Matrix multiplication with SME2 in assembly
In this chapter, you will use an SME2-optimized matrix multiplication written directly in assembly.
Description
This Learning Path reuses the assembly version provided in the SME Programmer’s Guide where you will find a high-level and an in-depth description of the two steps performed.
The assembly versions have been modified so they coexist nicely with the intrinsic versions. In this Learning Path, the preprocess function is defined in preprocess_l_asm.S and the outer product-based matrix multiplication is found in matmul_asm_impl.S.
These two functions have been stitched together in matmul_asm.c with the same prototype as the reference implementation of matrix multiplication, so that a top-level matmul_asm can be called from the main function:
void matmul_asm(uint64_t M, uint64_t K, uint64_t N,
                const float *restrict matLeft, const float *restrict matRight,
                float *restrict matLeft_mod, float *restrict matResult) {
    __asm volatile(""
                   : "p0", "p1", "p2", "p3", "p4", "p5", "p6", "p7", "p8", "p9",
                     "p10", "p11", "p12", "p13", "p14", "p15", "z0", "z1", "z2",
                     "z3", "z4", "z5", "z6", "z7", "z8", "z9", "z10", "z11",
                     "z12", "z13", "z14", "z15", "z16", "z17", "z18", "z19",
                     "z20", "z21", "z22", "z23", "z24", "z25", "z26", "z27",
                     "z28", "z29", "z30", "z31");
    preprocess_l_asm(M, K, matLeft, matLeft_mod);
    matmul_asm_impl(M, K, N, matLeft_mod, matRight, matResult);
    __asm volatile(""
Note here the use of the __asm statement forcing the compiler to save the SVE/SME registers.
The high-level matmul_asm function is called from main.c:
#include "matmul.h"
#include "misc.h"
#include <inttypes.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#ifndef __ARM_FEATURE_SME2
#error __ARM_FEATURE_SME2 is not defined
#endif
#ifndef IMPL
#error matmul implementation selection macro IMPL is not defined
#endif
#define STRINGIFY_(I) #I
#define STRINGIFY(I) STRINGIFY_(I)
#define FN(M, I) M##I
#define MATMUL(I, M, K, N, mL, mR, mM, m) FN(matmul_, I)(M, K, N, mL, mR, mM, m)
// Assumptions:
// nbr in matLeft (M): any
// nbc in matLeft, nbr in matRight (K): any K > 2 (for the asm version)
// nbc in matRight (N): any
int main(int argc, char **argv) {
    /* Size parameters */
    uint64_t M, N, K;
    if (argc >= 4) {
        M = strtoul(argv[1], NULL, 0);
        K = strtoul(argv[2], NULL, 0);
        N = strtoul(argv[3], NULL, 0);
    } else {
        /* Default: 125x35x70 */
        M = 125;
        K = 35;
        N = 70;
    printf("\nSME2 Matrix Multiply fp32 *%s* example with args %lu %lu %lu\n",
           STRINGIFY(IMPL), M, K, N);
    setup_sme();
    const uint64_t SVL = svcntsw();
    /* Calculate M of transformed matLeft.  */
    const uint64_t M_mod = SVL * (M / SVL + (M % SVL != 0 ? 1 : 0));
    float *matRight = (float *)malloc(K * N * sizeof(float));
    float *matLeft = (float *)malloc(M * K * sizeof(float));
    float *matLeft_mod = (float *)malloc(M_mod * K * sizeof(float));
    float *matLeft_mod_ref = (float *)malloc(M_mod * K * sizeof(float));
    float *matResult = (float *)malloc(M * N * sizeof(float));
    float *matResult_ref = (float *)malloc(M * N * sizeof(float));
#ifdef DEBUG
    initialize_matrix(matLeft, M * K, LINEAR_INIT);
    initialize_matrix(matRight, K * N, LINEAR_INIT);
    initialize_matrix(matLeft_mod, M_mod * K, DEAD_INIT);
    initialize_matrix(matResult, M * N, DEAD_INIT);
    print_matrix(M, K, matLeft, "matLeft");
    print_matrix(K, N, matRight, "matRight");
#else
    initialize_matrix(matLeft, M * K, RANDOM_INIT);
    initialize_matrix(matRight, K * N, RANDOM_INIT);
#endif
    MATMUL(IMPL, M, K, N, matLeft, matRight, matLeft_mod, matResult);
    // Compute the reference values with the vanilla implementations.
    matmul(M, K, N, matLeft, matRight, matResult_ref);
    preprocess_l(M, K, SVL, matLeft, matLeft_mod_ref);
    unsigned error = compare_matrices(K, M_mod, matLeft_mod_ref, matLeft_mod,
                                      "Matrix preprocessing");
    if (!error)
        error = compare_matrices(M, N, matResult_ref, matResult,
                                 "Matrix multiplication");
    free(matRight);
    free(matLeft);
    free(matLeft_mod);
    free(matLeft_mod_ref);
    free(matResult);
    free(matResult_ref);
    return error ? EXIT_FAILURE : EXIT_SUCCESS;
The same main.c file is used for the assembly and intrinsic-based versions of the matrix multiplication. It first sets the M, K and N parameters, to either the arguments supplied on the command line or uses the default value.
Depending on the M, K, N dimension parameters, main allocates memory for all the matrices and initializes matLeft and matRight with random data. The actual matrix multiplication implementation is provided through the IMPL macro.
It then runs the matrix multiplication from IMPL and computes the reference values for the preprocessed matrix as well as the result matrix. It then compares the actual values to the reference values and reports errors, if there are any. Finally, all the memory is deallocated before exiting the program with a success or failure return code.
Compile and run it
First, make sure that the sme2_matmul_asm executable is up-to-date:
docker run --rm -v "$PWD:/work" -w /work armswdev/sme2-learning-path:sme2-environment-v1 make sme2_matmul_asm
Then execute sme2_matmul_asm on the FVP:
docker run --rm -v "$PWD:/work" -w /work armswdev/sme2-learning-path:sme2-environment-v1 ./run-fvp.sh sme2_matmul_asm
The output should be something similar to:
SME2 Matrix Multiply fp32 *asm* example with args 125 35 70
Matrix preprocessing: PASS !
Matrix multiplication: PASS !
Info: /OSCI/SystemC: Simulation stopped by user.
Tip
The example above uses the default values for the M (125), K(25) and N(70) parameters. You can override this and provide your own values on the command line:
docker run --rm -v "$PWD:/work" -w /work armswdev/sme2-learning-path:sme2-environment-v1 ./run-fvp.sh sme2_matmul_asm 7 8 9
Here the values M=7, K=8 and N=9 are used instead.
