Build JetPack Yocto images for NVIDIA Jetson platforms
Understand Yocto image builds for NVIDIA Jetson
Provision a Google Axion C4A VM for Arm Yocto builds
Build a Yocto image for NVIDIA Jetson on a Google Axion VM
Flash the Yocto image onto the NVIDIA Jetson device
Run the Yocto image on the NVIDIA Jetson device
Use the
c4a-standard-32 machine type, which provides 32 vCPUs and 128 GB of memory. In the Google Cloud console, confirm that Series is set to C4A and Machine type is set to c4a-standard-32.The build summary reports
BUILD COMPLETE and lists the workspace, deploy directory, primary flashing image, and bundle archive paths. Confirm that the generated .tar.gz archive exists before continuing.Install the Google Cloud CLI on your Ubuntu host and authenticate with
gcloud auth login. Then use gcloud compute scp to copy the bundled archive from the C4A VM to your host.Use Ubuntu 22.04 or later with USB access to the Jetson device. Install
dtc, build-essential, gdisk, gptfdisk, udisks2, bmap-tools, libxml2-utils, zstd, tar, and usbutils before extracting and flashing the image.After the Matchbox desktop appears, open a terminal and run
nvidia-smi and docker --version. Successful output confirms that the NVIDIA GPU drivers and Docker runtime are available.
