# [Cache prefetching](https://learn.arm.com/learning-paths/cross-platform/memory-latency/latency-and-cache-prefetching/)
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/memory-latency/)
- [About memory latency](https://learn.arm.com/learning-paths/cross-platform/memory-latency/what-is-latency/)
- [How latency impacts performance - part 1](https://learn.arm.com/learning-paths/cross-platform/memory-latency/how-latency-impacts-performance-1/)
- [How latency impacts performance - part 2](https://learn.arm.com/learning-paths/cross-platform/memory-latency/how-latency-impacts-performance-2/)
- [Cache alignment](https://learn.arm.com/learning-paths/cross-platform/memory-latency/latency-and-cache-alignment/)
- [Cache prefetching](https://learn.arm.com/learning-paths/cross-platform/memory-latency/latency-and-cache-prefetching/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/memory-latency/_next-steps/)
Cache prefetching is another way to increase performance without changing the algorithm much and without rewriting the code in assembly.
Remember that the original problem of memory latency exists because the CPU must wait for data to arrive from the memory. Cache prefetching is a way to instruct the CPU to prefetch data to arrive in the L1 cache so that it is already close to the CPU when needed. Keep in mind that typical RAM latency is about 100 ns, so it is not sufficient to just prefetch the data that will be processed in the *next* iteration of a loop, it needs to be done a few iterations before.
You can try cache prefetching with the following example.
The first step is to determine the right place to tell the CPU to prefetch data. Although all CPUs have their own cache prefetching assembly instructions, it is recommended to use a GCC builtin that has become the de facto standard for portability. Unless you are writing assembly code or code that requires particular cache prefetching instructions, you should use `__builtin_prefetch()` in your code.
Add the cache prefetching builtin to the `init_alloc()` function as shown below:
```c
static void init_alloc() {
    if (start_ == NULL) {
        __builtin_prefetch(start_);
        memset(start_, 0, SIMPLE_ALLOCATOR_SIZE);
Compiling and running the example code doesn’t show any benefit.
There are two reasons for this:
- You need to prefetch the data that will be used in the iterations ahead, and not just for the data needed immediately before use.
- Prefetching tells the CPU to prefetch data just once, but it would be better to do this as part of a loop.
To counter the first argument, try increasing the prefetching by a multiple of the cache line size, 16 * 64.
```c
        __builtin_prefetch(start_ + 16 * 64);
Compile and run the application again:
gcc -O3 -o memory-latency2 memory-latency2.c -Wall
./memory-latency2
The output shows the program takes longer than the previous version.
__output__ 1000000 Nodes creation took 3800 us
Prefetching eliminates additional time from the program. This is because the CPU is able to load the first 16 * 64 bytes directly from the cache in the first iteration.
To continue, add the prefetch command to the loop, the place to do this is inside the `simple_alloc()` function.
Add a similar call to `__builtin_prefetch()` as shown below in `simple_alloc()`:
```c
static void* simple_alloc(size_t size) {
    if (cur_ + size <= end_) {
        void* ptr = cur_;
        cur_ += size;
        counter_++;
        __builtin_prefetch(cur_ + 16 * 64);
        return ptr;
    } else {
        printf("Error allocating %ld bytes!", size);
    return NULL;
./memory-latency2
Here is the new output which shows the lowest value so far:
__output__ 1000000 Nodes creation took 2772 us
By using cache prefetching, you have doubled the performance of the code without having to change the data structure or the algorithm. The changes make it easier for the CPU to find the data in the L1 cache when needed.
Cache prefetching is an essential part of the software optimization process. In some cases, the CPU is smart enough to recognize a data transfer pattern and start the prefetch on its own, especially in the latest Arm CPUs, but sometimes a manual nudge is needed to improve performance.
