Arm Trusted Firmware provides a reference implementation of Platform Security Architecture (PSA). Reference implementations are available for a number of platforms .
This Learning Path uses the Corstone-1000 platform.
The software stack can be executed on the Corstone-1000 Fixed Virtual Platform (FVP) and the MPS3 FPGA prototyping board.
You can access the FVP with Arm Virtual Hardware . Setup instructions are given in the Arm Virtual Hardware install guide .
The Corstone-1000 FVP is also available from the Arm Ecosystem FVP page. Setup instructions are given in the install guide . Use this for a local (Linux) development environment.
You can also use MPS3 FPGA Prototyping Board programmed with AN550 .
The image requires the QSPI Flash Module
to be installed. Refer to section 8.2 of the
AN550 documentation
