You can modify the original application to create a new version which runs faster.
Copy the original memory-latency1.c file to a new file named memory-latency2.c.
cp memory-latency1.c memory-latency2.c
Add the following code after the first #define:
#define NODES 1000000
#define SIMPLE_ALLOCATOR_SIZE 100000000UL
static void *start_ = NULL;
static void *cur_ = NULL;
static void *end_ = NULL;
static size_t counter_ = 0;
static void init_alloc() {
if (start_ == NULL) {
start_ = malloc(SIMPLE_ALLOCATOR_SIZE);
printf("Error allocating %ld bytes for allocator!", SIMPLE_ALLOCATOR_SIZE);
exit(1);
memset(start_, 0, SIMPLE_ALLOCATOR_SIZE);
cur_ = start_;
end_ = start_ + SIMPLE_ALLOCATOR_SIZE;
printf("start_: %p, end_: %p\n", start_, end_);
static void* simple_alloc(size_t size) {
if (cur_ + size <= end_) {
void *ptr = cur_;
cur_ += size;
counter_++;
return ptr;
} else {
printf("Error allocating %ld bytes!", size);
return NULL;
Replace the malloc() with the new function simple_alloc() in new_node():
node_t *new_node(node_t *prev, const char *payload, size_t size) {
node_t *n = (node_t *) simple_alloc(sizeof(node_t));
if (n == NULL) {
The function free_nodes() call at the bottom of main() is not needed, you can remove it.
Add the init_alloc() in the start of main() and free(start_) at the end to free the buffer allocated by our simple allocator:
int main() {
init_alloc();
free(start_);
Compile the new file:
gcc -O3 -o memory-latency2 memory-latency2.c -Wall
Run the application:
./memory-latency2
The output will print the time taken to run the application:
1000000 Nodes creation took 5374 us
Run the application again with perf using:
perf record ./memory-latency2
When the application completes, generate the report using:
perf report
The new report will be similar to:
# Overhead Command Shared Object Symbol
49.68% memory-latency2 memory-latency2 [.] main
29.03% memory-latency2 [kernel.kallsyms] [k] __pi_clear_page
3.38% memory-latency2 [kernel.kallsyms] [k] free_unref_page
3.32% memory-latency2 [kernel.kallsyms] [k] rcu_all_qs
3.18% memory-latency2 [kernel.kallsyms] [k] folio_batch_move_lru
3.01% memory-latency2 [kernel.kallsyms] [k] __cond_resched
2.89% memory-latency2 [kernel.kallsyms] [k] get_page_from_freelist
1.83% memory-latency2 [kernel.kallsyms] [k] crng_make_state
1.55% memory-latency2 [kernel.kallsyms] [k] ptep_clear_flush
1.07% memory-latency2 ld-linux-aarch64.so.1 [.] __tunable_get_val
Replacing the memory allocator for a simpler allocator gives a significant speed gain, more than 5x in this case.
This method of using a custom allocator is popular in performance-critical applications and libraries where the default system allocator is too generic or slow for the needs of the application.
A linear allocator like the one used here is one of the simplest memory allocators, and is popular in systems with known fixed size objects or known constrained size limits.
There are many more memory allocators for different sizes and quite a few of them are much faster than the default malloc(). To learn more about how a memory allocator works and write one yourself, please have a look at the
dynamic memory allocator learning path
