In this section, you will learn how you can use the outer product with the SME engine to improve matrix multiplication.
In this standard matrix multiplication example, the core of the computation can be represented as:
acc += matLeft[m * K + k] * matRight[k * N + n];
Which translates to 1 multiply-accumulate, which is also known as macc
, for two loads (matLeft[m * K + k]
and matRight[k *N + n]
). It therefore has a 1:2 macc
to load
ratio.
From a memory system perspective, this is not effective, especially since this computation is done within a triple-nested loop, repeatedly loading data from memory.
To exacerbate matters, large matrices might not fit in cache. In order to improve the matrix multiplication efficiency, the goal is to increase the macc
to load
ratio, which means to increase the number of multiply-accumulate operations per load.
Figure 3 below shows how the matrix multiplication of matLeft
(3 rows, 2
columns) by matRight
(2 rows, 3 columns) can be decomposed as the sum of the
outer products:
Figure 3: Outer Product-based Matrix Multiplication.
The SME engine builds on the Outer Product as matrix multiplication can be expressed as the sum of column-by-row outer products .
From the previous page, you will recall that matrices are laid out in row-major
order. This means that loading row-data from memory is efficient as the memory
system operates efficiently with contiguous data. An example of this is where caches are loaded row by row, and data prefetching is simple - just load the data from current address + sizeof(data)
. This is not the case for loading column-data from memory though, as it requires more work from the memory system.
In order to further improve the effectiveness of the matrix multiplication, it
is therefore desirable to change the layout in memory of the left-hand side
matrix, which is called matLeft
in the code examples in this Learning Path.
The improved layout would ensure that elements from the same column are located
next to each other in memory. This is essentially a matrix transposition,
which changes matLeft
from row-major order to column-major order.
It is important to note here that this reorganizes the layout of the matrix in
memory in order for the algorithm implementation to be more efficient. The
transposition affects only the memory layout. matLeft
is transformed to
column-major order, but from a mathematical perspective, matleft
is
not transposed.
In the same way that trees don’t reach the sky, the SME engine has physical implementation limits. It operates with tiles in the ZA storage. Tiles are 2D portions of the matrices being processed. SME has dedicated instructions to load data to, and store data from tiles efficiently, as well as instructions to operate with and on tiles, for example the
fmopa
instruction which takes two vectors as inputs and accumulate all the outer
products to a 2D tile. The tile in ZA storage is what allows SME to increase the
macc
to load
ratio, as all the tile elements are loaded to the tile, to
be used with the SME outer product instructions.
Taking into account that the ZA storage is finite, the desirable transposition
of the matLeft
matrix that was discussed in the previous section needs to
adapted to the tile dimensions, so that a tile is easy to access. The
matLeft
preprocessing has thus some aspects of transpositions, but takes
into account the tiling as well and is referred to in the code as
preprocess
Here is at the algorithmic level what preprocess_l
does in practice:
void preprocess_l(uint64_t nbr, uint64_t nbc, uint64_t SVL,
const float *restrict a, float *restrict a_mod) {
// For all tiles of SVL x SVL data
for (uint64_t By = 0; By < nbr; By += SVL) {
for (uint64_t Bx = 0; Bx < nbc; Bx += SVL) {
// For this tile
const uint64_t dest = By * nbc + Bx * SVL;
for (uint64_t j = 0; j < SVL; j++) {
for (uint64_t i = 0; i < SVL && (Bx + i) < nbc; i++) {
if (By + j < nbr) {
a_mod[dest + i * SVL + j] = a[(By + j) * nbc + Bx + i];
} else {
// These elements are outside of matrix a, so zero them.
a_mod[dest + i * SVL + j] = 0.0;
preprocess_l
will be used to check the assembly and intrinsic versions of
the matrix multiplication perform the preprocessing step correctly. This code is
located in file preprocess_vanilla.c
In real-world applications, it might be possible to arrange for matLeft
to
be stored in column-major order, eliminating the need for transposition, and making the preprocessing step unnecessary. Matrix processing frameworks and libraries often have attributes within the matrix object to track if it is row- or column-major order, and whether it has been transposed to avoid unnecessary computations.
