms.ToTensor()
# Test data
test_data = datasets.MNIST(
root="data",
train=False,
download=True,
# Dataloaders
batch_size = 32
train_dataloader = DataLoader(training_data, batch_size=batch_size)
test_dataloader = DataLoader(test_data, batch_size=batch_size)
learning_rate = 1e-3;
loss_fn = nn.CrossEntropyLoss()
optimizer = torch.optim.Adam(model.parameters(), lr=learning_rate)
def train_loop(dataloader, model, loss_fn, optimizer):
size = len(dataloader.dataset)
for batch, (x, y) in enumerate(dataloader):
# Compute prediction and loss
pred = model(x)
loss = loss_fn(pred, y)
# Backpropagation
optimizer.zero_grad()
loss.backward()
optimizer.step()
def test_loop(dataloader, model, loss_fn):
num_batches = len(dataloader)
test_loss, correct = 0, 0
with torch.no_grad():
for x, y in dataloader:
pred = model(x)
test_loss += loss_fn(pred, y).item()
correct += (pred.argmax(1) == y).type(torch.float).sum().item()
test_loss /= num_batches
correct /= size
print(f"Accuracy: {(100*correct):>0.1f}%, Avg loss: {test_loss:>8f} \n")
epochs = 10
for t in range(epochs):
print(f"Epoch {t+1}:")
train_loop(train_dataloader, model, loss_fn, optimizer)
test_loop(test_dataloader, model, loss_fn)
Begin by preparing the MNIST dataset for training and testing the neural network model.
Using the torchvision library, download the MNIST dataset and apply a transformation to convert the images into tensors, making them suitable for input into the model.
Next, create two data loaders: one for the training set and one for the test set, each configured with a batch size of 32. These data loaders allow you to easily feed batches of images into the model during training and testing.
Next, define a training loop, which is at the core of the model’s learning process. For each batch of images and labels, the model generates predictions, and you calculate the cross-entropy loss to measure how far off the predictions are from the true labels.
The Adam optimizer is used to perform backpropagation, updating the model’s weights to reduce this error. The process repeats for every batch in the training dataset, gradually improving model accuracy over time.
To ensure the model is learning effectively, you need to define a testing loop.
Here, the model is evaluated on a separate set of test images that it has not seen during training. You can calculate both the average loss and the accuracy of the predictions, and it will give you a clear sense of how well the model is performing. This evaluation must be done without updating the model’s weights, as the goal is simply to measure its performance.
Finally, run the training and testing loops over the course of 10 epochs. With each epoch, the model trains on the full training dataset, and afterwards, you can test it to monitor its progress. By the end of the process, the model has learned to classify the MNIST digits with a high degree of accuracy, as reflected in the final test results.
This setup efficiently trains and evaluates the model for digit classification, providing feedback after each epoch on accuracy and loss.
After running the code you will see the following output:
Epoch 1:
Accuracy: 94.0%, Avg loss: 0.196315
Epoch 2:
Accuracy: 95.3%, Avg loss: 0.155560
Epoch 3:
Accuracy: 95.9%, Avg loss: 0.138764
Epoch 4:
Accuracy: 95.4%, Avg loss: 0.156163
Epoch 5:
Accuracy: 95.5%, Avg loss: 0.163152
Epoch 6:
Accuracy: 96.3%, Avg loss: 0.129509
Epoch 7:
Accuracy: 96.8%, Avg loss: 0.124872
Epoch 8:
Accuracy: 96.6%, Avg loss: 0.127252
Epoch 9:
Accuracy: 96.4%, Avg loss: 0.134298
Epoch 10:
Accuracy: 96.5%, Avg loss: 0.137004
These results show a similar rate of accuracy as the original model.
You now have the trained model with the modified architecture.
In the next step you will optimize it for mobile inference.
